Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Hard drive is trying to start up, but then clicking noise starts and it shuts down, computer does not recognize it
  • Western Digital Master
  • 27,725 Answers
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
as for the clicking
a dirty hard first clean all of the dust from your computer using a fine air blower from an air compressor making sure there is no moisture in the air line then give the hard drive a firm tap on one side to free up the read arm
hope this helps
good luck
Posted on Sep 08, 2010
  • First make sure usb cable connected to harddrive is working fine.
    try it in different usb ports.
    Press windows key R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
    then check.
    Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
    And remove upper filter and lower filter.Then restart computer then check.
    Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
    Let me know if you need further assistance.
    Thanks for using FixYa
  • Brian Sullivan
    Brian Sullivan Sep 08, 2010
    Fist clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making sure there is no moisture in the air line
    as dust will cause a lot of static which will make a computer overheat and cause lots of problems
    then test your power supply unit PSU
    try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive one bad lead will cause a computer to shut down
    make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
    then you have a dirty hard first clean all of the dust from your computer using a fine air blower from an air compressor making sure there is no moisture in the air line then give the hard drive a firm tap on one side to free up the read arm
    then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
    you have to keep a computer very clean & free of dust and give it regular maintanance
    good luck with this
Western digital 2tb my passport keeps flashing; not detected
Remove the drive from the external case it is in and connect directly to your computer - see if the bios recognizes it. If so, the OS will do so also and you can access it. Also means the electronics of the external case are no good. If not recognized in other machine, the hard drive has gone to hard drive heaven and needs to be replaced.
Sep 08, 2017 | Western Digital Computers & Internet
While I'm watching movies on my hard drive it stops working. Does this mean that it is on it's way out? It is only about a year and a half old. Can someone please help me
Hello :)
Does the harddrive make any noise before shutting down? A clicking/ticking noise maybe? When did this problem start?
But before you replace the harddrive, try another SATA/IDE cable. You could also try another power supply, if you have one available.
Just to be sure you could also run a few malware programs like Malwarebytes and/or scan your computer with an antivirus program.
I had to replace two harddrives last year and they both had this clicking noise before shutting down completely.
Aug 02, 2013 | Computers & Internet
Imation 1TB USB external Hard Drive .....unrecognized in Windows Both in windows7 and XP.
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected. Hope this helps.
Jan 07, 2013 | Imation 1TB Cartridge (IMN27957) Hard...
The unit fall down, I picked it up and connected it inmediately to the computer to see if it was still working all right. The computer recognized it and I was able to see the folders, but it started to...
It sounds like you have damaged the hard drive. The method to recover the data involves sending the drive to a data recovery specialist who will dismantle the drive in a clean room.
Data recovery is a very expensive process and is not guaranteed to be successful. Look on google for a data recovery company in your country.
Jul 24, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
Hello I have a Toshiba canvio 3.0 external hard drive and up until today it was working perfectly fine this morning I turned on my HP dv7 and the external hard drive can not be recognized on my...
Hi kwooz109,
To fix the External HDD.
Take these steps.
First, click to open the Computer, on your "Desktop Screen"
In the (right, shortcut menu), select to open the Computer, by {right} clicking on it.
paul7of9_114.jpg Check to see if there's a External Hard Drive 'letter ie; [F:] ?
  • If the area is (Blank)?
  • Go to, and select the Control Panel, by clicking on the Start Button. paul7of9_115.jpg
  • Scroll to find: the"Hardware and Sound category, and click on it to open.
  • Next, select the "Device Manager."
paul7of9_116.jpg In the [Device Manager]; check to see: if there is a [Disk Drive] Icon?
  • You need to "Update the Drivers."
  • Open the "Disk Drive" by {2x clicking} on it.
  • Select the {Driver Button}, click on it to 'start the update.'
  • Follow all the instructions!
  • Click on the Apply and OK buttons when finished!"
  • Restart the Computer, to finish!"
!Attention: If 'problem still exist?
  • "Perform a "System Restore!"
{Start Button -> All Programs -> Accessories -> System Tools -> System Restore}
  • "Choose; most [Recent Restore Point] ie: Ext. HDD not' recognized!"
"Please let me know if you 'need' further assistance; by posting a "Comment 'or' Rating the Solution." Thanks, your 'response' is important!"
paul7of9
Mar 06, 2011 | Toshiba Canvio 750 GB USB 20 Portable...
Computer will not boot up. Goes to blank screen with cursor flashing in left hand corner.
When this happens, you either have a hardware or bios problem. First thing to try is to start your computer and hit the F2 key to go into setup. This will be your BIOS, or Basic Input and Output Settings. You can go thru the tabs and see if you hard drive is recognized. Look under IDE configuration. If your hard drive is listed properly, then you motherboard is seeing your hard drive.
Then, go to the tab on the far right and look for reset bios or load system defaults. Sometimes, this will help you get by this problem.
If this does not make any changes, start your comptuer and hit the F8 key this time. This should give you a menu including start in safe mode, start in Last known good configuration. Try selecting last known good configuration and see if this works. If not, try starting in Safe mode.
IF none of this will work, then you probably have a hardware problem. Shut your computer down and open your case. Unplug every drive EXCEPT the hard drive. Try to start the computer. If this works, the shut the computer down and plug in one drive as a time until th computer will not start again. When this happens, you have found the bad drive. A CD or Floppy drive that goes bad will sometimes stop the computer from starting.
Try these suggestions and see if you can get past this. If you find this provides a solution for you, please remember to leave positive feedback for me.
Thank You,
Brian
Jan 29, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computer does not recognize external hard drive, western dig 320 g. It has been making clicking noises before it started this problem.
Clicking noises are not an issue, as the hard drive uses voice coil technology, which clicks. Plug into another USB drive.
Jan 22, 2011 | Western Digital My Book Essential Edition...
1TB external hard drive has started to make load whirring and clicking noises that have not been heard before. It shuts down computer when connected so therefore cannot access files! The base serial no. is...
hi Ivandbafc.
this is what i have found out.
If your hard drive is displaying any of these symptoms it is important to stop using your drive immediately, Ongoing use of a drive with these symptoms will result in irrecoverable damage being caused to the media.
  • Hard drive producing a clicking sound.
  • Hard drive producing a clunking sounds.
  • Hard drive making buzzing sounds.
  • Hard drive making a grinding sound.
  • Its best you try and save all data to another drive asap.
Nov 27, 2017 | Buffalo Technology Computers & Internet
Iomega Ego USB is not being detected by any computer I plug it in
Your drive is a coaster. Iomega products seem to be made out of tissue paper and mucilage. You are lucky that it worked for any amount of time at all and wasn't dead right out of the box. Have you tried their online-only tech support? (You can call them for $25 if you want to.)
Jun 16, 2009 | Iomega 160GB Ego HD USB 2.0/FW Red 160 GB...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
160 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
