Question about Dell TrueMobile 1184 Wireless Broadband Router (802.11b) 9U555 (9U555)
I changed from bellsouth to comcast as my internet provider - the comcast tech disconnected my router, saying I didn't need one. Now my tivo can't connect to my computer - I need to reinstall and configure my router
  • 385 Answers
Actually, he did so because they don't "support" anyone else's equipment. once he verified your connection with them that way, he left. an easy solution would be to reconnect your router back into your system just like it was before. reboot everything, and everything should work just like before, including tivo.
Posted on Sep 08, 2010
What is Comcast phone number for help
Hello......
We provide the best Comcast Tech Support Phone Number
for issues related to internet, email, modems, and routers. For 24 7 tech support, call us on 1(877)-649-6892 and get toll free help. We have a well-certified technician that will certainly give you a desired & an appropriate solution. Also, you can visit Comcast Chat Support and get best technical support.
For another query visit here:
Comcast Supported Routers
Comcast Technical Support 24 7
Comcast Supported Modems
Comcast Support Chat
Dec 28, 2017 | Comcast Computers & Internet
How do I get my Zonet Router to play nice with my Motorola Modem and Comcast Connection?
If this types of issues again again then may be some technical Fault.
A> Your Network connectivity Not Good or loose.
B> Your IP Add or mac Add change or conflict.
C> Your Modem or router not proper connectivity establish.
D> Contact network ISP provider or ask some issues.
E> If possible check it loose connectivity and connection.
If not solved contact Network Support Technician.
http://setuprouter.com/router/zonet/zsr4154we/manual-915.pdf
Linksys Support Phone Number
Thanks,
Sep 05, 2014 | Zonet ZSR4134WE Wireless Router
Connecting MacBook or NetGear Router to Comcast
As a Comcast tech I assure you there are no special protocols used on a standard residential installation. There should have been nothing the tech downloaded to your pc most especially an executable file. I would assume he or she was making sure you were able to get to the customer installation page before they left. However if you have a router that the ports are not functioning on you are most welcome to have one shipped to your home for replacement. The wifi key provided on the bottom of the router is case sensitive most generally all in caps. If you dont have a spare cat5/6 cord to see if thats the issue ask them to send one with the new modem. Comcast does not charge you a fee for a truck roll when its faulty eqt. of their own. I have installed hundreds of apple products including the ones you are referring to as well as netgear routers they all work with the gateway Comcast provides the customer. Now if you want there is a tiny factory reset pin button at the very top of the gateway in the back you will need a paper clip to push it in. Hold it in there about 10-15 seconds and the gateway will reboot and return its setting to factory spec. try that first before calling customer service.
Jan 07, 2013 | Comcast XFINITY
Internet status light on netgear wireless n300 blinking. internet service on and off. 2 macs in house.
You can do a reset on the router to make a factory settings.On the back of the router you can look for a small hole usually with the word reset.Press it for 20 secs with the router on but disconnected from the Ethernet cable.Start up your PC and surf to the router Web UI (192.168.***) and make your settings.
May 26, 2012 | NetGear WNR2000 Wireless Router
Moved router to connect directly to the Comcast modem that also provides VOIP. Comcast activated modem and internet works when computer is connected directly to Comcast modem. Router does not connect to...
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Tivo says that a list of ports have to be open on
Easy done man, use these steps.
Start>Run>Cmd
Type: ipconfig
a list of numbers should come up. After that, open up your web browser. Look for the number that comes after "Default Gateway"
Enter that into your web browser. It will take you to a page that might ask for a password. Try "admin"
From there you go to basic settings and there should be spots for you to add ports acceptations.
Add them then "apply" or "save" the settings.
After that it will ask you to reboot for the changes to be saved. Do that and you should be good to go man. Good luck.
Jul 10, 2009 | Blitzz Technology (BWA611) Router
Set to work with centurytel instead of bell south
Howdy - You may have a two fold problem here. First of all the Westell wireless modem/router 327w has the access IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. That problem solved...
Now, from what I understand, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
This is the page link:
http://www.dslreports.com/faq/bellsouth/3.141_Westell_327W__wireless__Info#13772
This is the relevant quote:
"The BellSouth supplied 327W (model C90-327W30-06) is made exclusively for BellSouth FastAccess. They are functionally different from retail Westells (or any model designed for use with other ISPs) and the firmware between them are not compatible and can not be interchanged."
That being said, you still might attempt to use this 327W with centurytel but I do not know if it will work. I use the Bellsouth 327W and it is GREAT. Good luck.
P.S. - Please be advised that Westell does manufacture an identical 327W that does NOT have the Bellsouth/ATT firmware.installed. This is the "generic" version I suppose but I have no experience with this one. If you need more just ask. :)
May 29, 2009 | Westell Wirespeed VersaLink...
AT&T FastAccess DSL & D-Link not working for me
Yes D-link is compatible with DSL. What you need to do is call your ISP and have them bridge your DSL modem. Next you need to verify your username and password for your internet account. Next call d-link and have them help you change your router's setting to work with PPPoE connections.
Sep 11, 2008 | D-Link DI 514 Wireless Router (DI-514)
Dell TrueMobile 1184 Wireless Broadband Router (802.11b) 9U555 (9U555) Logo
54 people viewed this question
Alun Cox
