Question about HP Photosmart C4580 All-in-One InkJet Printer
Ouverture de port udp 427 sur norton - HP Photosmart C4580 All-in-One InkJet Printer
4 Suggested Answers
marketex
  • 371 Answers
SOURCE: Can't figure out how to open the UDP port number 427
Printers cannot function unless able to communicate in both directions.
Posted on Apr 26, 2009
  • 86 Answers
SOURCE: HPOfficejet Pro 8500 Wireless - need to open port 427 -Norton 360
hi first of all I would like to inform you that you have one of the best printers of HP now the open port error 427 that you get is generally due to blockage in network or firewall so we need to first check weather the printer is successfully connected to the network or not so press setup on printer go to network and then go to print network config page it will be on view network settings now note the ipaddress on the wireless tab of the page open a internet explorer and then type the ip address in the address bar and hit enter the printer page should open up if it does that means the printer is on network now turn off nortan firewall and turn on windows firewall now click on the add exception tab of windows firewall it vista it will be allow a programs through windows firewall now click on add port and in port name type the ip address of the printer in port number type 427 and then select udp ot tcp according to the error message you get in the installation if its udp select udp if tcp select tcp now in windows firewall click on allow programs through firewall and then in exception tab check all the entries related to hp apply and ok now restart the computer now try to install
if still you get the same error
click next if you have next highlighted and go to the next step and select the third option from the screen that will be contiue installing the printer
complete the installation
if the next is not highlighted then add an exception in nortan as well for guidelines open hp.com and in the search bar type c01633677 and open the document select nortan and see the instruction to add exception
if still problem persists let us know
Posted on Aug 23, 2009
vonnielsen
  • 169 Answers
SOURCE: Computer says unable to communicate with printer :
Most of the times just skipping that message will let you use the printer. That message is something that has to do with the printer rediscovery just incase the printer get's disconnected.
Checking with your anti virus software provider might help.
Regarding that message though. Try skipping that and try printing.
The printer should work.
Posted on Feb 06, 2011
How do I set trust port 427
Your looking for "firewall ports". I don't remember if Norton has an advance firewall or not. But your looking to "open a port" in either the Norton Firewall or the baseline firewall of your computer.
Sep 20, 2014 | Symantec Norton Internet Security 2011 For...
Error code 0xb814728e
Bon je fais mon feedback aussi pour ceux qui ne comprennent pas l'anglais. J'ai ouvert par inadvertance ma HP photosmart a fond, je parle pas du petit couvercle de scan, mais de la grosse ouverture la ou on met les cartouches... et MERDE ! elle voulait plus se refermer ! Surtout ne pas forcer, mais bon en general ca donne l'impression de quelque chose qui bloque, donc une personne normale ne va pas forcer. La solution (que j'ai trouvee sur ce site, merci) c'est de se procurer du WD40, ce lubrifiant bien connu, et d'en arroser les charnieres. En manipulant doucement votre imprimante, vous allez voir, elle va se refermer gentiment au bout de dix minutes. Quel soulagement !
Aug 29, 2013 | HP Photosmart 3310 Printer
CHARNIERRE DE SUPPORT
Mettez un peu de lubrifiant en poudre de graphite sur la charniere pour l'assouplir.
Aug 19, 2012 | Acer Aspire 5720 Notebook
I am trying to install a wireless printer to my lap top and is asking me to make sure the udp port 427 is unblocked for inbound and outbound traffic how do you do that?
On your laptop open the control panel then windows firewall, if you are using windows 7 the first link on left should be allow program or application. You will add an exception rule, name it, specify the port 427 and click ok. Now on to the second part. Open your web browser IE logon to the router, for example linksys is 192.168.1.1 if you don't know what your routers ip is, right click your connection in the tray, click status and advanced and note the IP address of your gateway, this is usually your router or firewall.
Login to the router, find the firewall port forwards tab, specify a name and the port 427 and click save to create the port rule. Now try your setup again.
Aug 29, 2010 | NetGear Computers & Internet
Erreur 105 serveur introuvable
Cette erreur est généralement provoquée par le programme de sécurité.
Norton est connu de bug chrome. Essayez de:
1.Ouvrez Norton Internet Security
2. Cliquez sur Firewall personnel et cliquez sur Configurer
3. Cliquez sur l'onglet Programmes et défiler jusqu'à Chrome.exe
4. Changez-à-dire "Autoriser tous"
5. Open Chrome
J'espère que cette aide, wbwTeam
Mar 25, 2010 | Google Chrome
HOW CAN I OPEN A PORT TCP AND UDP IN FRENCH FOR DSLG604T V3.00
Exemple : Vous accueillez un web server sur un PC qui a l'IP address de LAN de 192.168.0.50 et votre ISP bloque le port 80. Nommez le Virtual Server (par exemple : Web server) écrivez l'IP address de la machine sur votre LAN (par exemple : 192.168.0.50 Entrez dans le port privé comme [80] Entrez dans le port public comme [8888] Choisissez le protocole (par exemple TCP). Assurez que le programme est placé à toujours Cliquez sur sauf pour ajouter les arrangements à la liste virtuelle de serveurs Répétez ces étapes pour chaque règle de Virtual Server que vous souhaitez s'ajouter. Après que la liste soit complète, clic sauf des arrangements au dessus de la page. Avec cette entrée de Virtual Server, tout le trafic sur Internet sur le port 8888 sera réorienté à votre web server interne sur le port 80 à l'IP address 192.168.0.50.
My French isn't good sorry.
Feb 15, 2010 | D-Link AirPlus G DSL-G604T (790069265662)...
I have Windows XP and am trying to install HP Office Jet Pro 8500 Wireless and am getting the message to check UDP Port 427 to see if it is open. How do I do that? Don
Hello my friend,
If the HP device will be used locally you will not need to open any port, because open port mean do the port forwarding which is used only in NAT mode but anyway if they ask if the port UDP 427 is open that means that you need to access to the router web interface which is usually 192.168.1.1 and then under Port forwarding you will need to add a rule with external port: 427, Type: UDP, internal port : 427, internal IP: the ip of your HP device. and then save and reboot. everything should be fine after that.
Best Regards,
Oct 31, 2009 | Linksys Wireless-G WRT54G Router
Aug 23, 2009 | HP Photosmart C4580 All-in-One InkJet...
Don't know why this becomes an issue with these type of HP printers but i think ive worked a way around it...
Heres how you do it: (XP)
Control Panel>Printers and faxes>
Then select "Add printer" and choose the first option (Local printer attached to this computer)
An errormessage will appear saying they were unable to find printer. Click next to find the printer manually...
Now select "Create a new port" and choose standard TCP/IP... Ignore the list of different types of printers, now select "From Disk" and then click next... Once The computer recognizes the printer, it all should be in order...
Hope this could help you...!
Apr 25, 2009 | HP Photosmart C4580 All-in-One InkJet...
Non syncronization mechanism CD player
1$$$
Dans l'ensemble, ça marche super : fm, am, cassette(un peut dure mais ça devait être la tension de la bande...), Auxiliaire (oc : RCI...), mécanismes de montée/descente, ouverture des tirroirs, séléction du tirroir à faire marcher... test d'allaitement de la lentille : tout ça c'est bon/.
Mais, le CD ne tourne pas!!!
Est-ce le moteur qui serait grippé? Il ne semble pas puisque, alimenté directement avec une AC/DC en 3-5V : Il toune! Est-ce le programme contenu dans ces étrange blocs noirs à bras multiples qui donne l'impression d'être des microprocesseurs(2000 ans d'avance sur Intel...) qui nécessiteraient un reset ; car, en effet, n'ayant plus la télécommande, il n'est pas possible de remettre à l'heure la pendule et par conséquent de bénéficier de tous les avantages situés somewhere à l'azimut (du sud, sens direct) PI - 7/.
Qu'en pensez-tu?
2$$$
Mar 02, 2009 | Sharp Audio Players & Recorders
HP Photosmart C4580 All-in-One InkJet Printer Logo
65 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
