Question about Silver King Fountainette SKF2A Side by Side Refrigerator
Hi i bought a knobless temp control part no. svk20889 how do i put the knob on it part no. svk20651
I cannot understand the dual thermostat manual (" rolling " knob type) controls . They are printed in Japanese . There are 2 temp. control knobs side by side located inside the ref. compartment / lowe
Don't think it's the temp control problem, I suspect one on the defrost elements at the top is faulty, if food starting to defrost in the cycle indicates the lower element is working overtime.
Nov 22, 2014 | Refrigerators
Center console is stuck on taught temp control. What removes it?
You probably need to pullthe knobs off the 3 controls so that the panel can be pulled foreward!
Jan 01, 2013 | Cars & Trucks
Adjust temp gdm 12
HI. NORMALLY IS CLOCKWISE FOR COLDER.HOPE THIS HELPS
Jun 26, 2012 | True GDM-12 Refrigerator Commercial
My son just bought a used Caloric self-cleaning gas range and the oven knob is high,med,and low. How does he know what the temp. is for setting the oven for baking?
Hi, It is the wrong knob. Do all the burner knobs look the same?
The oven knob has to have #'s on it so you know what hte temp is.
Please get me a model # and I can get you the part # for the knob you need.
Vic
Jul 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Dash Control Unit Replacement
You can save a LOT of money by fixing it yourself.
All that is wrong with the knob are broken wires from the knob's PC board to the main PC board on the AC control.
All you have to do is remove the AC main control, take it apart, and resolder the broken wires from the PC board with the knob on it, to the main AC pc board. There are 3 wires, any number could be broken.
If you take it apart and solder the broken wires, this WILL fix your issue. Just make sure you put the wires back exactly where they go.
A FIXYA rating (4 blue diamonds) would be most appreciated for my assistance.
Mar 21, 2009 | 2002 Toyota Highlander
Temperature control knob turns but doesn't change temp.
the heater control valve is visible through the speaker cut-out; it's at the end of the plastic heater control rod, inside the car - not on the other side of the firewall! It's connected to the valve with a plastic "universal joint".
Check that the valve is actually being turned by the rod. The connection might not be good (pulled apart or broken), and or the valve might be stuck.
Saabreur
Mar 14, 2009 | 1991 Saab 900
Oven temp 30 degrees low
Usually you remove the temperature control knob. A screw on the back can be loosened to allow the dial to be moved to correlate the temperature in the oven to the the setting on the knob. Tighten the screw, put the knob back on and you are good to go!
I hope this helps
Jan 02, 2009 | Kitchen Ranges
'99 Hansgrohe Aktiva Family Set. All heads & controls are leaking
the temp control knobs have little plastic tabs over the hot and cold handles. To remove them take a flat blade screw driver( small with sharp head) or a small pen knife( cover drain with a wash cloth
and pop the tabs off
Take a medium size phillips screw driver and tighten the screw
Put tab back o and you are done
If they work loos again remov e tabs, screws put loctite ( You can get a small tube for m ace or hd) screw threads and tighten
Temp control knob either has same tab or has a hex type of set screw or has a large lock nut
use a channel lock pliars over nut ( protect chrome finish by putting washcloth over then put wrench over cloth
You mentioned heads I am assuming shower head you need to use an adjuatible wrench to turn the nut (at head) and a vice rip or chanel locks over washcloth around the eustaceon ( chrome pipe coming out of wall
If you have teflon tape put that on the threads of showr head and tighten
Best of luck to you!
Nov 18, 2008 | Hansgrohe Plumbing
Silver King Fountainette SKF2A Side by Side Refrigerator Logo
20 people viewed this question
Top Silver King Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Silver King Refrigerator Expert? Answer questions, earn points and help others
