Question about Samsung SyncMaster 152N 15" LCD Monitor
Hi have syncmaster 152v monitor used to work fine no probs moved it to another room switch it on flashes green always wont go away no picture just where the on off is just flashes green
SOURCE: Monitor not switching on.
Sync753s Monitor power switch problem.
I have to press monitor power switch to on my monitor, but occasionaly it works. Once On without any problem it is working. What will be the problem.
How to solve this problem ?
Posted on Jan 07, 2008
stabelabel
  • 51 Answers
SOURCE: Samsung SyncMaster 730B monitor green color problem
video controller card has gone bad need new video controller card.
Posted on Mar 16, 2009
  • 225 Answers
SOURCE: monitor will not turn on and the green light just flashes
There's an internal hardware electronic part/s of your samsung syncmaster 930 that is cold soldered / defective. I suggest to bring the unit to an authorized service center to fix the problem. regards
Posted on May 30, 2009
romsky79
  • 822 Answers
SOURCE: green light just flashes on and off and there is no displ
try to check your screen resolution maybe not compatible to your System. if green flashing there no signal from cpu to VGA cable monitor.
Posted on Jun 07, 2009
  • 1684 Answers
SOURCE: Samsung SyncMaster 710N Monitor SLEEP MODE
The monitor is not going to sleep the power supply board is shutting down. If you can solder you should be able to repair the monitor yourself. The problem is caused by blown capacitors on the power board. Go to our web site at : www.ccl-la.com/badcaps.htm We have pictures of what to look for. Open your monitor and look at the power supply board for any blown capacitors, replace all that you find. The replacement parts can be ordered from several places on the internet or we can supply them for you. The replacement parts will need to be high temp and will be marked 105c. The values you need to get will be marked on the sides of the ones you take out but will be something like 220uf, 470uf, or 1000uf etc. and then a voltage rating. When you install the new ones be sure to insert them with the polarity stripe going the same direction as the old ones come out. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. If you have any questions just let us know
I hope this helps if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Oct 24, 2009
I have a Samsung LED computer monitor (model S23A300B). The monitor connects to my Macbook air. The Samsung monitor recently stopped showing the picture on my laptop. Instead, red, green, blue and white...
Try the plugging the setup into a different monitor to eliminate the lead however it sounds like the monitors died. With cost of screens even if you can get hold of one you'll be better off getting a new monmitor.
Jan 20, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
Have A Samsung 940Bw connected via DVI connection and has worked fine for last 3 years. Monitor was on and working fine went out of room and came back to black screen and the blue light flashing on the...
First thing I would try will beusing this monitor with another PC using the same the same setup to see if it works OK. We need to narrow down the cause of the problem first since you have three parts that can be bad; Monitor, DVI cable, PC Video card/PC. It is just a process of elimination to locate the problem.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 14, 2011 | Samsung Syncmaster 940BW LCD Monitor
Syncmaster 152v repeatedly pops auto adjustment window
HI,
If you've changed the monitor recently, have you checked to make sure the Sync rate is not to high for the montior?
Steve
Nov 28, 2010 | Samsung SyncMaster 152 B 15" LCD Monitor
Syncmaster 720n
OK, I've figured it out! There's something wrong with the control chip, so if you don't have it under warranty, here's what you can do:
1. Turn off the monitor
2. Unscrew the face of the monitor
3. Remove the bottom part of the face from the backside, so you can see the chip
(the control chip is located on the face of the monitor, under the buttons)
4. You will see a small white connector about 5mm wide, UNPLUGG it
5. Put the small cable that you've unconnected under the front, so you can close the monitor back
6. Close the monitor and plug it back in
That's it. You won't be able to change your settings (they autoadjust anyway), but you won't have to throw the monitor away!
Peace.
Sep 01, 2009 | Samsung SyncMaster 720N Monitor
Switched from crt to lcd, no display!
You need to install the Display driver shipped or downloaded from net.
Mar 31, 2009 | Samsung SyncMaster 171 V 17" Flat Panel...
Monitor Problem
its a power prblem
u need to change the internal power conector
Sep 03, 2008 | Samsung SyncMaster 793DF 17" CRT Monitor
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
I had a similar problem on a different monitor and fixed the green sparkles by selecting a lower refresh rate.
Aug 15, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Before we moved to a new house my samsung syncmaster 710v monitor was working fine but when I reconnected monitor to the cpu, no picture appears but green power led flashes and when i disconnect the...
First make sure all cables are tight and secured, and try pressing the Auto Button on your Syncmaster? It's for auto configuration.
If problem persist and if possible can you try using another known normal monitor/LCD? Also try your monitor using another cpu or laptop.
May 12, 2008 | Computers & Internet
Screen on first start doesn't work
I have a SyncMaster 931BW which I duel Screen with a analogue montior.
There are Three things that I would check:
  1. Connection: if you are using the DVI adaptor, try using just the analogue (VGA) connection into your PC. You may have a faulty DVI adaptor which the PC cannot detect an output device.
  2. Drivers: If you have a standard monitor connect that to the PC and see if there is any output, if so, you may need to install the drivers for your monitor. You should have a Samsung Drivers Disc, or visit the Samsung website: http://www.samsung.com/uk/support/download/supportDown.do?model_nm=930BF&mType=DR&vType=L
  3. Cable: ensure that the cables are not knotted, and that within the adaptors the pins are all there and not bent as there is not a proper connection with the device.
Try them.
Jan 01, 2008 | Samsung SyncMaster 930BF 19" LCD Monitor
Samsung SyncMaster 152N 15" LCD Monitor Logo
78 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
