Describe your aspire 9410z fan problem Problem Laptop gets very hot, none of the usb ports are working. Not able to connect with the internet using an air card or able to download files using a flash drive.
  • 27,725 Answers
try cleaning your computer of dust using a fine air blower from a compressor making sure that there is no moisture in the air line dust causes static to build up in a computer causing lots of problems
hope this helps good luck
Posted on Sep 08, 2010
How do you open a port
  1. USB ports stopped working Acer Aspire 5750 - Tom's Guide
    www.tomsguide.com/.../usb-ports-stopped-working-acer-aspire-5750.ht... Apr 23, 2014 - USB ports stopped working Acer Aspire 5750. Tags: Aspire. Laptops... I have an Acer 5750 none of the USB ports work I tried disabling them all ... on Acer Aspire 4935 laptop Forum; Acer Aspire Computer - USB not working ...
Jul 11, 2015 | Acer Aspire Computers & Internet
Why isMy Acer aspire gettting really hot, would replacing the battery help?
Sometimes, the computer gets really hot because the "ventilation" (cooling) system (fan, etc.) is not working properly. Normally, if it gets too hot, i.e. to an unacceptable level, the system will shut down. Or, it will catch on fire.
Yes, it's known that some battery will get too hot ... and potentially damage the system. So, if you already know that the cooling system is working properly, then try replacing the battery.
May 28, 2014 | Acer Aspire One PC Notebook
4 OR 5 DAYS BEFORE WHEN I START COMPUTER IT CAN STOP AND RESTART AUTOMATICALLY AND GIVE BLUE SCREEN ERROR AND ALSO NOT CONNECT WITH INTERNET LANDLINE CONNECTION OR USB CONNECTION
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 20, 2010 | Acer Aspire 5542 Notebook
USB not working
If none of your USB ports work, there could be a problem with your USB controllers. Uninstall the USB controllers via Control Panel - System ... and reboot your laptop. They will reinstall upon bootup. Good luck.
Jun 13, 2009 | Acer Aspire 5100-5033 Notebook
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Acer notebook usb not recognized
Sounds like a hardware issue. I would guess that there is a bad connection between the usb's and the motherboard. If you are comfortable dismanteling the laptop and re-soldering the usb's than give that a try, but I would recomend you give it to a pro.
Here is a link that explains the process. http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Jan 17, 2009 | Acer Aspire 5100 Notebook
ASPIRE ACER 9410Z...sound wont work
Maybe it's something to do with the drivers. You can try and perform a reinstall by going to start ---- programs --- acer recovery manager ----- click restore at the bottom and reinstall teh drivers from there.
Apr 30, 2008 | Acer Aspire 5500 5570-2609 Laptop
Key board not responding
Try attaching an external keyboard to a USB port on the computer. If it works.
The keyboard cable is probably loose.
Apr 07, 2008 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
