Question about Xerox DC440ST Copier
How to connect the machine to the computer for printing
  • 33 Answers
Be sure that you have network option installed. On top cover of the printer itself (under the scanner) you can see a floppy drive, can you? OK, then it is capable of network printing. Also parallel (Mini-Centronics) port will work.
You may try parallel printing first, it is easier. Download from
www.xerox.com/support drivers for your DC440ST.
Install driver. Connect parallel port to computer via Cenntronics cable and you'll be ready.
If you want to print from network you must have UNIX printing installed in Windows. You have to create a new port in the printer driver and create a print queue and name it "lp". Port address is also needed. For example 192.168.0.1.
To set up network address on the printer you have to log into the printer as administrator.
Press (key) button on the top right part of the keyboard.
On the touch screen enter: #22222 (hash sign and five 5's)
Enter "Networks settings" "TCP/IP" "network address" "STATIC" "192.168.0.!" for example" "SAVE" "QUIT" and the printer will boot.
You may have to ping for the network address to see if it responds. If the copier/printer prints out a config sheet in five minutes you can check the address and other setting you just did.
If the printer DOES NOT PRINT the config sheet it may be disabled in settings. You can log in again (key) #22222 and enable "print config sheet" + reboot again.
Posted on Sep 08, 2010
LAN connection gestetner 10512
connect the local area network cable to the port of the machine .
press the counter key
press system settings
press the interface key on the screen.
enter the ip aderess and other necessary things in the portions provided the machine.
now go to your computer and open printers and devices.
click on add printer
select add network printer.
enter the ip aderess you entered on the machine and the computer will communicate with the printer and it will will be installed automatically.
print a test page .
if the test page comes out successfully, you have successfully installed the printer.
you can now print your documents form that machine.
good luck.
Feb 13, 2014 | Gestetner 10512 Printer
MFC_5840CN Will not print, not showing
Typically, a Brother machine stops printing, because the connection between the computer and the Brother machine is lost. There are multiple reasons for a lost connection.
  1. The Brother print driver is Offline.
  2. The Brother printer driver is not set as the default printer driver.
  3. The computer, not the monitor, connected to the Brother machine is set to go into sleep or standby mode. When the computer goes into sleep or standby mode, the connection between the computer and the Brother machine is lost and needs to be re-established.
Follow the steps below in order to re-establish the connection between the Brother machine and the computer:
  1. Verify that the Brother machine is connected with a USB cable and is not on a network.
  2. Verify the power cord and USB cable are securely connected. If the USB cable is loose on either end, disconnect and reconnect the cable securely. Test the machine by trying to print. If the machine does not print, go to STEP3.
  3. Cycle the power of the Brother machine by unplugging the power cord from power outlet, wait approximately one minute and plug back in. Once the Brother machine displays the date and time after plugging it back in, test the machine by trying to print. If the machine does not print, to Step 4.
  4. Reboot the computer connect to the Brother machine and then try to print again.
Apr 01, 2008 | Office Equipment & Supplies
Toshiba estudio 255 Cannot usefunctions
you must connect the machine with you're computer.you want the fax you must check the you're photocopy machine have a fax board.you want the scan & printing connect the photocopy machine to the computer.(network cable)
Jan 27, 2014 | Toshiba estudio 255 Copier
NEED TO CONNECT MY PRINTER TO COMPUTER TO PRINT VIA WIFI
There are two ways to your problem:-
1. The printer is connected to another machine
Set up a Home WIFI system and then add a network printer on the machine that you want to print from. You however need to switch on the pc connected to the printer when want to print. If not sure on setting up a home WIFI system just check on the internet.
2. The printer is WIFI enabled
Just install the printer on your machine and make sure that your printer is hooked up to the WIFI network as well.
Jul 15, 2011 | Computers & Internet
I HAVE A SHARP UX-105 HOW DO I CONNECT TO COMPUTER; NO MAUNAL BOOK?
install winfax program on your pc.then when you want to print with your fax,inprint menu choose winfax,and then you can print .
Jun 07, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
How do i set up my copier to print from my computer in a network
First you have to have a network card in the machine. Get the print driver for the machine. Make sure your Lan cable is connected and working properly. Install the print driver on your  computer as you would on a stand alone printer and do a test print.
Apr 09, 2010 | Sharp AR-M237 Copier
Samsung SCX4200 All in One Printer-Document not printing even after print instruction given to print
Good Day Sir. These are the possible causes why your machine doesn't print.
  • The machine is not receiving power.
  • The machine is not selected as the default printer.
  • The connection cable between the machine and the printer is not connected properly
  • The connection cable between the machine and computer is defective.
  • The port setting is incorrect
  • The machine may be configured incorrectly.
  • The printer driver may be incorrectly installed.
  • The machine is malfunctioning
Hope this will help you. God bless.
Feb 03, 2010 | Samsung SCX 4200 All-In-One Laser Printer
What is error code 300 for Canon MX310
Error Code 300 is displayed.
1) Cause : The machine not ready.
Action : Confirm that the power lamp is green.
If the power lamp is off, turn the machine on.
While the power lamp is flashing green, the machine is initializing. Wait until the power lamp stops flashing and remains green.
If the Alarm lamp is orange, an error may have occured on the machine.
2) Cause : Machine is not connected properly.
Action : Make sure that the USB cable is securely plugged into the machine and the computer.
* if you are using a relay device such as USB hub, disconnect it, connect the machine directly to the computer, and try printing again. If printing start normally, there is a problem with the relay device.
Consult the reseller of the relay device for details.
* There could be a problem with the USB cable. Replace the USB cable and try printing again.
3) Cause : Your machine is not selected in Printer on the Print dialog box.
Action : Select your machine's name in the printer on the Print dialog box.
If your machine name doesnot appear in Printer, follow the procedurebelow to check that the driver for your machine is installed on your computer.
a) Select Print & Fax Preferences in Printer.
In Mac OS X. v.10.2.8 or 190.3.x, select Edit Printer List in Printer.
b) Check that your machine's name is displayed in the list of printers and that the check is selected.
In Mac OS.X v.10.2.8, check that your machine;s name is displayed in printer list.
c) If your machine's name is not displayed, click Add(+) to add the machine. If you cannot add the machine, follow the procedure described in youe setup sheet to reinstall the MP drivers.
Nov 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Pspcl drivers for ir400 machine
press the option switch
in screen press function
press print pages
print configuration page
see the ip address & install the printer on this ip
in your computer networks use tcp\ip is smaller than machine ip if machines ip is 192.168.1.33
computers ip is 192.168.1.32
Aug 15, 2009 | Canon imageRUNNER 400S Copier
Sharp ar c260m error code f9.00 print function out of service
F9-00 is "AR-NB3 communication trouble"
that is the NETWORK PRINTING / SCANNING
EXPANSION KIT. that is the box that hands on the back of the machine.
Aug 12, 2009 | Sharp AR-207 Copier
221 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
