Question about Maytag Washing Machines
Hi, I have a Maytag washing machine that will not fill with water. The problem is intermittent, but it fails to fill more often than not. I have good water flow to the machine, and it does not seem to matter if the water level or temperature adjustments are at different settings. I would like to fix it possible, as the unit is only two years old. Any ideas? Thank you. -Dan
  • Maytag Master
  • 909 Answers
Hello Dan, quite a few options to this problem, but my first impression is to switch the water off, clean the sieve in the valve inlet then open the back of the washer, to locate the pressure switch pipe.(It is a 1/4" diam and is clear in colour.).Make sure plug is pulled out of socket. Where the pipe connects onto the actual pressure switch, pull it off and then blow hard into the pipe.(the other end goes to the outer tub.) I think you have a partial blockage at the drum side. You will feel a resistence if it is blocked then all of a sudden it will be free. Put back together and retry.
Posted on Sep 08, 2010
Hot water not coming into washing machine
The solenoid valve that lets hot water into unit is not opening. Check out the valve itself and the timer cam that feeds power to the cam.
Jul 04, 2015 | Maytag Washing Machines
Cold water will not fill
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 27, 2011 | Maytag Washing Machines
Water won't stop running in at end of cycle, keeps filling up and overflows
This is symptomatic of an intermittent water control valve- sometimes closes too soon (its physical fail position is closed) or sticks open too long.
It needs replacing! Service call ;-0(
Good luck,
John C
Mar 16, 2011 | Maytag Atlantis MAV6000 Top Load Washer
My maytag lat8214aae will not fill up with water
heatman101
Feb 09, 2011 | Maytag Washing Machines
Will not fill with water
heatman101
Jan 29, 2011 | Maytag Washing Machines
MAYTAG NEPTUNE TOP LOAD DOES NOT FILL TUB WITH WATER HEAR NOISE BUT NO WATER AND STOPS AND 24 MIN QUICK WASH CYCLE, NOT SURE WHERE TO START.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
heatman101
Sep 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag LAT9400 top loading washer has stopped allowing hot water to enter the tub, only cold water works. What might be wrong?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 06, 2010 | Maytag Washing Machines
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer will stop working and
HI, this error code is signaling an issue with the fill actions. Your washer seems to be having problems when it try's to fill the tub with water.
First, make sure there's water getting to the washing machine. Make sure the water faucets are open all the way.Check for kinked hoses as well.
If the hoses are fine and, the faucets are fully open, this will confirm a inlet water valve malfunction. you will need to replace this failed component in this case. it has failed.
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fills with Water but, that is it
If a machine spins and drains, but won't agitate, that sounds like a timer control problem. Wires can come loose or burn up, but that's not as common as a failed contact. If the machine won't agitate or spin, that could be a lid switch problem, which is real easy to fix.
Mar 25, 2009 | Maytag LAT3600A Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
