Question about Kenmore Washing Machines
My washer give an error code F-71 coukd you help
  • Udhaya Rajan
    Udhaya Rajan Sep 08, 2010
    Please give the model number of your washing machine
    Thank You
  • pleighton26 Sep 08, 2010
    the model # is 110470876OO
    President:
  • 1,932 Answers
Posted on Sep 08, 2010
  • Udhaya Rajan
    The F71 error code indicates a user interface heartbeat failure
    Check the continuity of the user interface harness
    Check user interface harness to central control unit
    Replace user interface if drum is rotating
    Repalce central control unit if drum is not rotating
    Thank you
    Hi i appreciate the information thanks
I'm getting an f 71 code on myKennmore elite smart wash steam care quiet pak 9 HE5T. What does that mean?
the F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit." from here. Hope this helps, good luck.
Apr 15, 2015 | Washing Machines
The washer has been displaying error code F 71. We unplugged the washer for a few minutes and plugged it back up but now it will not come back on at all.
Hi
F71 is a communication error and is displayed when there is no communication from the User Interface to the Central Control Unit. First check the user interface harness for continuity and then check the wire harness to the user interface and CCU. If the drum rotates then replace the user interface, if the drum is not moving then replace the central control unit (CCU). Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
We have a duet washer wfw9200sq00 and it won't power on - just gives 3 beeps. I did get a F71 error code
F-71 user interface heartbeat failure, com failure between touch pad and central control.
You ain't sitting goopy liquid detergent on top of the washer is ya? Stuff goes down into the controls and oopzy. themobilian_2505.jpg
Service manual for duet with repair photos
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code f 71
Check to see whether the laundry drum to the washer moves. If it does move, then the user interface needs replacing. If the drum is locked and will not move, you need to replace the central control unit on the washer.
Read more: Whirlpool Duet Error Code F71 ' eHow.com http://www.ehow.com/facts_7618431_whirlpool-duet-error-code-f71.html#ixzz1AANUprMm
Jan 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
1994 4Runner V6 (non-4wd) error code 71
2.4L code 71 - EGR Gas Temp Sensor
3.0L code 71 - EGR Gas Temp Sensor
There is a test procedure to tell if bad sensor or wiring problem, can email diagram to you if like need an email address to send to
Feb 08, 2010 | 1994 Toyota 4Runner
GOT ERROR 71 PLEASE HELP
any of the error 7X codes are to do with the fuser. Call an engineer
Jun 04, 2009 | Brother MFC-8220 Fax
WHAT IS A2DP PTS MODE?
I HAVE A GFIVE E 71 PHONE I AM NOT ABLE TO USE BOTH SIMS INCOMING FACILITY AT SAME TIME , THE ERROR MESSAGE WHICH IT GIVES IS " DISABLE SWITCH MODE", CAN ANYBODY HELP ME IN DISABLING THIS SWITCH MODE , OR GIVE A CODE TO IT , THIS IS A CHINESE NOKIA TYPE GFIVE E 71 MOBILE
Mar 18, 2009 | Nokia 6300 Cell Phone
Whirlpool Duet front load washer won't start
The error codes it is showing don't even exist. Does the little round door latch plunger go in and out if you push it?If not, then replace the door latch. If so, you most likely have a bad machine control. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Brother 4100 fax error code # 71
Error 71 is a laser scanner error.
Inkworks
866-381-0541
Nov 19, 2008 | Brother IntelliFAX 4100 Laser Fax
Machine error 71
Error code 71 -- ( Polygon motor does not synchronize with the reference clock. ) What ever that means - hope that helps.
Mar 20, 2008 | Brother MFC 9700 All-In-One Laser Printer
Washing Machines Logo
122 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
