Question about Bugaboo Frog Stroller
The clip that fixes onto the side of the handle bar of my Bugaboo Frog is broken (the clip that the break lever is attached to). Do you know where I may order a replacement part?
    Guru:
  • 541 Answers
Try these people in Australia <lisle@karlisles.com.au>
Posted on Nov 03, 2010
I don't know how to reverse the handlebars on the stroller.
The handle has two white release buttons, the one on the side opposite of the break lever has a smaller safety release button. You have to push the safety release button in than pull up on both release buttons. This whole handle lock assembly can get quite stiff without proper lubrication. Check my tips section for best ways to maintain your Bugaboo.
Feb 08, 2011 | Bugaboo Frog - Black Stroller
On the right side of my bugaboo cameleon;the break side the black piece where the white clips are to adjust the handle bar. From being mad taller or shorter is off and the sprang came out and the handle...
The handle extension lever is held in by the pin it pivots on, cut the tip of a smaller size nail and use it to tap out the pin. There should be a rubber block and a matching steel shim under the lever. The lever pushes on the shim and the shim on to the rubber block jamming it against the handle. The steel shim is the usual problem. it slips out. Open the other side and use that shim to get a copy cut. A piece cut out of a tin can could work.
Nov 19, 2010 | Bugaboo Cameleon Jogger
Hello! I have a Bugaboo Frog but the handle bar has been broken ( the small plastic clip at the end of the bar ) I just don't know where can I buy one!!!
Fill it up with a Quick fix material and cover it with a solid broad Tape - cheap and best solution though it is temporary
Jun 29, 2010 | Bugaboo Frog Stroller
I just got a used bugaboo stroller and i am having trouble figuring out how to rotate the push bar up
there are two clips one on either side of the handle you need to press them in together and the handle will move up and down. Or go to www.buggypitstop.co.uk and ask them they are experts on bugaboo and I'm sure they will help you
Nov 11, 2009 | Bugaboo Frog Stroller
Bugaboo frog and wheeled board not fitting??
Had exactly same experience today. I emailed Bugaboo (via website) and got a reply the same day.
I attached the clips the wrong way round. The picture in the manual is not very clear....The little 'roofs' have to face each other and than you are able to push the clips further over the axle. The slot of the clip fits over where the small wheels comes in on the bar.
Hope this helps.
Jul 26, 2009 | Bugaboo Frog Stroller
How do I collapse bugaboo stroller
take off the basinette or seat
then, there are 2 knob, sticking out of the sides of the frame, about 6 inches below the handle, from the normal pushing position, hook yr fingers round them and slide them up the frame towards the handle
the handle will drop, then just up the frame from the cross bar under where the set is.
easy once you know how
if it still don't work, go to your local park and accost the nearest person with a bugaboo and ask for some help - there'll be hundreds of them!
Jun 21, 2009 | Bugaboo Frog Stroller
Bugaboo Frog Handle Bars Not Locking into place
Try to contact Bugaboo Service 1-800-460-2922 or serviceus@bugaboo.com
Jan 07, 2009 | Bugaboo Frog Stroller
Bugaboo cameleon handle bar
HIYA.... YOUR BEST BET IS... TAKE THE HANDLE BAR BACK OFF AGAIN. TAKE THE SPRING OUT OF THE SIDE THAT WORKS FINE AND TAKE IT TO YOUR LOCAL DIY STORE AND GET A REPLACEMENT, IF YOU CANT FIND IT ASK SOMEONE IM SURE SOMEONE WILL BE ABLE TO SEND YOU IN THE RIGHT DIRECTION... PROVIDING ITS JUST THE SPRING, IF YOU BUY ANOTHER TO REPLACE THE BROKEN/LOST 1
THIS SHOULD SOLVE THE PROBLEM :)
Dec 08, 2008 | Bugaboo Frog Stroller
Bugaboo Frog Foam Handle ripped
On Ebay, if you type in Bugaboo on the search field, there is an item called Stroll-air that covers the handle bar. I think it's made of neoprene (like wetsuits) or something that looks like it.
Jun 24, 2008 | Bugaboo Frog Stroller
Handle bar issue...
CONTACT BUGABOO
PHONE: 1-800-460-2922
E MAIL: service@us.bugaboo.com
WEB SITE: WWW.BUGABOO.COM
Aug 13, 2007 | Bugaboo Frog - Aubergine Stroller
Bugaboo Frog Stroller Logo
102 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
