Question about Imation Apollo (27223) 250 GB USB Hard Drive
My laptop cannot detect the Imation Apollo Portable HD it only shows the light
papa_sanjay
  • 67 Answers
SOURCE: my usb port does not recognize imation apollo
if usb drivers are loaded in your system then this problem comes from dry solder of logic card of external hard disk. open the hard disk and just give some heat to the pin where usb interface is soldered, it will solve the problem.
or it may happen that usb data cord is broken internally.
or it may happen that in bios only usb 1.1 (normal) is enabled. check that and make changes to support usb 2.0 (fast) then save setting and exit the bios it may solve the poblem
Posted on Aug 20, 2009
bob_computer
  • 3153 Answers
SOURCE: Imation apollo pro ux 500gb external hard drive
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Oct 05, 2009
Ooq Affiat
  • 76 Answers
SOURCE: Imation Apollo UX External Hard Drive
try replace the USB cable,
Posted on Oct 20, 2009
SOURCE: I got a Imation Apollo ii 320gb portable hard
Try to reload the operating system you are using i.e windows xp,one of the windows files may have been corrupted and how can you load it. if you have a important files on your desktop try to copy it into any storage device such as flash drive or memory card after you have transfer those files to the backup you use as your storage device unplug it from the system then format the system and load it with your windows xp any one that support service pack 2. how can you format and load your system. in the start up of the system press the key your system support to enter setup some system like compaq for you to enter their setup you have to press F10, some system support DEL to enter setup and some system support F1,while some support F2, any one your system support press it when you get to the setup area to advance setup or check those drop list one after the other until you see were you see booting or booting sequence or booting other then set your CD rom to the first boot follow the order the system give to you then save your setting by pressing F10 key or move your cursor to where you see save and exit and press the enter key for the system to restart then insert your operating system software i.e windows xp immediately the system restart and boot it will bring press any key to boot from cd rom then press enter key then follow the instrution.
Posted on Jun 08, 2010
SOURCE: Hi, Brand : Imation Model : Apollo M250 Capacity
Hi, The hard drive Apollo M250 does not have any locking mechanism. It only has backup software. If your computer does not detect the HDD, it only means that the HDD is already broken.
Posted on Sep 09, 2011
Imation apollo 2.5 portable HDD 250 GB driver missing?
Just download it from Imation.com. Install it and your on your way.
Feb 16, 2014 | Imation Apollo (27223) 250 GB USB Hard...
Imation Apollo M100
https://www.imation.com/en/consumer/external-hard-drives/ External Hard Drives
Jan 29, 2014 | Imation Apollo UX 2.5" USB Portable (250...
Imation 250 12.5m U3 in my laptop but cant open
Connect it to a different computer.
If no success, it is "dead".
Oct 24, 2013 | Imation Apollo UX 2.5" USB Portable (250...
Describe your Imation Apollo UX 2.5" USB Portable (250 GB) Hard Drive Problem
Please repost your problem, and enter a description of your problem in the textbox where it says "Describe your Imation Apollo UX 2.5" USB Portable (250 GB) Hard Drive Problem"
Aug 25, 2011 | Imation Apollo UX 2.5" USB Portable (250...
Aug 15, 2011 | Computers & Internet
Hello there. I can't view the files on my Imation Apollo M100 2.5 Portable HDD. I was able to use a few days back, copied and transferred some files to and from my netbook. But now, I couldn't...
change the usb and then check else if its working or not..check also if its working on any other computer..if its not even detectable at other computer as well then the hdd itself must be the faulty..contact the manufacturer
Aug 10, 2011 | Imation Apollo UX 2.5" USB Portable (250...
Hi, my Immation Portable 160GB as soon as I plug it into my computer, the light is on, the HD seems to be working, but on my pc it doesnt even appear on MY COMPUTER the disk to open. I plug it and windows...
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
Jun 17, 2011 | Imation Apollo Portable - Hard drive - 160...
I have an PHDD 500GB apollo HD. it fall from my hand and now when i connect it only light appears, but no detection or further is happeneding please guide what can be done ..
Hard disks do not like being dropped, there is nothing that can be done to repair it.
If you need the data off this hard disk, there are companies that can recover data off damaged hard disks BUT it will cost you an arm and a leg for their services.
May 09, 2011 | Imation Apollo UX 2.5" USB Portable (250...
Hi.My Imation Apollo 2.5" 500GB
With any luck, it may just be due to a loose cable or connection inside. You need to open the unit and make sure everything is properly connected.
Mar 14, 2011 | Imation Apollo UX 2.5" USB Portable (250...
Imation Apollo (27223) 250 GB USB Hard Drive Logo
271 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
Jax Planet
Jax Planet
carey w mason
carey w mason
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
