Question about Samsung HL-P5063W 50" Rear Projection HDTV
Tv shuts off after 20 minutes of use. Tv button reads...STAND BY TEMP in red???
    Brigadier General:
  • 3,006 Answers
Your tv is overheating and so shuts down to avoid damage. Although I'm unfamiliar with your exact model, the usual causes are either incorrect positioning of the tv (too near a heart source or with a casing vent too close to a wall or another obstruction); the casing vents or internal components have become dust-choked (very common); or finally one or more cooling fans have failed. Just like pc's these types of tv's use fans to actively cool them down and they sometimes wear out.
Some of these faults will be obvious and easily remedied on a DIY basis, but if the fans have failed then the parts are usually cheap and easily replaced by a qualified tv repairer.
Posted on Sep 08, 2010
Replaced lamp on mitsubishi wd62527 worked for 10 minutes then shut down. Now red lamp light is on
If the red indicator light on the front of your HDTV is glowing a solid red, you should first unplug the AC cord from the wall power outlet and wait for 60 seconds before reapplying power to the HDTV.
After you turn the TV on, if it doesn't power up, try holding the power button down for at least 8 seconds. That's supposed to force a system reset. If your model has a system reset button, use that instead. Press the reset button for about 20 seconds...release it and press it again for 20 seconds, release it again and the led will blink just for a minute or two. You should now be able to turn the TV on.
If after several attempts, the HDTV has not fully powered on and the LED on the front of the HDTV is still glowing solid red, you may want to reseat the lamp.
If reseating the lamp has not resolved the issue then your next step is to order a replacement lamp.
Apr 05, 2015 | Mitsubishi Televison & Video
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Sony kdf50e2000 shuts down after 20 minutes, then 3 red blinks
This is the cause; 3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
May 06, 2017 | Sony Televison & Video
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
MY SAMSUNG HLR5067WAXXAA PROJECTION TV JUST
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
Oct 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
My flat screen tv does not have a picture or sound. The stand by red button is on once we press the power button the picture will come on with a message that reads digital television for about a second or...
I've had the same problem with a 32" model LC320EM82S. All the Emerson TV ( no matter what size ) are having the same issue.
I'm sure with your TV, the green light is blinking before the TV automatically turns OFF. Basically, the TV is trying to power up the screen and has failed. Protection mode turns the TV OFF to prevent other parts from being damaged inside.
My solution for fixing my TV was replacing one bad inverter transformer of six on the Backlight Inverter/Power Board. Here is what my board looks like: 767c946.jpg
You can see the six inverter transformer on the bottom of the board. It's what supplies power to the screen. Your board may look similar. You can sometimes find a whole replacement board over the internet for a good price. Shopjimmy.com is a good place to start. Just start searching by your TV model number.
If you have some electronic experience, you can repair the board itself by finding a Service Manual over the internet for less than $20. It will have all the part numbers, schematics, and diagrams you need. I would investigate the inverter transformer for your problem.
I hope I helped you out with your problem.
Sep 03, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
Tv shuts off, red status indicator lamp flashes.
Your main boards are bad. The FMT, DM, & Power Supply. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor
Jan 17, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Tv will not stay on only for 1 min. then turns red and off
Symptoms shows Red Tube is defective and needs replacement.
Please confirm model number with serial to look for Red Tube in stores.
Thank you.
Dec 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
115 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
