Question about HP Compaq nc6120 Notebook
Trying to locate the battery in the back of the lap-top
My lap top its not responding to power button and i cant start my lap top
Unplug the battery and the power cord. Hold down the power button for 30 seconds. Plug back in the battery and power cord. Try powering on the laptop. If it powers on you are good to go. If not try contacting Lenovo support.
May 31, 2014 | Lenovo 3000 G530 Notebook
Your account has been locked
Easy solution but sometimes hard to do because of close quarters.What you need to do is locate the watch battery inside of the lap top.It may be under one of the back panels but not all ways.If you have to open the case it is super easy to break something and some will only open an inch because of a small electric ribbon hooked to the top board.What you do is remove the watch battery for ten minutes and then put it back in.Be sure and ground your self by touching the metal frame because if you have any static electricity and it jumps to the mother board it will fry the motherboard.If your not handy with delicate work I would take it to a technician. Good Luck. Easy solution but sometimes hard to do because of close quarters.What you need to do is locate the watch battery inside of the lap top.It may be under one of the back panels but not all ways.If you have to open the case it is super easy to break something and some will only open an inch because of a small electric ribbon hooked to the top board.What you do is remove the watch battery for ten minutes and then put it back in.Be sure and ground your self by touching the metal frame because if you have any static electricity and it jumps to the mother board it will fry the motherboard.If your not handy with delicate work I would take it to a technician. Good Luck.
May 19, 2011 | HP Pavilion dv6000z Notebook
Need to reset password on samsung nf210 without back up disc
May 15, 2011 | Samsung NF210-A02 Netbook
My averatec lap top os stuck in sleep mode
Hi. I suggest you try pressing the power button to wake it up or you could also try power draining it and turting it on. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. Hope This Helps
Jun 02, 2010 | Toshiba Satellite M100 Notebook
My lap top wont turn on i have a blankj screen the
Please try these. After on your pwoer botton wait 2 minites and the press FN+F6.
Let me know what happening.
Thanks.
Jan 30, 2010 | Acer Aspire 6920 Notebook PC
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
Display problem
the best thing to do is to get the help of a qualified technician(better go to a toshiba service centre)
they will help you with this.
try removing the battery after turning off the computer and removing the power supply.reinsert the battery and turn on th notebook. it should work fine.
else contact the technician.
Dec 03, 2008 | Toshiba P25-S676 Notebook
Lap top not turning on
Try removing the battery, waiting 30 seconds, then plugging it back in. Plug in power cord and try to turn it on.
Feb 02, 2008 | HP Compaq Evo n610c Notebook
Accer 3500 series
looks like you need a new battery
or have that one reconditioned
Nov 04, 2007 | Acer Aspire 3000 Notebook
HP Compaq nc6120 Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
