Question about Bosch Nexxt WTMC 3300 Electric Dryer
Hi I have got problems with my Bosch Classixx electric dryer It runs for a few minutes and then it stops I have cleaned the filter system etc and looks as clean as a whistle It seems to stop as it appears to be changing "gear" !! Please help cheers norman
Clean the front under the lint filter has a sensor on the left near the lint pin. purchase a special long thin cleaner for vac from: All rand Vacuums 561-967-3575 GREAT
Posted on Oct 02, 2010
HAVE A BOSCH CLASSIXX CONDENSER DRYER KEEPS SWITCHING OFF AFTER A FEW MINUTES
Have you tried cleaning out the metal concertina-like element inside the bottom trap door? This clogged up caused mine to stop & also to drip some water on floor
Apr 17, 2017 | Bosch Washing Machines
Why my bosch classixx keeps stopping every 5 minutes
The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 13, 2014 | Bosch Classixx WVF 2402 Front Load...
Clean reg flashes
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 10, 2014 | Bosch Axxis Series WTB86201UC 24" Ventless...
I have a Bosch Classixx Condenser Dryer which wont turn on - have cleaned out the filter - checked the fuse on the plug - still wont turn on. The model is WTE84107GB
Check the door interlock, this could be sticky or broken.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Bosch Axxis WTL 6003 Electric Dryer
Hi! I have a new Bosch Dryer. We can't seem to get it to dry. It stops after just a minute with a linter filer light flashing.
i take it you have cleaned the lint filter if so then it has a bad sensor reader in the filter system
Dec 22, 2010 | Bosch WTMC3510UC Gas Dryer
Bosch WTL5400 Drier runs fine for 5/10 minutes, then it stops and the "start" light flashes. Pressing this then restarts the process, but a few minutes later it cuts out again. I have checked...
I have the same problem, the dial to select the dry program is making a bad contact causing it to stop. Try using a different program.
I tried to clean the dial but it didn't help.
Dec 06, 2010 | Bosch Axxis WTL 5400 Dryer
Hi Bosch classixx condenser dryer is not heating and drying ! cleaned out filter emptied condenser. HELP
Welcome to FixYa,
Based on your post it may just be the hi-limit has tripped. Here's what I'd do/check.
**Unplug the unit from the wall or switch off the breaker...safety first**
Once the dryer has been disconnected from any power, remove the rear panel...
i.e.
Once the panel has successfully been removed, you'll see the heater with the Hi-Limit and NTC attached. The Hi-limit is the thermostat with the red button in the center...
i.e.
push it in to reset it. As you can see by the images I've provided, if you have a multi-meter or ohm meter you can verify the proper values of the listed components.
If the hi-limit is tripped, obviously something triggered it, you can check the possible culprits such as the NTC's or heater with the info I provided above as I alluded to.
( Even so, I'd suggest running it through a cycle or two with clothes and monitor it's performance, it may have tripped simply due to poor air flow from a large load etc. and therefore nothing is actually wrong...human error )
You may run the dryer momentarily without the rear panel in place ( provided nothing electrical has been disconnected, don't attempt an entire cycle. ) just to witness the heater functioning, but it isn't recommended for much longer than a minute or two.
Thank you for choosing FixYa and please let me know what you find out or if you indeed require further assistance.
Good luck.
Regards,
Macmarkus :)
Dec 01, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Lint Filter
hi there,
i can understand your frustration. i have reviewed the information that i have from Bosch and they indicate that the lint filter indicator light should only come on as a reminder but should not shut off the dryer.
here is my recommendation and also a question:
the dryer is shutting off due to the fact that it's overheating. it's a safety precaution from the manufacturer and it's built in to prevent the lint collected in the lint filter, since it's highly flammable.
check the venting in the back or side, wherever it was installed.
the vent tube is often the cause for the dyer to stop functioning.
if that turns out to be okay, the dyer is equiped with a sensor on the heater. it is possible that it's opening due to the heat generated by the dryer that has nowhere to go.
does the display show any error messages?
can you tell me what they are?
thanks again
Sep 24, 2008 | Bosch Nexxt WTMC 6300 Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
252 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
