I am using Samsung 40in LCD TV. 2years old. For the past one week on switching on it makes a tick tick sound for about 30 seconds before the TV actually switches itself on. OK in all other respects
    Problem Solver:
  • 17 Answers
Caps are bad on smps or ip board. replace caps or pcb
Posted on Sep 09, 2010
Testimonial: "Useful , thanks"
NO SOUND ON HDMI_1, VIDEO OK. HDMI_2-3 AND RCA ALL .
HDMI-1, according to the manaul, supports a DVI input only. DVI does not carry an audio signal. You need to use the DVI audio in if you are using HDMI-1
Jan 17, 2016 | Samsung LN40B550K1FXZA - 40in Lcd Tv 1080p...
Tv's sound is not coming through but the tv's sound test is working
Go into the sound menu and make sure the speakers are set to the TV , or the audio system you are using.
If they are turned on , then reset the systems sound settings to clear any previous settings .
The preset volume may be set too low and you are using your surround systems volume controle?
try turning up the volume on the set manualy... ?
Sep 29, 2011 | Samsung 40IN LCD 1920X1080 30001 400UX2...
PICTURE HAS GONE OF MY 40IN SAMSUNG LCD TV SOUND IS THEIR I HAVE CHECKED EVERTHING,OTHER TVS IN HOUSE ARE OK.
The caps on the power supply that supply the inverter board are probably swollen, bubbled, or cracked! Replace as needed with proper values and make sure you use 105 degree replacements for longevity. Let me know how it turns out: Sam Farrell
Feb 17, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I have 52" hd lcd TV.. And when I press the remote
Please navigate to this page ...click here
It is an articol about .Samsung tv strange clicking sound!
Dec 11, 2010 | Samsung LN52A530 LCD TV
Samsung ln-t4053h 40in lcd will not power on
my samsung when switched to the hdmi inputs comes up with a box saying not supported mode?? how ever shall i play my ps3 now?? can anyone help??
Feb 08, 2010 | Samsung LN-T4053H 40 in. LCD Television
LCD TV LA40R81BM/XTL tv tick tick sound 5min then strat
Hi my name is Roety,
I can help you with your issue ,
This is most likely a power supply issue
I usually replace the swollen capacitors I can see
A repairman would charge about $300 to replace them for you.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Dec 15, 2009 | Samsung LA40A450 40 in. LCD TV
Samsung 46 clicks takes 45 sec for picture
Hi my name is Eric,
I hope I can help you with your issue ,
The TV not starting properly you should hear the tone noise (bleep bleep) not a ticking noise or no sound .
Great that its under warranty
These Samsung LCDs have problems with the power supply capacitors going bad, a servicer will charge between $200 and $450 to repair it replacing either the capacitors or the whole board.
here is a DIY (do it yourself) solution:
It could be just a few bad capacitors on the power supply, if you want to attempt the repair yourself you can do a visual of the power board caps will appear swollen on to.
We do not recommend do it yourself, but depending on your knowledge and technical ability you may be able to.
with the back removed you will usually see two circuit boards the upper one is the power supply, it has a few capacitors on it (cylindrical standing straight up soldered in mark on the sides with the positive/negative sides and MF and Volts values)
Samsung uses mostly 1000Mfd at 16Volts rating capacitors, they cost about $1 each (680mfd will also work fine)
usually I replace about four of them (or all the bulged on top ones) .
The power board and back unscrew with a medium philips screwdriver, if you do not know how to desolder and resolder then do not attempt this as you may damage the TV more than fix it.
Im am posting a photo of some swollen caps on a board so you know what they look like;
best of luck to you
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Sep 06, 2009 | Televison & Video
Samsung lns4051d 40in has horizontal lines across screen and additional "fuzzies" on hd channels
This sound likes the incoming signal is week. You should play a DVD player to see if the problem stays same or not.
If you try all sources ie HDMI, AV Component, etc...the TV show the same problem. There are two possibilites: T-Con board or main board need replacing. You should need technician to figure out the problem. Hope it help.
Aug 13, 2009 | Samsung LN-S4051D 40 in. LCD Television
Samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Apr 14, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
