Question about KitchenAid Dryers
Dryer stopped heating - it is rotating but there is no heat!
  • KitchenAid Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
The dryer is about three years old, the drum rotates, tumbles, but there is no heat? It was working and then just stopped, no warning and no burning smell.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 09, 2011 | Dryers
Not generating heat and dosnt stop automatically
heatman101 ,..,
Apr 03, 2011 | GE Dryers
My dryer still rotates but it does not blow hot air and it contineously rotates.the only way it will stop is if Iopen the door
heatman101
Aug 13, 2010 | Estate TEDX640JQ Electric Dryer
My dryer still rotates but it does not blow hot air and it contineously rotates. The only way it will stop is if I open the door.
first check for 240 volts at the dryer if it has an electric heating element,if you lose 1 leg of the 240 volts that leaves you with only 120 volts and with both your problems this is what it sounds like your problem is,because the motor is on one leg(120volts) the timer is on the other(120volt)leg and the element is on both legs at 240volts,so you lose 1 leg your timer or motor would qwuit and the heating element wont heat either
Jul 19, 2010 | Estate TEDX640JQ Electric Dryer
Whirlpool Gas Dryer Model #LGR7648KQ0 has no heat - I cleaned out the vent (it was pretty well clogged!) and then replaced the Fixed highlimit thermostat, the thermal fuse and the dryer cycling thermostat...
The problem is the dryer coils are failing. They tend to fail as they heat up. There is a video at http://appliancehelponline.com/gdryertroublevideo.html this will walk you thru checking them. They are inexpensive and easy to replace.
May 26, 2010 | Whirlpool Dryers
No heat in the dryer. It is Maytag Neptune gas dryer about 9 years old. The drum rotates just fine but heat stopped a couple of days ago.
heatman101
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer does not heat
Check out this tip it will help you with your problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Heatman101
Mar 23, 2010 | Kenmore 72972 Gas Dryer
Dryer does not heat. It does rotate. Any ideas?
The heating is either a blown fuse or element and the rotating is the belt that has come off or broken or worts case the motor has packed up
Dec 28, 2009 | Whirlpool LEQ9858P Electric Dryer
Kirkland Dryer drum does not rotate, but heat comes out
check capacitor next motor its a white long got three clips coming off it change good luck
shaun
Jan 16, 2009 | Whirlpool GEW9250 Electric Dryer
Open Questions:
Dryers Logo
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
