Question about Kenmore Dryers
Have Kenmore electric dryer that works normal but does not get hot.
    Problem Solver:
  • 5 Answers
Check the electric coil spring. It may be burned open. If so then twist the two half together. Sometimes coins or other objects land on the coil and burn it open
Posted on Sep 09, 2010
My kenmore elite electric dryer wont get hot
The motor works on 120 volts the heater is what requires 240. I bet you have an electrical problem
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 12, 2012 | Kenmore 400 6942 Dryer
Kenmore electric dryer got really hot and stopped working?
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 19, 2011 | GE DVL223EBWW Electric Dryer
Is it normal for the cabinet to be hot to the touch?
Yes, it will be hot... but check out this tip that will help you to keep your dryer running efficiently...
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
Apr 15, 2010 | Kenmore 62872 Electric Dryer
Dry take hours to dry
need to check hi limit thermostat on element make sure it is not cycling to soon
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Dryer working but not blowing hot air
Either bad thermal cutoff or bad element .( first 3 numbers missing on model #)
Jul 05, 2009 | Kenmore 800 6983 Electric Dryer
Kenmore 64672 dryer gets hot but clothes still wet
you have a clogged wall vent or clogged dryer vent or a clogged lint trap,you are trapping all the hot wet air in the dryer and that's why it's taking so lont to dry-mike
Apr 22, 2009 | Kenmore 64672 Electric Dryer
Kenmore dryer
Probably too late to help either of you since this is so old but there are two possibilities (assuming everything else works as normal).
1st
If you really mean the circuit breaker to your house, then the heating element is bad and pulling too many amps. It may be shorting out when it gets hot due to the expansion of metal.
2nd
If you mean a switch on (or in) the dryer then you mean a thermal breaker (or thermal fuse). The most likely problem is that the exhaust vent for the dryer is plugged up with lint either within the dryer itself or in the part that is in your wall and exits someplace outside (could be as far as the roof). When the hot air can't escape the dryer overheats and shuts off to prevent a fire.
Jan 07, 2008 | Kenmore 659 Electric Dryer
KENMORE DRYER
Electric or gas?
Sep 13, 2007 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
