Question about Hitachi CR10DL HXP Liion 108 V Micro Reciprocating Saw
Hitatch reciprocating saw switch lever is broken,does anybody know how to fix it?????????
Dewalt Model D304-04 reciprocating saw wont run. I plug it in, pull the trigger and it wont start. What am I doing wrong or what could the cause be?
Hi Fred:
Hmmmmm.
- Confirm there is power in the plug.
- use continuity meter to check that there is a complete circuit through the saw.
- broken connection in plug?
- broken wire between plug and switch?
- switch not functioning?
- switch set between forward and reverse?
- Speed control potentiometer contacts dirty?
- Bad brushes?
Aug 25, 2015 | Dewalt Saws
I pull the quick lever to put the blade in but i cannot get the blade in?
check to see if the lever is worn or bent. If so it won't make the sliding piece move enough to get the retaining ball to open all the way. Do you have a broken piece of blade stick in it?
Feb 17, 2015 | Dewalt 18 Volt Cordless Reciprocating Saw-...
I have a dewalt model dw008 reciprocating saw.while removing a broken blade a small steel ball fell out. #52 in their parts manual.where does it go?
Here is a parts diagram. Item 52 is the ball. It fits behind item 49. Item 49 has a groove machined into it so that when it is moved it allows the ball to move away from the blade far enough to insert the blade. Once the lever is released the ball moves back and locks the blade into place.
DeWalt parts diagram
Jul 20, 2012 | Dewalt DW008 24V XTR Reciprocating Saw...
How to remove broken blade stub from cordless ryobi reciprocating saw
Try spraying the clamp assy with WD40 and then gently bang the front down against the work surface whilst holding open the clamp lever.
May 16, 2012 | Ryobi 18 V Cordless Reciprocating Saw
Replacing blade assembly on a dewalt 18v Reciprocating Saw Sawzall
Remove the foot, remove the boot (and yellow lever), pull shaft out all the way (so you have more room to work with), remove the spring clip from the clamp block, remove the lever and ball, the clamp block will then slide off once the wire clip that wraps around it is removed.
Apr 22, 2012 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
The lever that releases the blade is no longer working. In other words the old blade is stuck and the lever doesn't release it any more. Any thoughts on a fix?
Sometimes plaster and drywall dust, or other abrasive materials cause these parts to stick... Try some WD40. I spray mine as routine maintenance! (You might have to let it soak for a few minutes the first time) Hope that helps!
Sep 24, 2011 | Dewalt DW304PK reciprocating saw kit with...
My lever to my Dewalt xrp reciprocating saw some how got stuck in the lock position and i have no idea how to remove the lever to fix it
Often when these recip saws get jammed around the blade or lever it is usually due to sawdust or grit that has worked it's way into the mechanism or else the mechanism has actually broken. After a full day of work I often have trouble getting blades removed.
First try spraying the whole mechanism with silicone lubricant and let it soak in. Try tapping as forcefully as you can around the mechanism without breaking anything. If the lever and mechanism isn't actually snapped off somewhere, this usually does the trick.
Dec 02, 2010 | Garden
Shaft or rod seems to be broken
The gears are stripped internally in the saw...it will need to be repaired..usually there are regional service centers for repair...look for the one closest to you...
heatman101
Jul 26, 2010 | Craftsman 85 reciprocating saw 926770
Reciprocating saw only works at certain angles
It sounds like the cord has a broken wire in it or there is a loose wire at the switch. Unplug tool and if you are comfortable in removing the handle halves look at the switch wiring and I pull gently on the wires from the cord to see if a can pull one out. Let me know if you still need assistance and I will go into more detail.
May 16, 2009 | Bosch RS15 1 1/4 Reciprocating Saw
Hitachi CR10DL HXP Liion 108 V Micro Reciprocating Saw Logo
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
