Error code cfa14 on a konica minolta c451 - Office Equipment & Supplies
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
  • 3 Answers
SOURCE: c451 Bizhub Konica Minolta printer
press utility. press metercount. press metercount details. press stop 0 0 stop 0 1 to access service mode in service mode look for admin initialialation function
Posted on May 22, 2008
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Posted on Jan 16, 2009
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
KONICA MINOLTA 258 ERROR CODE CFA14
We had one here but fixed by doing firmware.
Check the marketing area is correct for your region
<Symptom>
"Please turn main switch off and on."(FA14) may be displayed if the following procedure is operated.
<Reproduction Procedure >
If "Other3" is selected in marketing Area setting, "Please turn main switch off and on."(FA14) may be displayed when performing Scan sending the following orientation mixed document.
- 8K or 16K and other document size.
Jul 11, 2017 | Konica Minolta Office Equipment & Supplies
P7 error code in Konica Minolta c451 how to solve
replace the magenta (Red ) image unit.
Sep 14, 2016 | Konica Minolta C451
How to solve error code c-2553
The toner abnormality you have to clean toner hopar and clean senser and again OFF and ON
May 23, 2015 | Konica Minolta C451
Errore Trouble code C-C172
Refer to Konica Minolta Bizhub C451 Printer/Scanner/Finisher's User Manual or Call Service Center.
May 01, 2014 | Konica Minolta Bizhub C451...
4301 error code in c451 konica minolta
Left side of the machine, remove the upper and lower left covers remove the metal cover to your lower right is the fan causing the code
Dec 05, 2013 | Konica Minolta Office Equipment & Supplies
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Sep 24, 2009 | Konica Minolta bizhub C450P Laser Printer
1,553 people viewed this question
k24674
jasbo
jasbo
