Question about HP LaserJet 3600n Printer
Can you please tell me the product code for the HP3600N fuser unit
  • 1,110 Answers
The part number for the fusing unit is RM1-4348-000
Posted on Sep 08, 2010
C-0500
Remove the fuser unit and verify the fuser heater lamp continuity and the thermofuse continuity.To reset the trouble code please tell me the copier model.
Apr 03, 2013 | Konica Minolta Office Equipment & Supplies
Malfunction code c0500
In minolta copiers the C5xx codes refer to fuser unit malfunctions.Verify the fuser unit gears,the fuserheater lamp continuity and the thermofuses continuity.To reset the codes please the copier model and I tell you the reset method.
Mar 01, 2013 | Konica Minolta Office Equipment & Supplies
I have IR 4570 error code E0000001-0002 i am reset this function this but this will not solve please help me
If you have resr the error code in service mode and it did not clear.... Odds are you are going to have to replace the upper fuser heating unit with a new fuser film or you may want to replace the whole fuser unit..... The heating element is shorting out...... Good Luck
Dec 25, 2011 | Office Equipment & Supplies
What is error code E000 mean
Solution:
Press "Additional Functions",
Press "#", then press the "Right Arrow" button till it says, "Printer",
Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
Then press "Set" again, the display will ask you "Yes" or "No".
Press the "Left" arrow for "Yes", then press "Set".
Now, unplug the power cord and wait 5 seconds and plug back in.
If this don't work, get a new fuser.
Feb 04, 2010 | Canon imageCLASS D880 All-In-One Laser...
Hp3600n is stating that the fuser is hot what do I do
you either need to buy a replacement fuser assembly or a thermister for this unit the install is hard but it might be worth fixing due to the cost of the unit,
Jan 27, 2010 | HP Color LaserJet 2600n Printer
My iR2016 displays "system error E007, would you please help me repairing it?-
it error code means fuser unite problem please change fuser unite then solve your problem
Nov 20, 2009 | Canon PC-940 Black and White Copier
Hello, i have a canon xerox machine ir3300 model. I have a problem in Error Code. The Error code is E000000-0000. Please tell me how to solve this problem. my e-mail id is: mcpx_vpy@sify.com
There is a problem in the fuser area of the copier. For some reason the fuser is not heating to the proper temperature. There are several possible causes such as a failing/failed thermistor (this is a heat sensor device that monitors the fuser's temperature) or a thermal switch (this is a device that, based on the current value of the thermistor, either turns on the heating unit or turns off the heating unit) or the heating element itself could be bad, etc etc etc
Unless you are a technician with extensive Xerox experience I will advise you to contact Xerox about tech support.
Oct 07, 2009 | Canon Office Equipment & Supplies
Jam 01-009 code from my Samsung SCX-6345. It always jam at the fuser unit please help.. thanks..
Probably have a scrap paper stuck in the fuser or a "stripper finger" out of place, catching the paper. You'll need to remove the fuser to get a good look at things.
Aug 04, 2009 | Samsung SCX-6345N Laser Printer
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Sharp Copier AR-C270 Code Problem
sir there is no code of HS may be it is other code H4 or H2 so please write correct code
Oct 06, 2007 | Sharp AR-C270 Color Copier
HP LaserJet 3600n Printer Logo
Seeker5211
Seeker5211
