Question about Kenmore Refrigerators
Freezer side is working normal. Refrig. is not cooling .temp set is on more cool side. I cleaned condenser. Light bulb off during closing.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 08, 2010
  • Alexander Mimun
    Alexander Mimun Sep 08, 2010
    Check heater in freezer, will sit under evaporator, looks like a halogen bulb, but don't light up, more then likely, the evaporator is froze, so no air from freezer blows into refrigerator, heater should cycle 4 times with in 24 hrs, back panel of freezer will have to be remove, to replace heater, part runs about $40.00, hope this was helpful.
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
The strip between freezer and refrig become hot then cools off. It's like it is going thru a cycle. We cleaned the coils underneath, but it is still getting hot and then in about 15 minutes, it's...
When you cleaned the coil underneath did ya notice that their was air being blown out their by a fan,having clened the coil was a good start but if the fan by the compressor isn't running that divider between the ref/freezer will be hotter than normal( its normally warm and thats ok),so check that the condenser fan is running and that it seems to running at a good speed.
GENE
Sep 23, 2011 | Whirlpool GC5SHEXNS Side by Side...
Refrig. stopped cooling then the freezer side. then started back
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Temp light does not light up and temp does not get cold. inside door latch is broken model #pfs22sisbss
The main control board could solve the display problem . May also solve the cooling problem , but would need to know , if frost build up on back wall inside freezer , are both fans working (freezer and compressor cooling fan) , is the compressor running ,are the coils clean in back of refrig ? Unsure about a "door latch" . The freezer door ,rides on glides , and the magnetic gasket should hold it closed .
Jul 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Frig won't cool, freezer works fine
Defrost unit completely. You're frosting up. Then, avoid leaving the door open, leaving liquids and food uncovered. Clean condenser coils. If it happens again, you need refrigerant.
Jun 09, 2008 | Refrigerators
Sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
Jan 29, 2008 | Sub-Zero 650 / O Bottom Freezer...
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
