Question about Samsung LN-T5271F 52 in. LCD Television
Hello, I have a Samsung 5271 that over the last few months, has taken longer and longer to power up. Now it finally won't power up at all. It just keeps trying to turn on and clicking. I think it is the power supply but I'm not sure.
    Problem Solver:
  • 17 Answers
If it just sits there and clicks then yes it is some caps on the SMPS or IP board depending on which one it has. You can replace the caps or replace PCB, thats up to you.
Posted on Sep 09, 2010
How long should high quality exercise bands last for?
If the exercise band is made of high quality rubber, then it will last for at least six months if taken care properly. There's a good chance that it will last for longer than that.
Aug 20, 2012 | Exercise & Fitness
Three-year old 47" Samsung LCD. At first, some pixelation, usually correctable by turning TV off then on again. This situation lasted months, getting slightly more frequent each week. More recently, the TV...
1. the motherboard might be bad and you will need to replace it. 2. or The power supply is bad
Chances are if its making clicks the power supply is bad and you will need to replace it. Which makes sense because constantly powering the tv on and off will damage the power supply or possibly short out your motherboard. These things usually cost about 200 bucks to fix at a local tv repair store.
Sep 02, 2010 | Samsung LN-T4671F 46 in. LCD Television
Hi I Got a Samsung SyncMaster 920NW the display
If you are saying that it powers off in a few seconds you most probably have a bad (internal) power supply.
Jul 12, 2010 | Samsung SyncMaster 920NW Monitor
Samsung 22inch lcd monitor goes blank after 1min idle system.
Hello sir, I have samsung 22in lcd monitor and nvidea fx5500 card. since last more than 6 months, my monitor goes blank If system remains idle (means I don't move mouse and don't touch keyboard) for 1 minute. After monitor goes blank I have to move mouse to brink it back to on. The power led keep on during this problem. I tried everything including power options in windows but could not fix it. Is it bios setting to be checked or could it be windows bug? Please help
Mar 23, 2010 | Acer X193W LCD Monitor
The battery in my canon elph sd780 doesn't last long
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Feb 20, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Tv tries to come on but just clicks and clicks. seems to be powering it self on and off. Samsung LNT 4665F. Red standby light blinks on and off with clicking sounds. Blue Power on light tries to...
There are 3 capacitors in power supply board, all 1000uF10v.
2 for 5vdc and 1 for 12vdc. replace with best quality 1000uF 25V cap.
do it yourself repair will save you $300
Oct 18, 2009 | Samsung LN-T4665F 46 in. LCD Television
I have a magic chef range/oven. For the last few months, it has taken longer and longer for the oven to heat up to temp. Now it won't get more than 90 degrees or so. What is the problem??
Turn off the power to the range. Remove the bake element from inside the oven. Be careful not to let the wires go back into the oven cavity. Take a volt/ohm meter set for ohms or continuity and test the bake element leads. If you get no reading replace the element. If you do get a reading,replace the temperature sensor in the oven.
Oct 08, 2009 | Magic Chef Ovens
TV suddenly stopped working; not will not power up at all.
it may have overheated
or it blew a internal fuse
if this is the case you may be covered under warranty. if warranty is expired contact
http://www.tacp.toshiba.com/customersupport/contact.asp
Apr 29, 2009 | Toshiba 26HL83 26 in. LCD HDTV
Samsung Digimax V4 Power Consumption
I had similar symptoms as well until it finally died: 1) First started eating batteries like crazy, especially standard AA and rechargeables. The CRV3 seemed to work a bit longer. 2) One day out of nowhere the autofocus stopped working. I replaced the batteries and it worked again for 10 shots. Then the autofocus stopped working and battery died (with the lens stuck open). Pressing power, the LCD backlight flashes on, the LED in the view finder blinks, and the lens motor makes noise. Then nothing just stuck open. 3) Again new batteries and was able to close lens, take a few pictures and dead again with lens stuck open - same problem in 2. 4) Replaced the batteries a couple times and was able to get a shot or two off, and now its complete stuck open, even with brand new batteries - with same problem in 2 it just won't turn on. I finally sent it to Samsung the week of Christmas. I called Friday 1/7/05 to check and had to leave a voicemail. They called back Monday 1/10/05 to let me know they recieved it and that I should call back Thursday to check its status.
Sep 12, 2005 | Samsung Digimax V4 Digital Camera
Samsung LN-T5271F 52 in. LCD Television Logo
150 people viewed this question
Jerry Greenberg
Jerry Greenberg
