Question about Whirlpool Duet GHW9150P Front Load Washer
My drum is broken how to remove it - Whirlpool Duet GHW9150P Front Load Washer
  • 92 Answers
There is a string or something attached to it just remove it
Posted on Sep 08, 2010
Testimonial: "yes i removed it and it worked thanks"
Dryer drum won't turn
Hi
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
Note: This method works for most front loading machines.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
Here is a link to see a picture of your belt routing in case the belt is broken when you open your dryer:
http://www.expertappliance.com/dryerbeltconfiguration.html
While you have the drum out, I would recommend that you remove and lubricate the drum rollers.
And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Please take time to rate me
Oct 04, 2012 | Whirlpool WED4800XQ Traditional Electric...
Rear brake pipe broke off inside the rear drum how do i get the broken piece out and hoe do i repair it again to working condition
remove the wheel of the drum then remove the drum if its stuck you gonna have to use a hammer a bit after you removed the drum remove that broken piece i recommend that you buy a new one to replace the broken then ur done
Sep 03, 2012 | 2005 Toyota Tazz 130
Need to replace back left rear wheel studs...3 out of 4 are broken. How difficult is this? Should I just purchase another drum? Is the drum difficult to get off and install for a want to be mechanic?
drum is not hard to get off and install
no dont buy another drum
once you remove drum,you can just knock the broken studs out with a hammer and punch
to install new studs,just tap them into place with a hammer. the studs go in from the inside of drum.happy mechanicing
Dec 23, 2010 | 2000 Ford Focus
Drum does not agitate water goes in and it just humms, no agitation or spin
The drive belt is broken or the motor's rotor is stuck. Open the door and rotate the drum manually. The drive belt is worn or broken if you can freely rotate the drum. The rotor is most probably stuck if you cannot turn the drum.
Visual check can be done by removing the back panel. Remove the screws holding it to the cabinet and pull it off. Replace the belt if it is worn or broken. Simply wrap it around the drive motor pulley and on one side of the drum pulley. Rotate the drum pulley in such a way that the belt completely wraps around it.
Try to free the rotor if it's stuck by lubricating it and forcibly turning it back and forth until it turns freely. To remove the motor, disconnect the motor wiring harness and ground wire from the terminals and remove the mounting bolt. Pull the motor out of the mounting slots. To reinstall or replace, simply slide it back into the mounting slots and secure it with the mounting bolt.
In some cases, the drum will not spin due to a broken drum pulley. Post it back if that is the case.
Feb 07, 2010 | Kenmore 42822 Front Load Washer
MY SERVICE CENTRE SAY DRUM NEEDS TO BE REPLACE,
Drum can break , it is not unusual.
Remove rear cover, and looknunderneath the drum, you will probably see where it has broken, and it would be better to buy new washer if it has brokem.
Happy new year.
Jan 01, 2010 | Indesit WA 125 Front Load Washer
How do i fix the tub from not spinning
You did not say if it was broken or not...
If it is broken then it must be replaced.
If it is not broken, then it must have came off the pulley or the drum.
you have to pull the front of the dryer off and remove the drum to reinstall the belt on the pulley and the drum
Sep 25, 2009 | AEG Dryers
Drum does not turn
THE BELT HAS BROKEN,TO REPLACE REMOVE THE 2 LINT SCREEN SCREWS,PULL THE TOP TOWARD YOU AND UP,REMOVE THE 2 SCREWS FROM THE TOP FRONT PANEL ONE ON EACH SIDE,REMOVE THE DOOR SWITCH WIRES,PULL THE FRONT UP AND OFF,PUT THE NEW BELT AROUND THE DRUM AND UNDER THE DRUM PULLEY AND ONTO THE MOTOR PULLEY,PUT ALL BACK TOGETHER,YOU CAN GET THE MODEL NUMBER FROM INSIDE THE DRYER DOOR,GO TO YOUR LOCAL APPLIANCE PARTS STORE TO GET A BELT,OR GET IT FROM SEARS .COM
Mar 08, 2009 | Kenmore 63942 Dryer
Installation of workcentre pro 416 drum
Just sendig this to get your message off the baord. I sent you the most likely problem.
I will add you may want to see if the pin assembly is broken. You can clean that shafe and lubricate it.
Dec 30, 2008 | Xerox WorkCentre Pro 416DC Copier
REMOVE FRONT PANEL - ZIPPER PARTS STUCK IN DRUM GUIDE.
I found the parts manual on line at GE Appliances.
The replacement parts for the top indicated pictured two clips holding the front of the dryer in place.
I tried a narrow screw driver on the clips and that released the top.
With the top off, removing the front panel required removing two screws, lifting the drum and pulling slightly on the front panel.
After removing the wires from the door switch, I was able to find the broken zipper, clean out the fan, remove excess lint and reassemble.
Dec 06, 2008 | GE DBL333EBCC 5.7 cu. ft. Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
