Question about Bosch & Tankless LP Hot Water Heater
The off button on my bosch hot water service want pop back out So nothing is happening and I can't relight the pilot light??
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
Turn the Gas off at the main supply to the unit and contact Bosch ASAP. Do not try and refire the unit.
Posted on Sep 08, 2010
Wher is pilot light
Why will my pilot light on the gas water heater not stay lit for ...
diy.stackexchange.com/questions/.../why-will-my-pilot-light-on-the-gas-...
Jul 28, 2011 - The pilot light went out on my gas water heater. I followed the ... This could be from a valve not being all the way open. It could also be from a ...
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
How to Light a Water Heater (with Pictures) - wikiHow
www.wikihow.com/Light-a-Water-Heater
wikiHowJump to Questions and Answers - If the pilot light doesn't relight or goes out immediately after ... if you are unable to light the water heater after several attempts.
Jan 13, 2016 | Water Heaters
Bosch 10p hot water system off button wont pop out!
Wiggle the button while pushing and releasing, maybe it's caught on the casing it's in.
Jun 13, 2012 | Water Heaters
I have a Bosch 10P water heater. Pilot light has blown out and while trying to relight the pilot the stop button has been pushed down and won't pop back out. What am i doing wrong? Cheers
What leads you to suspect that pilot blew out instead of another problem?
Fact that pilot will not relight, indicates other factors at play.
Open following link for Bosch troubleshooting resources including manual, and Bosch contact info:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Best place to start is your manual.
http://waterheatertimer.org/pdf/Bosch_10P-installation.pdf
1) Manual recommends 'cleaning by authorized person, never less than once a year.'
Tankless water heaters, and most newer tank-type gas water heaters, are highly technical and finicky devices that require continual maintenance, with tankless requiring 'yearly' maintenance while tank-type require 'periodic' maintenance.
2) Troubleshoot in manual says 'no gas supply' or 'blocked pilot' replace pilot injector
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 21, 2011 | Bosch & Tankless LP Hot Water Heater
When the wind blows the pilot light out, I have great difficulty in pressing the buttons in to relight it.
You are getting negative pressure in the burner ... this can be caused by the access panel not being reinstalled properly after you relight the pilot. Vents can cause a "venturi effect" and if the access door is not on tight it will indeed become a real pain
Feb 18, 2011 | Bosch & Tankless LP Hot Water Heater
Pilot light will not stay on Bosch natural gas tankless water hea
Check to make sure the flame of the pilot is hitting the thermocoupling. If not then you can use compressed air to clean the pilot port and relight and check again. If the flame is hitting the thermocouple, then it may need to be replaced.
May 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Have replaced to thermal coup.s and still cant keep the gas lit on mine? must relight it every time i need hot water, have had a tech out twice its now 2 yrs old and were still relighting the thing. no...
make sure coupling is in the flame and is mounted securely at all points.. and that it is tighten tight to gas valve..after that it could be the gas valve???
Mar 20, 2010 | Bosch & Tankless LP Hot Water Heater
Pilot light went out but will can,t get it relit it only stays on as long as I hold the button down
Is the thermocouple in the pilot flame? & does it get hot [glow red] If not adjust position until it does & make sure it's clean
If thermocouple gets hot but no relight, replace couple
Oct 26, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Pilot light gone out. How do I relight? Which
In general, large button from gas valve push in & hold 20-30 secs at same time push electronic lighter/ignition button to light pilot. Remember to hold in only gas button. the pilot light heats up a thermo couple [u can see this in the flame] and when hot enough allows the main gas through and the pilot to remain on.
If not then either thermo couple not heated for long enough or
it may need replacing
Oct 22, 2009 | Bosch Water Heaters
Pilot blows out on n.g. tankless water heater when it's windy
There are many anti-back-draft systems on the market, but there may be only a few that could possibly be Incorporated in to your application. You might contact the manufacturer for their product list of, flue pipe anti-back-draft devices.
Good luck...
Feb 22, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Tankless water heater pilot light will not stay on
It is most likely the water valve stuck open, telling the controls to heat water, that it thinks is flowing through it, but without actual flow it overheats. Depending on how comfortable you are with taking it apart yourself, you could open the valve to see if it just needs cleaned out, or if you have a ruptured diaphragm or some other cause.
Jan 25, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Bosch & Tankless LP Hot Water Heater  Logo
202 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
