Question about Sony FD Trinitron WEGA KD-36FS130 36" TV
My television not switching on ive cheched the power supply but there is no b comming out
Power supply fault
hi i would say more than likly bad caps
Mar 16, 2014 | Televison & Video
Ive got a 37inch lg tv and keeps switching itself of
I would be checking the power supply inside the unit. Many LCD have been plaqued with bad eletrolytic capacitors. These capacitors are located on the power supply. Over time,age,use and other issue like heat these tend to just give out. Read my tip on how to have this fixed.
http://www.fixya.com/support/r3565137-lcd_flat_screen_common_problems
Now if you rather not mess with it then a local repair shop can take care of that for ya.
Thanks and please do leave postive feedback and ratings for your free answer today.
Jun 14, 2010 | LG RZ-37LZ55 37 in. HD-Ready LCD...
Blinking green light for 5 minutes - then light goes out - no power. This is exactly the same problem as the others. The TV is only 2 years old! What should we do?
I had exactly the same problem My TV is a 20 PF 4121/05 flat screen, but it may work on yours. When the TV was switched on all I could see was a flashing green light. After cheching the TV internals and not seeing a problem including the power supply unit which looked and checked normal. Here is what I did to get M TV working again.
Disconnect it from the power supply. Hold down all the buttons simultaneously i.e. the on/off, the volume, the programme, menu buttons, all of them simultaneously and Plug it into the power supply again.
Lo and behold My TV jumped back into life after an absence of about 4 weeks.
Try it yourself exactly as above.
Best of luck.
Irishfreethinker
Sep 21, 2009 | Philips Magnavox 42MF521D/37 Television
Phillips Flat TV Model 20pf4121\105 (Flashing green led)
I had exactly the same problem When the TV was switched on all I could see was a flashing green light. After cheching the TV internals and not seeing a problem including the power supply unit which looked and checked normal. Here is what I did to get M TV working again.
Best of luck.
Irishfreethinker
Jul 10, 2009 | Philips 20PF5120/01 20 in. EDTV-Ready LCD...
Philips 20PF4121 LCD tv no picture but flashing error codes
Best of luck.
Irishfreethinker
Jul 09, 2009 | Philips 20PF5120 20 in. EDTV-Ready LCD...
Philips tv 20pf4121 doesn't turn on
Best of luck.
Irishfreethinker
Feb 10, 2009 | Philips 13MDTD20 13 in. TV/DVD Combo
Plasma tv won't power up after lightning strike
are you sure you seen all the fuses on all of the boards, (they are numerous, and hard to spot, not like fuses you are used to looking for.) if so then your power supply is at fault and must be replaced.
Mar 30, 2008 | Televison & Video
Not fixed
power supply and possible horizontal short ,chech power supply if ok check horizontal o/p transistor if ok check the damper diodes for shorts,by the yoke plug./
Aug 22, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KD-36FS130 36" TV Logo
74 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
