Question about Amcor PLM-14000E Portable Air Conditioner
My AlP-12000 EH Portable Air Conditioner blows hot air
  • 388 Answers
Dear sir
please test your aircon with digital temperature meter i mean take first room temperature data then check your aicon flow air temperature it should be lower than to 20-22 degree Celsius if it,s not low like this
then it can be low freon problem in your aircon system.
thank you
hope answer the question
Posted on Sep 25, 2010
SOURCE:
Control panel lights on whynter 12000 btu portable air conditioner .can't read some numbers
This is due to the detrioting condition of the display, sometimes an even lite press with fingers on the display may help. This happens due to loss of contacts inside due to poor quality of display or aging.
Oct 13, 2015 | Whynter ARC-12S ECO-FRIENDLY 12000 BTU...
My kenmore 12000 btu portable air conditioner keeps switching to DH mode out of AC mode
That means that it is dehumidifying. Is the air coming out still cold? I assume you have tried using the mode button to switch it back? Is the air extremely humid? Perhaps it is humid enough that the machine needs to dry the air before safely operating as an AC. The manual is available here:
http://www.sears.com/kenmore-portable-room-air-conditioner/p-04272012000P
Jul 05, 2015 | Kenmore Portable Air Conditioner 10000 BTU...
Ac repair portable 12000 btu unit will not blow cold air
Maybe you have it set on dehumidifier mode instead of air conditioning mode. That happened to me with mine too. And turn off your timer (if it has one) or it will shut off after a while and you will forget why.
Jul 23, 2013 | Amana Portable Air Conditioner
Amcor portable Air conditioner replacement exhaust hose
I am also looking for a replacement hose for my amcor nanomax portable ac 12000 btu. If I locate one, I will let you know
Jun 26, 2013 | Amcor Heating & Cooling
Window kit dimentions i have a window 18 inch wide
The portable AC units generally have a customizable, exhaust hose window, termination kit that comes with the unit.. In other words it can be cut to fit. The one that comes with the unit will fit casement windows, as well as sash windows.
To further assist you, I have included a link to the Owner's/Installation Manual for the model you referenced. You may download and print it if you like.
http://www.air-conditioner-home.com/manuals/ac-12000.pdf
Hope this helped you. Please let me know. Thanks.
Jun 13, 2011 | NewAir AC-12000E Portable Air Conditioner
The air conditioner is blowing hot air, there is no water to drain
if it is also blowing cold air out of the other vents you need to vent the hot air its blowing outside
Sep 30, 2010 | NewAir ACP-1000E Portable Air Conditioner
Does anyone know how to add freon to a Amcor PCMB-12000 EH Portablle AC?
All i can tell you is the system is a sealed system and you need to install line taps on the suction line. It is the larger one on the compressor. Like i said before you can not buy R-22 with out an epa card. That is how you would charge the system, low side line tap.
Jun 12, 2010 | Amcor PLM12000EH Portable Air Conditioner
Hot air coming out of back
portable air conditioners mainly have two hoses one hose is exhaust thats the one that is blowing hot air. the one pulling is return.. the hot air blowing out should be exhausted to the outside. the blowing air needs a hose and to be laid out a window the back should have model and serial maybe product number. the two holes are either 4 inch or three inch and most portable units other than hand me downs come with a window frame that allows the hot exchanged air to go outside and cooler air to be used for heat exchange.
May 28, 2009 | Maytag NMPEB08F2A Air Conditioner
Amcor PLM-14000E Portable Air Conditioner Logo
126 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
