Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool ADP6000WH This dishwasher does not clean and leaves soap in dispenser. Tried other products but same result leaves most of the soap in dispenser. What could be the problem, machine is 8 months young
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 08, 2010
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Hi, Just moved into a place with a DU4500B Magic Chef. After a cycle there is still a clump of wet soap in the main wash cup dispenser and the dishes aren't clean. Yesterday I tried putting the soap in...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 04, 2010 | Magic Chef 24 in. DU4500 Built-in...
Rinse aid does not dispense
Normally 2 things operate the dispenser. 1) is by means of an electrical solonoid which activates automatically. 2) when your rotors rotate, they spray hot water onto the dishes and your soap dispenser. The heat activates it then. possibly the rotors are blocked not allowing the rotators to turn resulting in no hot water getting to the dispenser. Clean the rotors
May 17, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I have a whirlpool dishwasher that is not working properly. It is less han 3 years old. It is not cleaning the dishes properly and leaving a heavy film on the dishes which only came off by handwashing with...
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info. You will love the results!
May 08, 2010 | Whirlpool 24 in. DU850SW - Multiple Color...
The soap fails to disolve!
Having the dishwasher powder failing to dissolve is a far more common problem recently with the filing economy.  People are trying to save money by buying generic dishwasher powder rather than brand name products.  The ultra-cheap products fail to dissolve because their ingredients include bulk fillers with minerals, etc.
It is possible that the dispenser is failing to open, but that is a generally rare problem except on very, very old dishwashers. Before deciding the dishwasher has failed, go buy a box of brand name (Electrosol or Cascade) dishwasher detergent powder and only use it.
Please report back your results here, OK?  Good Luck!
Apr 17, 2009 | Whirlpool 24 in. ADG7540 Built-in...
My dishwasher still has soap in the dispenser
are you sure its soap? do you have hard water? that could be leaving spots on your dishes and also not allowing the soap to properly mix with the water. there is a product out that actually filters and softens the water going into your dishwasher. it works great and is way cheaper than a new dishwasher. i would give it a try. i love mine. you can get it at www.dishwasherfilter.com
Jan 26, 2009 | GE 24 in. GSD2120C Built-in Dishwasher
Whirlpool dishwasher ADP6000WH Error 3
Hi there i have found out that error 4 mean's two many soap suds and ths washer thinks there's two much water. Try less soap and clean the filters.
Jan 15, 2009 | Dishwashers
Soap door doesn't open
remove the door panel and replace the wax motor on the dispencer
May 22, 2008 | Whirlpool 24 in. DP840D Free-standing...
Dishwasher won't dispense soap
The dispenser's unit should be replaced. You can try as well to operate the dishwasher while putting the powder detergent or the tablet on the dishwasher's bottom and if you will get good results, to opereate the machine this way. Good luck!
Sep 05, 2007 | Roper 24 in. RUD5750DB Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
281 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
