Question about HP Pavilion dv9715nr
Yes my laptop does not come on the blue light at the plug in adapter is on but it will not try to start
    Problem Solver:
  • 10 Answers
Is the lap top power on when u press the power on button
Posted on Sep 08, 2010
2 Suggested Answers
epr1977
  • 46 Answers
SOURCE: NO POWER/NO BLUE LIGHT
eww.... Probably it's something related witht power supply of the laptop....Contact hp.....
Posted on Jun 28, 2008
Battery indicator on my acer aspire 5517 laptop is blue what does it mean
Acer Aspire 5517 shows BLUE light when fully charged.
Start it and check battery indicator (tray item) will probably say
plugged in fully charged (with adapter plugged in)
Dec 07, 2013 | Acer Aspire 5517 Laptop
My laptop pavilion dv7 window 7 core i5 stops starting on fir any reason and when I plug it on ac there is a blue which appears and if I press the power button this light becomes orange and the laptop does...
I take it is the HP Pavilion
try to charge the laptop for a couple of hours without switching it on, it might be the battery is completely drained.
the light will change to orange to let you know it is charging, when fully charged it should change to blue and stay blue until you remove charger. you should try to use the your laptop with the charger adapter connected at all times when it easy to do so. I do hope this helps.
Sep 20, 2013 | Computers & Internet
Orange battery light comes on and the computer says low battery. Computer does not work even when plugged in to wall outlet. I don't think it is the adapter because blue ring on plug in to the com
Diagonizing and analysing this problem, it's obvious that the orange light means battery low.
Have u ever tried charging the laptop with another charger/adapter?
If no try it because some adapters/chargers don't work with some laptops. Also be careful to use the recommended adapter, some can spoil the laptop's panel.
Jul 23, 2012 | Dell Studio 15 Laptop
Acer one notebook no display and automatic shutdown
= if your laptop computer will not start =
laptops have power supplys that can lock up
the power adapters conectors break all the time
and the batterys are designed to be "con$umable$"
so
- - -- - -- - -power reset - - -- - -- - -- - -
remove the power adapter's wall plug &
leave the power adapter plugged into the computer
but pull the laptop battery out of the laptop.
press the power button just like you are trying to start it
but press it longer, this will drain & reset
the internal supply, now relese the button.
-- - -- - -power adapter only test - - -- - -- - -
reconnect the power adapter's wall plug
press the power button to start it with just the power adapter ,
If the power adapter starts the laptop on its own go down to
"If the computer can be started"
If the power adapter does not start the laptop on its own
leave the power adapter plugged into the computer but
remove the power adapter's wall plug & press the power button
just like you are trying to start it again,
then relese the button
- - -- - - battery only test - - -- - -- - -
unplug the power adapter & put the battery back in
press the power button to start it with just the battery
if the battery starts it on its own go down to
if the battery ALMOST starts it on its own
DO NOT BUY A NEW ONE! it may only be discharged
locate another laptop just like yours and charge it,
and yes this is crazy and yes i am sorry!.
- if your laptop computer cannot start at all -
this can be caused by a bad;
connector ($5-$60), power adapter($5-$60),
battery ($70), internal supply ($40-$90),
or main/mother board ($100-$300)
If the internal power supply is bad or if the
power conector fails at random (intermitant)
most of the cost is determined by how dificult
finding parts and dismantling the laptop is
and if it's external or internal
Jun 05, 2010 | Acer Aspire 5720-6661 Notebook PC
My daughters Toshiba satellite l505d will not boot up correctly. It starts but then nothing happens. What do I need to do. Have already taken battery out and restarted. Any help would be helpful.
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - Battery is defective
If no - Motherboard Problem/AC adapter
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. Reformat your computer and install necessary drivers and applications
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite L505-S5966 Notebook
Battery indicator light on, but the actuall computer will not come on; What do I do?
Try the following steps:
1. First remove the battery from your LAPTOP and plug in the AC Adapter. Turn ON the Laptop without the battery. Check if it is Working:
If Yes - You need to change your BATTERY
If No - Try checking your AC Adapter
2. The AC Adapter has LED indicator which will light up if it is plug-in to a power source (outlet) Check if it is lighted:
If Yes - AC adapter functions properly
If No - Try replacing your AC Adapter
3. If the problem still persist you might have an a following hardware failure on the following component:
a. RAM - Memory errors - replace with same Memory SPEED or type
b. Motherboard defective - you need to replace your motherboard with a new one.
Please Rate. Thanks. Cheers!
Mar 02, 2010 | Microsoft Compaq Presario C501nr Notebook
Battery has gone dead. When I plug the A/C cord in the light on the charger immediately goes out and won't charge battery.
try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue.
try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
Oct 12, 2009 | Dell Latitude D610 Notebook
Gateway laptop randomly shut off and wont come back on
Try removing the battery and see if will start up with power adapter. The battery may have failed. If it is a couple years old the battery may need replaced.
Apr 01, 2009 | Gateway Computers & Internet
Jun 21, 2008 | Compaq Presario 700 470024-192 Notebook
HP Pavilion dv9715nr Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
