Question about Garden
How to change trimmer line - Garden
How to load string into trimmer head
pull head off cut 1 piece of line bout 48 inches should be a **** in center of head put center of line in slot then roll line in same direction in both slots lock ends in head reinstall
Jul 15, 2012 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
How to change the trimmer line
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Until Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, ii
Jan 06, 2012 | Homelite Mighty Lite Lawn Trimmer
How to change trimmer line 32 cc craftsman weed ****
Input the model number of your trimmer here and download an owner's manual. The manual will have detailed instructions on how to change the trimmer line.
http://www.managemylife.com/mmh/owner_manuals
May 01, 2011 | Craftsman Garden
How do change the line? can not get head off Craftsman 25cc Gas Line Trimmer
should be a button on side of head assembly. press in and top should come off
Jul 05, 2010 | Craftsman 25cc Gas Line Trimmer
Hello i have a question on changing th fuel
how to change fuel filter in gas tank remove line from carb pull line through the fill hole in gas tank remove filter replace & pull hose back up reconnect to carb & your done
Jun 27, 2010 | Homelite Mighty Lite Lawn Trimmer
Out of trimmer line
You should be able to just pull the spool off the end. Try. Once you have it off, look closely at the spool. You will find the starting hole/s and the direction to wind the string. Good luck...Lee
Jun 10, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Change cutting line
Pop of bottom cover and wrap new line by turning head or replace with different spool or blade cutter
Jul 01, 2009 | Craftsman 22" Gas Hedge Trimmer
Change feed fuel feed line craftsman string trimmer
no should be fairly straight forward! you can find the tubing at ace lowes home depot! good luck & happy trimming!!
May 31, 2009 | Craftsman 25cc Gas Line Trimmer
Refill string trimmer
ARE YOU WINDING TO LINE THE RIGHT WAY ON TO THE SPOOL?? FOLDING THE LINE IN HALF AND WINDING BOTH ENDS OF LINE SAME WAY? NEIL
Dec 16, 2008 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
