Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
My system is only 2 years old & has recently started turning itself off & when I try to restart it, it will show up the 88 numbers but not allow me to put in time cycle when I push down on the button, it also seems to be a little warmer to touch.
    Problem Solver:
  • 10 Answers
Had the same thing happen to mine. In my case water got into the controls somehow. This showed up as steam and or water droplets showing up on the inside of the display screen. If you see the same thing than that is probably the problem for you as well. Unfortunitly had to replace mine. Hopefully yours is not the same problem.
Posted on May 10, 2011
Idle Problems
IAC Idle Air Control --solenoid valve near the
throttle body
He can remove it & try cleaning it or replace it,IF it is just
an idle control issue
You can not have spark plugs in the motor for years
They should be changed every three years & clean any
ignition rotor & cap, if you even have that,may not
If you have never changed the oxygen sensor, that would help
Clean MAF Sensor & replace the air filter
Keep in mind that fuel pumps do fail,so don't run it out of fuel
& expect that some day if you have starting issues, to check for
a good battery & then fuel pressure at the motor
Mar 14, 2014 | 1999 Oldsmobile 88
88 chevy sprint just dies taking hard left turn & wont restart for 25+ mins.
hav u replaced the fuel pump--some cars with old pumps are sensitive to turns--git a fuel pressure test done to confirm
Jun 03, 2013 | Cars & Trucks
1989 Oldsmobile Regency 88 - stalls and sputters
Hi All your love, Lucky boy, The vehicle is fairly old and I suspect it has a points and condenser ignition system. Renew the points and replace the condenser. Set the gap to .45 mm and then set up the firing position by loosening the distributor locking base and setting it at 6 degrees before top dead center. I think it is not a fuel problem but instead, ignition timing. Regards John
Jun 30, 2012 | 1998 Oldsmobile 88
1989 Oldsmobile Delta 88 Royale won't start. Do I need a new battery?
YES. you need to take your battery to O'Reilly's, Autozone, Advance Auto and have the CCA's checked..(Cold Cranking Amps)..this is the only way to know if your battery is good..they will show you..get a new..enjoy...
Sep 12, 2017 | 1989 Oldsmobile Delta 88
My LG KC 910 is less than 2 years old and has recently started turning itself off in the middle of a phone call and while sending text messages. The battery shows that it is fully charged when this...
maybe the phone dies due to bad battery or poor battery connection.
remove the battery and clean the contacts.
consider buying a replacement battery
Apr 29, 2011 | LG KC910 Renoir Cell Phone
I have an APC XS1300. One year old. Very few
Mines, two or three years old and doing the exact same thing, you ever figure out what happen or how to fix it? I took the battery out and it reads 16 volts. I put a 2 amp load (fan) on it and it pulls fine, so I'm reluctant to buy a new battery pack for it now.
Feb 01, 2010 | APC BACK-UPS XS 1300VA LCD 120V...
This has been an ongoing issue for the last 2-3 years now. First the car would all of a sudden not start. We'd wait 10-15 minutes then try again and it would start. It began happening more frequently. ...
Maybe resetting the theft system. To do this you need to get in the car, turn everything off, turn the key to on, wait about 10mim or so till the light stops flashing, them turn key to off and back to start engine.
Nov 17, 2009 | 2000 Saturn Ls 4dr Sedan
1988 Oldsmobile Delta 88 (Vin "C") won't start, won't turn over
the 12 amp is for a jump start and the 2 amp is for a trickle charge which doesn't degrade the battery. i believe you have a loose connection either a loose ground cable or the positive cable to the starter check these and tighten if neccessary
Apr 18, 2009 | 1988 Oldsmobile Delta 88
Ps3 freezes before getting to main menu!!
Try Accessing the Ps3 Recovery Menu
Turn off Ps3
Hold the power button down; the system will turn on and turn off once again
Once the system has been shutdown, re-press your finger until you hear 2 consecutive (quick) beeps
When you hear the 2 beeps take finger off power button
You will be prompted to plug in your controller via usb and then hit the ps button
The recovery menu will pop up
Recovery menu
* restart system
* restore default settings
* restore file system
*rebuild database
*restore ps3
*system update
Now I was not sure which one to choose. I clicked restart system and that did NOT work so I clicked restore ps3 and lost everything but it DEFINITELY WORKED!!
Nov 02, 2008 | Sony Playstation 3 (PS3) Console
Shuts down, then restarts itself
That can be caused by a number of things , your best bet is to take a look @ this guide...since there are so many things it could be , this breaks it down to make it easier to figure out where it is coming from:
http://www.aumha.org/win4/a/shtdwnse.php
Hope that helps you out!
Oct 07, 2008 | E-Machines etower 500i PC Desktop
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
21 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
