Question about Samsung SGH-L700 Cell Phone
If i connect my mobile to my laptop it was showing that the phone was not connected in the pc suite menu. what i have to do?
  • 10,421 Answers
5 Suggested Answers
SOURCE: I have C5212 Samsung Mobile Phone. I am connecting
there are times when the pc suite comes bundle with phone does not work;windows vista usually have this problem ;download the lastest version,here is the link
http://downloadcenter.samsung.com/content/SW/200902/20090227100255781/New_PC_STUDIO_1.0.0_IA1.exe
and check out
let me know if this is helpful
Posted on Dec 05, 2009
Testimonial: "Thanks. "
vanherringto
  • 1738 Answers
SOURCE: Motorola PC suite
Here is the link for the USB Drivers:
http://www.motorola.com/consumers/v/index.jsp?vgnextoid=bda09ec8009a0210VgnVCM1000008806b00aRCRD
Here is the link for the Motorola Phone Tools Utility:
http://lfiles3.brothersoft.com/internet/mobile/Motorola_mobile_phone_tools4.5.1.zip
Please give me a big thumbs up when you rate my answer. Thanks!
Posted on Jan 27, 2010
muntejaya
  • 10421 Answers
SOURCE: WHERE TO DOWNLOAD PC SUITE FOR MY LG GW300 MOBILE
Hi, Please download it here : www.brothersoft.com/downloads/mobile-phone-pc-suite.html
Posted on Feb 06, 2011
How to download video from phone to computer
Your mobile phone needs to be set to PC Suite mode, located in the "Connectivity" menu. Once that has been done and connected to your PC using usb cable, the PC Suite will launch. When it does, it will show the model of the handset and will be able to synch with your mobile handset. Other solution is by using bluetooth if your PC comes with bluetooth.
Jul 05, 2012 | LG KG800 Cellular Phone
I have pc suit cd & i have installed it but when i stat to connect my lg gm200, it shows cannot connect device note. so how can i connect my lggm200 with pc?
hi
after connecting into your PC then go to settings menu and select the connectivity setting in your mobile. there there will be option that to choose data storage or PC suite. then change to a PC suit option in your bile.. this will fix your problem.
thank you
Dec 22, 2010 | LG GM200 Cell Phone
I want to transfer some songs from comtputer to my mobile i hav joined the cable but it isnt showing corbys sign in the computer
Make sure that your mobile is having memory card inside it and is working fine.
Install the s/w came in a cd with your mobile phone.
Just connect your mobile to cable and them to computer. If anything is prompted on the mobile screen, select file transfer/ storage / mass storage mode ( may vary and if applicable).
you should be getting some extra drives in My computer, just like c:, etc using which you can access the files present in your mobile phone and can transfer the files to your mobile.
I hope this is helpful to you. Please rate
Jun 23, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
How to ACESS INERNET TO LAPTOP THROUGHT MOBILE
First of all you will need to have settings save to your phone sent to you by your phone provider. If your phone can access the web, then that means your phone already have the settings for surfing the net.
Secondly, you will need pc suit software or any other mobile suit software compatible for your phone. Install the software to your pc..
Third, you must specify the mode of connection that you want for your phone and pc.. If you will be connecting your phone to your pc via blutooth... then you will need blutooth device installed and connected to your cpu.... If you will be connecting via usb data cable.. then you will need driver installed for your data cable.
Fourth, on control menu.. double click Phone and Modem.. Install your phone as your modem.
Lastly, If all is done.. run your pc suit... pair your phone to your computer.. Access dial up via phone modem... and there you go.. just make sure your phone is loaded so the connection wont stop..
Good luck.
Much appreciated if you rate this help. thanks.
May 21, 2010 | Computers & Internet
Connection error to link phone to pc
hi 1st of all, reinstall the LG Pcsuite software, once that is done, you will see that a usb modem driver is also installed at the end of the process of installing the LG Pcsuite.
If you disconnect the usb cable from your mobile, then..
on your mobile go into the menu, then phone settings, then connectivity, there you will see USB connection mode.
If you click on USB connection mode you will see 3 options..
Data service, if selected tells your mobile to act as a modem when attached to your computer\
Mass Storage, if you select this option and then plug your usb cable back into your mobile, your computer will then discover your mobile phone as an external hard drive that will show up within Windows "My Computer", you are then able to browse your SD Micro memory card as an external hard drive and copy your files to your computer as simply as from one drive to another.
Remember if you want to use your phone again as a modem to go back to the USB connection mode menu and reselect Data Service.
Hope that helps
Sep 26, 2009 | LG KU990 Viewty
I want to install "GO BIBLE" software into LG kc910 renior mobile
My brother does the same thing with his phone. To get it to install you probably need to turn off the certificate check settings!
Go into menu > tools > settings > applications > app.manager
Turn software installation to "all "and online certificate check to "off",
This should allow you to use any app that hasn't been digitally signed.
If you still can't get it to work, it might not be able to work with your phone. But you also might want to call your phone company for the best results.
Mar 19, 2009 | LG KC910 Renoir Cell Phone
Cant get my pictures onto my laptop
You need LG PC Suite 2 (it is on CD which comes together with phone). Or if you don't whant to install it, go to Menu, Settings, Connectivity, USB Connection mode and select Mass Storage. I prefer using LG PC Suite 2, because than you can connect through a bluetooth and don't need a USB cable everytime.
Mar 16, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Need to connect mobile mointer for k700i
Go to Device Manager/Ports(Com&LPT) and see what ports BlueTooth had enabled. Use one of this in pc suite settings.
Usualy pc suite use port 40 or 41. Try to enable one of this.
Oct 16, 2007 | Sony Ericsson K700i Cellular Phone
Samsung SGH-L700 Cell Phone Logo
26 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
