Question about HP Photosmart C3180 All-In-One InkJet Printer
HP C3180 error - no error number, just blinking lights and an E. Driving me crazy!!!!!
Scan function not working
I have had issues with HP scanners myself. The way I deal with this is to use the scanner and camera wizard in XP, it recognizes the device and scans even over the network. Works every time for me.
If you need more help let me know I CAN solve this problem, let me know.
Jim
Aug 05, 2009 | HP Photosmart C3180 All-In-One InkJet...
Hp 3180 print cartridge light blinking
hi,
is the ink cartridge you replaced hp brand or did you refill it this is an incompatibility code from the software. some brands and cartridges are not fully compatible and creates an e code error code. if it is hp brand it is likely a defective sensor chip in the ink cartridge. i would for best assurance return the cartridge for a different one and then recheck. if niot you may need to restore your software or reinstall it most of the time this will fix the problem.
hope this helps..happy computing!
Mar 29, 2009 | HP Photosmart C3180 All-In-One InkJet...
Color cartridge blinking
ok take out the colour ink cartridge clean the contacts that is the copper dots on the ink cartridge also the point of contact in the printer after that the printer should not give that error messase if it sill persists replace the ink cartridges .....
if they are new ones call HP Tech support they will replace it free for You
Mar 04, 2009 | HP Photosmart C3180 All-In-One InkJet...
When try to print the check paper/ink cartridge light blinks and printer wont print.
If both the Check paper, and the Check Cartridge Lights are blinking, this indicates a Carriage Jam. Follow the instructions here to clear this error.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&rule=8471&product=1146331&docname=c01447224
Dec 29, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP C3180 problem with black ink cartridge
This is news to me. I would contact HP on that because if it is the case, they can get you the correct ink. Those numbers on their are usually the same accross the board. Being that I sell HP supplies, I wasn't aware of this.
Jun 22, 2008 | HP Photosmart C3180 All-In-One InkJet...
Flashing lights.. when i turn power off it just does same thing
All lights flashing indicates a "fatal error" condition, so the printer just needs to be reset:
1. Turn the HP c3180 off.
2. Unplug the power cord.
3. Wait a minute, then plug the power cord
back in.
4. Turn the HP c3180 back on.
This should clear the system error and restore the printer to its "out-of-the-box" default settings.
Feb 26, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
648 people viewed this question
Seeker5211
Seeker5211
