Question about Acer Aspire 3000 Notebook
My guitar strings are out of tune. can somebody tell how to fix it/
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 146 Answers
Download guitar tuner from below link
http://www.guitarforbeginners.com/onlinetuner.html
start from lowest string, tight it one thread at a time and with pick make sound, when guitar tuner sound from speaker and ur guitar make resonance, tune the upper one, repeat it for all and you are done
cheers!
Posted on Sep 08, 2010
Testimonial: "it work well. i need practice but it working good. you coach? where u are ? in fl?"
What are the tune r numbers
For 6 STRING GUITARS, tune strings in
ASCENDING ORDER: Target Hz
For 6 string guitars. Tune in ascending order
First LOW E . . . . . . . . . . . . . . . . . 82.4
Second A . . . . . . . . . . . . . . . . . 110.0
Third D. . . . . . . . . . . . . . . . . . . 146.8
Fourth G. . . . . . . . . . . . . . . . . . 196.0
Fifth B . . . . . . . . . . . . . . . . . . . 246.9
Sixth HIGH E. . . . . . . . . . . . . . . 329.6
For 4-5 string BASS GUITARS, tune strings in
DESCENDING ORDER: Target Hz
For 4 and 5 string Bass Guitars
First G . . . . . . . . . . . . . . . . . . . . . 98.0
Second D. . . . . . . . . . . . . . . . . . . 73.4
Third A. . . . . . . . . . . . . . . . . . . . . 55.0
Fourth E. . . . . . . . . . . . . . . . . . . . 41.2
Fifth B (if 5 string) . . . . . . . . . . . 30.95
The manuals are here.
http://www.snarktuners.com/contact-service
Jan 16, 2016 | Snark Clip-On Guitar & Bass Tuner
How do i adjust intonation on a peavey predator plus exp?
To adjust the intonation on a guitar you need the following. ..
a electronic tuner
and a small philip screwdriver
when you tune a string say low E you play the note open and adjust tell it's in tune
then to intonate play the low E at the 12th fret
producing a Harmonic, view the tuner it will be sharp or flat,
turn the small philip screw on the bridge adjustment
it only takes a small turn one way or the other so go slow
once the string is tuned at the harmonic note check to see if it's in tune played open, keep tuning and adjusting tell the strings are in tune open and at the 12th fret on all six strings
once intonation is set properly the guitar will sound better
really hope that helps?
Mar 15, 2015 | Peavey Music
HOW DO I TUNE A KRAMER GUITAR
Without seeing your guitar, I'm going to assume the "tightening lugs" you're reffering to are the string locks on the nut. On a guitar with a "floyd rose" style tremolo system, the strings pass through a clamping system at the nut before going to the normal tuning keys. This clamping system "lugs" must be loosened then the guitar is tuned as it normally would, then the lugs are tightened to lock the strings in place. These clamps are not part of the tuning mechanism, but instead lock down the strings after they have been tuned by the keys. After all that, one would fine tune the guitar at the bridge rather than at the keys. A more complete explaination is found here-
String Tuning Instructions
Feb 17, 2015 | Kramer Music
My 3rd guitar string sounds bad
Get it a repare at guitar center they have a pack of guitar strings for 5-10 Dollers they are located in Oregon Washington cailfoina if you relly want a cheep guitar that sounds good get bc rich or finder or eipcphone your guitar strings are probley getting old you have to buy a certain brad of stings that well last a year and if you need tuneing you can download an app for online tuning or you can type in online guitar tuneing I hoped this helped give me a message if you need more
Nov 25, 2012 | Dean Guitars Dean Ml Xm Electric Guitar
Is he tuner supposed to light up green when the string is correctly tuned?
Before turning the unit on, press and hold down the calib/batt switch to check the condition of the battery on the battery meter.
Then either plug in your electric guitar to the input side of the AG-6 or if tuning an acoustic guitar without electronics placing the AG-6 near the front of the guitar should work. You will not need to press a button to select which string you are about to tune. The AG-6 will detect it and the corresponding light will turn on when it is tuned within range.
Turn on the AG-6 and start by striking the low E (thickest) string while open. This is the number 6 string or 6E. Slowly turn the guitars low E tuning key untill the red LED below the 6E marking on the AG-6 lights up. Continue stricking the open string and turning the key untill the needle centers on zero and the 6E light remains on.
Repeat this for the open A string untill the 5A light turns on and the needle centers on zero.
Repeat for the remaining four strings, 4D 3G 2B and 1E, being careful not to over tighten and break them.
Tip: It may be a good idea once the low E string is tuned, to tune the rest manually, especially new strings or strings way out of tune. Then tune again using the AG-6 tuner.
If installing fresh strings you will probably need to stretch each string and re-tune, possibly several times, before they hold their tuning.
Feb 19, 2011 | Fender AG6 Automatic Guitar Tuner
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
I just got this guitar. I pull the tuner control, strum the string and after the guitar tune itself, the G string still out of tune??
Are you sure you are struming the G string at the right point? One might be able to fool the tuner by triggering a harmonic on the strings or being too aggressive in the strum.
I would pull the peg and see if the string CAN be tuned manually. It is possible the G string is bad or somebody put the wrong string on there.
Remember that strings can be within about 10% of the breaking tension when in tune.
Also it appears that the thing can detune itself to nearby keys. Make sure you have the dial set correct when you pull it out to tune.
Feb 05, 2010 | Gibson Robot SG Special LTD Ebony
"G" string tunning problems,
hi there .... flat means does the string go lower in pitch ...needing the string to be tightend after you have bent it ?
Do you give the strings a real good pull a few times after fitting? this often corrects the problem .... let me know ..as there could be a few other reasons
cheers Pete
Feb 02, 2009 | Epiphone Les Paul 100 Electric Guitar
LP epiphone 100 "g" string problem,
after tuning ....put a capo on ... if this stops the problem then the cause must either be
1 the string catching in the top nut or
2 a faulty machine head
if it still goes out of tune with the capo on then look at where the ball end of the string sits
Guitar strings on a mandolin.
Looking at your desired notes the mandolin is standard tuned to gdae.
So three of the four notes are already available, just put the "d" mando strings where the "g" ones would go and the "g" ones where the "D" ones would go the highest is already a "e" and I am sure the "a" would tune up to a "B" with little risk.
You can also
look at string sets made for the madochello or possbly octave mandolin.
Good luck,
The dude.
Aug 07, 2008 | Johnson Ma100 Lynchburg Mandolin
Acer Aspire 3000 Notebook Logo
57 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
