Question about GTCO Roll-Up Digitizer, 30/36" (RU3036)
Tabletworks has a red X and the digitzer is not found. I have a rolll up II and although it has worked in the past, my tabletworks loses the three "right tabs"(the two remaining are the info and mapping)
2 Suggested Answers
  • 11800 Answers
SOURCE: how do you uninstall tabletworks on an xp machine
Control Panel / System / Hardware / Device Manager / identify the tablet and double click on it / 1 - in General, at Device usage put it to disable and disconnect it / 2 - in Driver Uninstall it.
Posted on Mar 01, 2010
Does the drawing board III use WinTab for arcGIS 10?
ALL ESRI ARC Programs as far as I am aware use the Standard GTCO Tablet Works drivers. All GTCOCalcomp digitizers are or were level 1 supported by ESRI and the standard tabletworks driver will work just fine (This only applies to Windows versions of ARC, not Unix or other OS's)
Drivers can be obtained from GTCOCalcomp or from this link at the Interworld Site: http://www.interworldna.com/GTCO/gtco-drivers.php
If your digitizer has a serial interface use the SuperSet code 01 or 11. If you digitizer uses USB then no superset is active or needed (This only applies to GTCO or GTCOCalcomp Digitizers)
Calcomp or Summagraphics digitizers will need to be set to 9600,8,N,1 with High Resolution Biinary output to work with Tablet works. Hope this helps you
Jan 10, 2013 | GTCO CalComp Drawing Board III 34480...
Super L III and pad system software
First set the Superset Code to S01 on the tablet, if you are using the TabletWorks Driver it should work in your software.
Try using a Super L II selection or Digipad 5 if it has that selection.
Nov 18, 2011 | GTCO 4 Button Corded Cursor Puck for Super...
Our GE Profile DPSB613ED2WW dryer has been losing drying efficiency for the past few months. It now takes three cycles to completely dry a load. The dryer is heating (although we assume not correctly) and...
How is the vent discharge air flow out the back of dryer? If not very strong check out lint trap cavity for blockage or obstuction causing lint to build up, blocking air flow from drum cavity. Once found a pocket comb that had got into lint trap housing and created a lint dam blocking air flow.
Feb 14, 2011 | GE Dryers
GTCO Roll-Up Digitizer... lines appear wavy and jagged
The GTCO ROll-Up is not a high accuracy tablet,it is made for general use by Estimators.
Normal accuracy is somewhere between 15 and 22 mil.
Are there any breaks in the line,this would indicate an open on the grid.
Are you using a Tabletworks driver? Check the options and make sure the correct size tablet is in the driver.
Apr 30, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
CAN NEVER GET PAST "ALIGNMENT"
you will need to replace the digitzer
Mar 29, 2010 | Audiovox PPC-6600 Pocket PC
How do you uninstall tabletworks on an xp machine when it doesn't appear in the add/remove programs list - help! tabletworks works fine it just doesn't work with autocad lt and we need to get rid of it
Mar 01, 2010 | GTCO CalComp Drawing Board III 34480...
Calcomp GTCO Roll upDigitizer
Go to the search on your computer and find your tabletworks. Open tablet works and go to mapping. Click pick. Locate your mouse pad on the digitzer pad. Click Apply. This worked for me.
Mar 29, 2009 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Computers & Internet Logo
60 people viewed this question
Top GTCO Computers & Internet Experts
David Payne
David Payne
Are you a GTCO Computer and Internet Expert? Answer questions, earn points and help others
