Question about Frigidaire Gallery GLWS1339EC Top Load Washer
Washer wont wash on large load but will wash on medium and small i want to kwow what is going wrong it want do nothing but fill up and leak on the flooor when on large load should i replace the washer
    President:
  • 2,468 Answers
The water pressure hose connected to the load size switch and the lower outer tub has a hole in it,remove the control panel and replace this hose,it uses water height/pressure in the tub to trigger the switch to operate the machine and the hole must be at the upper end of this hose,so it leaks before the water gets high enough to trigger the switch on a large load
Posted on Sep 08, 2010
After washing 2 loads the machine won't fill to high level it only fills 1/2 way
You have a faulty fill valve. Return/ replace you washer if under warranty. If not then you will have to replace your fill control valve. That valve is where the knob for the fill level is.
Mar 12, 2014 | Danby 1.7 Cu. Ft. 4-Cycle Portable...
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
GE washer wJR4170G1WW wont wash or spin What
changing from large to small load will not cause a problem. this could be a control panel issue. unplug machine, the try rotating load size dial back and forth a few times, plug machine back in and try
Jul 24, 2009 | Washing Machines
The washer only fills up full even when I put the load size on sm
Check the other knob or switch on top. Perhaps it has some settings regarding small, medium, or large load. This switch may be defective. Go to
www.repairclinic.com for more help on removal and replacement. You can also order a new one from them.
Mar 14, 2009 | Washing Machines
Does not agitate with large load
have same problem but mine take large and small loads and leaks
you need part #ap4253876 made by whirlpool
Feb 28, 2009 | Amana ALW480DA Top Load Washer
Maytag washer water doesnt stop
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
Dec 12, 2008 | Maytag HAV3460AWW Top Load Washer
Water drains underneath washer
the load could be to small and all the water whats been left after the wash might be because you only need small pressure on a small wash and the pressure wont make the water evaporate. or you might just need a new drainage pipe i would put less water in next time and see if its better if not get a local self employed plumber.
Dec 01, 2008 | Kenmore 46462 Front Load Washer
Timer setting
choose the load size on the timer for what your putting in large small medium etc match the water fill large small med etc select wash rinse temp to you pref add soap bleach fabric softner pull out the knob make sure the lid is closed
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Frigidaire Gallery GLWS1339EC Top Load Washer Logo
131 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
