Question about GPS
Hi I have a Win CE . NET 4.2 Core Model no. GPS-352 (D1-32904) CE Brand. Unfortunately I do not have a manual for this device, I bought it back on dealsdirect.com.au in 2008. I need to update the map and cannot find out how to do it. Thanks
  • 504 Answers
SOURCE: GPS MAP QUESTION
No, Garmin will not provide map updates for free. You can update the unit's firmware for free from Garmin's website, but if you need new maps you must purchase them and download them into the unit. It should not be necessary to do this right away, though. Even if the unit does not have 2008 maps on it, unless there are major changes to the areas you travel most, it should get you around fine until you do decide to purchase updates.
Posted on Mar 26, 2008
  • 107 Answers
SOURCE: Screen defaulted to Win CE
well, I had a similar problem once, I managed to get the unit to relaod the map data using my repair dvd but I cannot guarantee this will work in your case. if your unit still has the basic operating system intact, you shoudl be able to boot it with the firmware update in the SD card and it will load, however, someone else told me they were not able to do this becasue the unit would never try to boot from the SD card. it was basically a brick.
One solution is to visit C&C wireless and pay over $100 for a map update or even send them your unit for even more $. see http://www.finedrive-acc.com/shop.cart?action=ITEM&prod_id=F400-08CP
The other solution was to send it to Fine Digital but they closed their doors in the US so they no longer support us customers. Because of this I made a DVD with map data I purchased from them before they closed and I added much better instructions; this DVD updates the firmware in the unit and loads the last map data issued to the SD card. you would need a PC with a DVD drive and SD card reader to use it. you can find these DVDs on ebay for $18 which basically covers my costs only.
Posted on Dec 02, 2008
  • 121 Answers
SOURCE: my gps freezes 20 secs after starting the only
if it's tomtom,garmin,mio,megalan or asus
reset the button with a pin
for tomtom
press the power button for 15 sec
Posted on May 05, 2009
SOURCE: Magellan Maestro 4250 2008/2009 Map Update will not update my GPS
I also had problems with a refurbished Magellan 4250. The paperwork inside said to install the 4.85 firmware update which I found would not work with Windows XP Home at least for me. I used my laptop which has Vista Ult 32 bit it updated with no problem that is so far the only solution I used.
Posted on May 19, 2009
  • 13433 Answers
SOURCE: gps fun findel model p-100
hi,
is there a question in there?
Posted on Oct 25, 2010
Why does my Nextar gps system takes foprever to load when turn on
If it is running Win CE then it is VERY old. The GPS is probably failing to see the satelites. Probably time to replace it.
Aug 02, 2016 | Nextar w3g-01 3.5"" touchscreen portable...
I just bought my first GPS, the Garmin Nuvi 255WT. It is a basic model but gets me where I need to go and I'm happy. However I'm concerned about the voice distortion. When on the freeway I need the thing...
Although yours is a wide screen device, as the GPS devices getting smaller the sound is getting crappier. Larger units of the old days like C330 had much better sound than the smaller Nuvi series because they had more resonant cavity for the speaker which increases acoustical efficiency of the speaker...
I can not imagine a brand new Garmin GPS having defective speaker... So unfortunately, you need to lower your expectations. Unfortunately, this particular GPS doesn't have external Audio connectivity for considering to connect the GPS to your car stereo, for better sound.
Feb 25, 2011 | Garmin GPS
Hi im looking for info on how to flash or load windows ce on a neoware ca5 thin client, i have downloaded the Os but have no clue how to load it on the thin. can you please assist me
  1. Make a bootable USB drive using HP Drive Key Boot Utility (via bootdisk.com Method 2)
  2. Format the flash disk in the device.
  3. Make the flash disk in the device bootable using MBRTool (This is necessary if you installed GRUB on the disk. The MBR needs to be overwritten)
  4. From the Win CE installation folder, from drive:\<path to wince installation>\PLATFORM\CEPC\SRC\BOOTLOADER\DOS\BOOTDISKcopy all files and paste it to the flash disk in the device (These files always comes with Win CE installation)
  5. Put your build of Win CE - EBOOT.BIN in the flash disk on the device (This will be your custom Win CE image)
  6. Remove the USB drive, and boot the device. Your new build of Win CE should boot up.
Aug 26, 2010 | Computers & Internet
My gps need install windows ce but install because I connect the cable to the computer but the computer gives unknown device message
If you GPS is at the point of needing windows CE installed then it is in a bad way. This is not done in the normal way on the Mitac Mio. It is setup using and SD cardspecific keys assigned by mitac to perform only a minimum of functions for its GPS hardware.LikeRESET +POWER then selecting different options specific to the GPS
Then getting maps on it is also different from a straight install. I suggest you contact MIO and have them reinstall Win CE and the maps for you before you compromise it totally so that it cannot be undone
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Mitac Mio P550 GPS Receiver
My gps freezes 20 secs after starting the only way to stop this is to flick to menu and back again, what can i do ???? thank-you. running on win ce 5.0 core arm 4.
for tomtom
May 04, 2009 | GPS
Hi I need tomtom ONE GPS manual my dad gave me his and he bought a new gps for is car but he can't find the manual for this one. I checked his but it's not the tom tom brand
Go to the web page below, find your particular model and download the manual.
http://www.tomtom.com/support/support.php?ID=3
Peter
Jan 23, 2009 | GPS
GPS Error Message on Start Up Model GM-7-1
sounds like your firmware or sd card is corrupt, unfortunately this is common on these. I created a dvd with the map and program data to reload everything in your unit, it also updates the map data to the last version issued. you can find it in ebay by searching for finedrive 400 map...
Jun 01, 2008 | Fine Digital FineDrive 400 GPS Receiver
Gogo plus navigator
gogo cm310 software updates
Apr 17, 2008 | GPS
GPS Logo
41 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
