Question about Lexmark X1270 All-In-One InkJet Printer
Hi. I am trying to install a new black ink cartridge, which I think I am doing successfully. i pop in the box and snap the top down (having removed the tape also!) but when I come to ask it to print, it says "A PRINTER CARTRIDGE IS MISSING". Now, i have no colour one in, is this why? but i dont need colour. Am i putting it in correctly?
SOURCE: color cartridge missing
The error 50c
Posted on Jan 15, 2007
vegakitten20
  • 685 Answers
SOURCE: Lexmark x2650 printer not responding to new cartridge
yes you have to have both of them then everything should be fine.if you have the color cartridge that is empty put it in for now and see if it will work it will let u know that it is empty but at least you will be able to print in black
Posted on Jan 04, 2009
  • 29 Answers
SOURCE: Missing Black Cartridge
hi..try these steps
1. clean the cartridge contacts in the printer..
2.unplug power adaptor(black box) from the bac of printer,,press and hold stop/clear button..plug the adaptor back in...display says clearing NVRAM,,,,after this printer would turn off and turn on automatically..reenter the intial set up details like language,country....
3.insert black cartridge...still same msg..printer is defective...call techsupport..your printer would be replaced if in warranty.
good luck
Posted on Jan 25, 2009
CW Oly
  • 240 Answers
SOURCE: refilled black cartridge 36 on my 5650 won't work
The cartridge is electronically dead. This is a common occurrence from improper refilling. To be correctly refilled it must be done under a vacuum to prevent air from entering the print head, which has likely happened. As ink flows through the print head it acts as coolant in an engine, when air is introduced the print head cannot cool, over heats, and ruins the cartridge. These cartridges are difficult enough for us professionals to refill successfully, my recommendation is to leave it to us, or buy original. A refilled integrated print head cartridge will always continue to read as empty because there is no way to reset the cartridge, the manufactures do this on purpose. Lexmark cartridges in general are designed to only last one cycle anyways, multiple refills is attained only with proper technique.
Posted on Feb 02, 2010
SOURCE: Is it possible to refill ink cartridge on Lexmark x6690 printer?
Take out all cartridges, switch printer off and then on again and let printer see that there are no cartridges. Do this 5 times, it resets the cartridges. Then install refilled cartridges
Posted on Dec 27, 2011
How do I replace ink jet in officejet 4500
Step one: Remove the old cartridges
1. Press the power button to turn on the product
2. Open the front access door. The carriage moves to the far right side of the product
3. Wait until the carriage is idle and silent, and then lightly press down on the cartridge to release it.
To replace the tri-color cartridge, remove the cartridge from the slot on the left.
To replace the black cartridge, remove the cartridge from the slot on the right.
Pull the cartridge toward you out of its slot.
Step two: Install the new cartridges
1. Remove the new cartridge from its packaging. Be careful to touch only the black plastic.
2. Gently remove the plastic tape by pulling the pink pull tab
3. Hold the cartridge with the HP logo on top, and insert the new cartridge into the empty cartridge slot. Make sure you push the cartridge in firmly until it snaps into place.
If you are installing the tri-color cartridge, slide it into the left slot.
If you are installing a black cartridge, slide it into the right slot.
4. Close the front access door.
May 27, 2013 | HEWLETT-PACKARD Officejet 4500 All-in-One...
Need to replace ink cartridge and I forget how to replace ink cartridge
1. Remove the black ink cartridge from its bag.
2. Carefully remove and discard the orange cap.
Handle ink cartridges carefully to avoid ink transfer.
3. Insert the black ink cartridge into the printhead.
4. Press down on the ink cartridge until you hear it click
into position.
5. Open and uncap the color ink cartridge. Insert it into
the printhead.
6. Press down firmly on the ink cartridge until you hear it
click into position.
7. Close the printer access door.
Here's the link if you want some illustrations. Link
Chapter 3, Page 5
Thank you for posting..
Jun 30, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
HOW DO I CHANGE THE INK CARTRIDGES IN MY CANON PIXMA MP160
Hi
Here's how to replace ink cartridge.
Make sure the printer is turn on. Place your fingers under the LED control panel and lift the scanning unit. The cartridges inside the printer will automatically slide to the left, for easy access. Remove the empty cartridge by pushing the front of the cartridge downward. It will snap out of its cradle. Pull out the cartridge and replace the new ink cartridge. Insert the new cartridge. With the front of the cartridge tilted down, push the back into the cradle. Lift the front upward, and the cartridge will snap into place. Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help. Regards and thank you for using Fixya !
May 21, 2011 | Canon PIXMA MP160 All-In-One Printer
Problem installing an ink catridge
Most HP printers will move the print heads to the center of the printer when you open the front.
Each cartridge has a flip that you can flip up. The cartridge can then be removed by tilting it toward you. You can install a new cartridge by removing it from the box and foil liner. You then remove a strip that protects the head. Like you took out the old cartridge, tilt the cartridge and straighten it up. Flip the flip down. Close the top. You should be ready to go after the heads clean themselves and do an alignment.
If the printing is not satisfactory, you can go to your programs and hp will have a tool to perform alignment.
You can use HP cartridges, refilled cartridges or fill cartridges yourself (depends).
I've filled cartridges with success. However, it can be a bit messy.
Jun 07, 2010 | HP Printer Cartridges (Complete List): ,...
How do i install ink cartridge for HP 4355?
To install the ink cartridge
1) Press the On button. After you press the ON button, wait for the print cartridge prompt before continuing.
2) Open the print cartridge door. Lift the print cartridge door. The print cartridge moves to the right side.
3) Remove tape from both cartridges. Pull the tab to remove the tape from both print cartridges.
Important : Do not touch copper-colored contacts or retape the cartridges.
4) Insert the tri-color print cartridge.
Caution : The device must be On before you can insert the print cartridges.
a) Slide the tri-color print cartridges into the left slot.
b) Push the top part of the cartridges firmly up and into the slot until it snaps into place.
5) Insert the black print cartridge.
a) Slide the black print cartridge into the right slot.
b) Push the top part of the cartridge firmly up and into the slot until it snaps into place.
c) Make sure both cartridges are secure, Close the print cartridge door.
6) Align the print cartridges.
a) Press OK to print the alignment page, (Make sure you have loaded plain white paper in the bottom tray,)
b) Remove the alignment page from the output tray.
c) Place the alignment page face down into the document feeder.
d) Press OK to scan the alignment page.
After the page has scanned, alignment is complete.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Dec 01, 2009 | HP Office Equipment & Supplies
Show me how to install new ink cartridge onv305
hi eileenoreill,
you can try these steps:
  1. Turn on your printer.
  2. Lift the scanner base unit.
  3. Press down on the ink cartridge lever to raise each ink cartridge lid.
  4. Remove the old ink cartridge.
  5. Store the cartridge in an airtight container, such as the storage unit you received with your photo cartridge, or dispose it appropriately.
  6. Remove the sticker and transparent tape from the back and bottom of the new ink cartridge.
  7. Insert the new ink cartridge. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
  8. Snap each lid closed.
  9. Lower the scanner base unit until it is completely closed
  10. Snap each lid closed.
just update me if the issue is not yet resolved.
Oct 18, 2009 | Dell V305w All-In-One R840635AU InkJet...
How do I put new cartridge in
Follow this procedure to install print cartridges in you printer.
1 Turn on the HP Officejet, and then lift open the print-carriage access door.
The print carriage moves into view.
2 After the carriage stops moving, push down on the top of the print
cartridge to release it, and then pull it toward you out of its slot.
3 Remove the new print cartridge from its packaging and, being careful to
touch only the black plastic, gently remove the tape by using the pink pull tab.
Caution! Do not touch the gold-colored contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge
immediately to prevent the ink from drying in the nozzles.
4 Hold the black or photo print cartridge with the HP label on top. Slide the print cartridge at a slight angle up into the right side of the print carriage.
Press firmly until the print cartridge snaps into place.
Caution! Do not attempt to push the cartridge straight into the slot.
It must slide in at a upward slight angle.
5 Hold the tri-color print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the left side of the print carriage.
It must slide in at a slight upward angle.
Note: You must install both print cartridges in order for your HP Officejet to work.
6 Close the print-carriage access door.
“Press OK to print Align page” appears on the display.
7 Press OK.
Oct 06, 2009 | HP OfficeJet 4215 All-In-One InkJet...
How do I remove and install new black ink cartridge in Canon K10222 printer please
How to Remove the black ink tank on the Canon K10222
Turn the printer on and open the printer cover. (The print head will move from the right to the center.)
Lift up on the Push mark on the black ink tank to unlock the ink tank from the allocated slot of the print head and lift it out.
How to Reinstall the new black ink tank
Install the new black ink tank by inserting the the new black ink tank where the old one was removed. Put the back rear edge in first. Then press down the Push mark on the front top of the black ink tank until it snaps into place with a click sound
Close the printer cover and you are done
Hope that makes sense...
Take Care,
Michael
Nov 06, 2008 | Office Equipment & Supplies
Print cartridges
  1. When one or more ink cartridges are empty, for example, Black, the LCD shows “Ink Empty Black” and “Open Cover.” Close the printer’s document support and the document tray.
  2. Lift the top cover to the open position until it locks securely into place.
  3. Pull the ink cartridge hook toward the front of the printer and remove the color ink cartridge displayed on the LCD. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  4. Open the new ink cartridge bag for the color shown on the LCD and remove the new ink cartridge. The cartridge cover may come off when you open the bag. This is not uncommon and will not damage the cartridge.
  5. Each color has its own correct position that is clearly labeled and color coded inside the printer. Keep the ink cartridge in an upright position when you insert it into slot. It will only fit in the correct direction. Press down on the ink cartridge until the hook snaps over it.
  6. If you replaced an ink cartridge while “Near Empty” was displayed on the LCD, the LCD may ask you to verify that the replacement cartridge was brand new one. Example: “Did You Change Black? 1.Yes 2.No.” For each new cartridge you installed, press 1 on the dial pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand-new one, select 2.
Sep 16, 2008 | Brother MFC-5840CN All-In-One InkJet...
How do I install an ink cartridge? HP photosmart c5280 All in one
To replace the print cartridges Perform the following steps to replace the print cartridges:
  1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
  2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door c00956268.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
  4. Pull the print cartridge toward you out of its slot.
    NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
  5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts c00956271.gif
  6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge c00956272.gif
  7. Close the print cartridge door. Figure 6: Closing the print cartridge door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
  8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
  9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
    NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
  10. Press OK to continue.
May 15, 2008 | HP Office Equipment & Supplies
Lexmark X1270 All-In-One InkJet Printer Logo
176 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
