Question about Neff K4664 Top Freezer Refrigerator
Neff fridge fd8309 k4664x1gb1 how to attach new latch to freezer part of fridge
  • 143 Answers
SOURCE: Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Posted on Jul 23, 2008
tborn6
  • 700 Answers
SOURCE: how do i switch off freezer part of neff american fridge freezer?
turn off the thermostat on the freezer and the refrigerator and that should shut it all down.
Posted on Apr 03, 2009
  • 5 Answers
SOURCE: Neff K9724 Fridge Freezer with water in the fridge drawers
sounds like a thermastat problem or maybe your drain away hole is blocked
Posted on Apr 25, 2009
  • 3 Answers
SOURCE: Neff fridge freezer K4664 broken door handle
Go and find your frig paper work there are areas with parts and how to order them
Posted on May 13, 2009
iwillfixforu
  • 619 Answers
SOURCE: Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Posted on Feb 04, 2010
Neff integrated fridge freezer. Intermittent fault. Sounds like compressor jerking on and off
Possible cause is start/run capacitor faulty.Do not run fridge please get a tech to confirm problem.
Jan 17, 2016 | Neff Refrigerators
Neff K3965 side-by-side American: Freezer works but Fridge doesn't any more, 3 days after defrost
Can you remove the freezer rear panel again and take some photos of the frost pattern so I may see what is stopping the cold airflow to the fresh food section?I'm here on Fixya if you have questions
Contact Me Here
Appliance 911 Sea Breeze
Nov 23, 2015 | Neff Refrigerators
Neff Fridge Freezer K3965 Freezer is working but the fridge is not
This is either a defrost problem or the evaporator fan is not running. The way to check is to open the freezer and do two things. Listen to see if the fan is running, if not and you hear the compressor in the back going then the fan is the problem. If the fan is running then look at the freezer wall and see if it is covered in frost. If so, you have a defrost system failure and either the timer, bi-metal or the defrost heater has gone bad.
Sep 05, 2012 | Neff K3965XO Side by Side Refrigerator
NEFF K4663 fridge. the freezer works ok but refrigerator space does not go below 9deg C even at highest setting. have defrosted and water drain is clear.
The defrost board is not functioning properly.;
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 4 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Jan 31, 2011 | Neff Refrigerators
Feb 04, 2010 | Refrigerators
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
May 13, 2009 | Neff K4664 Top Freezer Refrigerator
Jul 23, 2008 | Refrigerators
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Neff K4664 Top Freezer Refrigerator Logo
Top Neff Refrigerators Experts
John Tripp
John Tripp
richie46
Rabbit Brains
Rabbit Brains
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
