Question about Yamaha RX-V2700 Receiver
I have a yamaha rx-v2700 and it will not power on. there is power getting to the back of the power socket but no power at the internal fuse,
  • northlodge Sep 09, 2010
    hi Palaboy, thank you for your response, so far i have not had time to look at the amp again but i can tell you that there is no power to the fuse (F1)
    sid
  • northlodge Sep 13, 2010
    Hi Palaboy, could you tell me the number on the circuit board where i will find the transistor that you want me to test please
    sid
  • Yamaha Master
  • 5,807 Answers
Service Manual can aid you with the troubleshooting,
Audio Yamaha RX... - Electronics Repair
It is number 55 on the list.
Only with a fee.
Your unit , besides the standby transformer , there
is a much bigger transformer that supplies
voltages to the Amplifiers.
These amplifiers will not operate without the necessary
split supply ,
These power transformer will not have output voltages
if the primary windings are open.
( open meaning no internal resistance ).
If these transformer is not open,
Check for low voltage regulators that activates ( latch )
the relay that turns On your Power transformer.
If these are OK , three ( 3 ) things to check
a) check Micro
b ) check for cold solder joints
c ) check for possible shorted power Transistors
Posted on Sep 08, 2010
  • 7 more comments
  • Rommel Cana
    Rommel Cana Sep 09, 2010
    here is a schematics to show you :
    If there is power on the outlet check on the circled component ( fuse )
    above
  • Rommel Cana
    here are additional guides:
    Troubleshooting
    Transistors
    How to solder boards properly
    ( click on the links above )
  • Rommel Cana
    these is where you would test ( pins on transistor )
    these pins should not be shorted , C and E
  • Rommel Cana
    sample image of the transformer that you may need to check
    for continuity in primary windings:
  • Rommel Cana
    On some Model like:
    might as well check , if yours have one
  • Rommel Cana
    sample image of the transformer connector:
  • Rommel Cana
    It is OK , take your time,
    But try to read the schematics above ,
    ( if you cannot understand what it means I understand )
    try to check if you have voltage selector at the back , sample image is also
    on the post above.
    here are sample image location of power transistors:
  • Rommel Cana
    additional guide for you :
    Troubleshooting
  • Rommel Cana
    Rommel Cana Sep 13, 2010
    I understand if you have not read all my post with images
Yamaha rx-v2700 digital A/V receiver will not read 3trb external hard drive when it is formatted on nts and also tried with fat32 format and does not read mp3 files. when plugged into usb port the reciever...
Hi. Is the HDD drawing too much power from the receiver (does it have its own power supply)?
You could look at the troubleshooting guide in the user manual here:
Yamaha RX V2700
Feb 14, 2018 | Yamaha RX-V2700 Receiver
Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
why not you use a normal AV cable
instead of hdmi cable
May 22, 2008 | Yamaha RX-V2700 Receiver
What kind of up-grades are for the yamaha
There are no "upgrades" however, if your having problems with HDMI switching or "not working" You can send it to Yamaha and they will replace the HDMI board at n/c. It's still version 1.2 and the current version is 1.3a soon to be 1.4. What is it that you need to have upgraded? Post a comment with what it is you would like your receiver to do and I can help you further. I work with Yamaha daily
Nov 25, 2009 | Yamaha RX-V2700 Receiver
RX-V1070 tuner fault
This only a cold solder symptom in tuner section .Just reworks all solder joints components parts in tuner section.
Good luck:
Regards:
Dont forget to rate.
Jun 30, 2009 | Yamaha RX-V2700 Receiver
120v plug in's on the back of my rx-v2400 will not send power to my mono block amps.
those are fused internally and made to power small items.the unswitched are constant power and the switched goes on and off with the power on the reciever.you have hooked it up to something that draws way to much power and more than likely blew the fuses.check the back by the sockets,they are rarely over 250 watts max.
Jun 12, 2009 | Yamaha RX-V2400 Receiver
Yamaha RX-V2700 no sound from any speaker outputs
Make sure that you have the correct input signal selected.
Also, check if the sound is not muted.
If you have a multi-room speaker switch, make sure it is set correctly to main speakers.
Apr 28, 2009 | Yamaha RX-V2700 Receiver
Yamaha RX-V2700
Have you tried to see if there is a fuse connection on the back of your receiver?
Sep 20, 2008 | Yamaha RX-V2700 Receiver
Getting to work your pc music files through the usb connection
how should i connect my yamaha rx-v2700 to my desktop pc and which software i should install on my pc and where to download this software
Feb 12, 2008 | Yamaha RX-V2700 Receiver
Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
Jan 18, 2008 | Yamaha RX-V2700 Receiver
The subwoofer preout is not working
does sub woffer have speaker wire in and outs run the fronst throw ther back up to front speakers pass throw it that would work
Jan 06, 2008 | Yamaha RX-V2700 Receiver
Yamaha RX-V2700 Receiver Logo
1,160 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
