Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
How to convert mini DV to DVD via Computor - Sony Handycam DCR-HC42 Mini DV Digital Camcorder
  • 14 Answers
You should have a computer with either USB or firewire (also known as ilink or 1394) port and a cable to connect your camcorder to this port on computer. Using firewire would be better as you would not get good quality with USB (may be OK for VCD, but definitely not good for DVD). If you have Sony DCR-HC42 model, then place it on its stand and use the suitable port on its stand to connect to the computer via the cable. If it is some other camera, then see its manual to locate the port. Your camera should necessarily have one of these ports for conversion to DVD via computer. The computer should also have a DVD writer, apart from firewire port (or at least USB2 port for the poor quality).
Now, if you use Windows operating system and have this model of Sony, go to Sony's site and download the DVD making software from there. Connect your camcorder to computer and use this software for converting to DVD. The software is user friendly and you would be able to use it without problem. Do not use the software on CD that came with the camcorder as that can make only VCDs.
If you use linux, you can use dvgrab or kino software to capture the video on harddisk in raw (DV) or avi format. Afterwards, use mencoder or such software to convert and burn to DVD format.
Posted on Sep 16, 2010
Hi, I want to change the mini dv image to dvd
You will need to get a converter program to turn it into a dvd.
There are several free ones out there, but I would use FREE DVD CREATOR. It is easy to use, can convert almost any type of media into a dvd, and....IT'S FREE !!!
Dec 08, 2010 | Panasonic Palmcorder PV-DV203 Mini DV...
Transfer from pz card shot on HD to mini DV tape
you can transfer to DV tape only by using software like Edius 6 or a similar one.
First you download the p2 card on the hard drive and then you use this program to convert the video file to DV and use the camcorder as recorder connecting to pc via firewire .
Jan 22, 2010 | Panasonic AG-HVX200A Mini DV Camcorder
I am trying to upload video from my pvgs2 to a dvd on win xp using a wire fire usb converter cord.but neither xp or win 7 recognizes the hardware I dont have regular fire wire connections on either...
Hey! I think you need a DV to DVD burning tool to help you burn dvd from your pvgs2 DV. I recommend you use this DV to DVD Burning software which I had a good luck with.
You can have a try of it. Hope that helps.
Dec 23, 2009 | Panasonic PV-GS2 Mini DV Digital Camcorder
How can i change my panasonic nv-gs230 mini dv
Best
1. Copy the video to your computer with WinDV. No "capturing" involved. The video resolution and PAL/NTSC format will be the same as the source.
2. Then convert to whatever format you like.
You could also use something that copy and converts the video directly from the DV, like convert to dvd with Ulead DVD Workshop.
DV is a fixed standard and comes in 50Hz and 60Hz versions.
50Hz ("PAL" 625/50) 720x576, 25fps interlace (aka 576i)
4:2:0 components, 25Mb/s Video Rate
LPCM audio 2ch 16bit 48KHz or 4ch 12bit 32kHz
60Hz ("NTSC" 525/60) 720x480, 29.97fps interlace (aka 480i)
4:1:1 components, 25Mb/s Video Rate
Meaning, You cannot change the camera. It is either a pal camera or a ntsc camera. Othewise you will have to by a firmware update from the manufacture's website.
Oct 14, 2009 | Panasonic NV-GS230 Mini DV Digital...
JVC SR-DVM600 not recognized by Adobe Premiere Elements 4.0...
I HAVE SAME PROBLEMS AS FLUING PUFFIN ANY SOLUTION EMAIL AT tahirpm@yahoo.com
Jun 01, 2009 | JVC SR-DVM600
TRANSFERRING VIDEO FOOTAGE TO COMPUTER
you can access via USB only SD card on your camcoder.
The only way to transfer from the tape is via Firewire (IEE 1394) . You should have this port on your PC or laptop, if not you can buy external firewire card .
regards,
Konstantin
Aug 06, 2008 | Canon MV530i Mini DV Digital Camcorder
Export movie from an older TRV68 to computer
I purchased a canon elura 100. The 100 has a AV -> DV converter. This allow you to tunnel your Sony via a 3.5mm 4-pole mini AV to mini AV camcorder A/V cable to your computer.
Sony (via AV out) -> (AV) Canon -> PC/Mac (DV) via fire wire cable
Feb 12, 2008 | Sony Handycam CCD-TRV68 Camcorder
HOW TO CONVERT MINI DV INTO DVD ON WINDOW VISTA OS
Get a capture card( IEEE1394) or if your laptop has a firewire inlet you already have a built in capture card. Connect your camcorder via a firewire cable to your laptop. Nero, Windows xp has the step by step procedure making your own dvd copy.
Aug 31, 2007 | Sony Handycam DCR-TRV40 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
488 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
