Question about Craftsman 7500 watt 6 circuit Transfer Kit
Do you plug the gernerator into the house and then start it or start it first and then plug it in
  • 490 Answers
The generator should be attached to the gentran switch box then started. Once started, then follow instructions for that system to swich to generator power. Some setups may have their own initiating order, it is important to obtain the correct instructions from your manufacturer and keep them where you can find them in a hurry.
I hope you don't need it too often:)
Regards, Farmerbear at FixYa.com
Posted on Sep 09, 2010
Can not start generator with remote switch or with switch on gernerator
The problem is the control board if neither the remote or local swiych will work. Assuming the board is plugged in correctly and proper battery voltage is present. I would NOT recommend jumping the solenoid !
Mar 27, 2013 | Onan Generator, 4000W, Gasoline
Code for Kenwood radio DPX5200M
Sorry but the number stated is not 129bytes which is whats need to open the dump on my code gernerator ,this number you gave is the model number i think and not the chassis number of the radio
Dec 23, 2012 | Cars & Trucks
Engine runs on half choke
You probably have some buildup in the carburetor, because tillers are gernerally used seasonally it leaves plenty of opportunities for buildup to occur . Also, you should inspect throttle cables and linkage to insure that everything intact.
Sep 07, 2012 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Gernerator wasn't used over a year, tried to start and can not pull cord. Checked the oil and there is gas in it?
The rings are stuck to the cylinder wall. Remove spark plug and spray some pb blaster in the hole.
3 or 4 seconds worth. Let sit a day then try. If no go repete. You can pry on the flywheel if yiu know where not to. Take your time Rushing it may brake the rings.
Feb 11, 2011 | Briggs Stratton H7159 & Stratton® 5500,...
We have a jaguar xj6 sports 12 years old,
Possibile ignition control module problem Check for spark when problem occurs No spark.. Follow wires from distributor to icm box. Open box and you will find a gerneral motors ignition module. Remove module and have tested at local parts store. Replace if bad. Jaguar wants over $300.00 for IGNITION AMPLIFIER UNIT. You should get gm module for under 50 bucks.
Mar 11, 2010 | 1987 Jaguar XJ6
My gernerator has set for a couple of years and now won't start, where should I look for a cause?
need more! is it tuning or is it seized take spark plug out then pull cord it should make a phoot phoot type of noise renu your spark or brush it up use fresh petrol cos petrol will go stail check switch for loose wires if all else fails take filter off and pore petrol down nto intake (small amount) it should start
Dec 14, 2009 | Coleman Electrical Supplies
Cant get a spark when i go to turn it over
my 1989 gsxr 1100 has 2 brand new coils i have no spark
Apr 10, 2009 | 1988 Suzuki GSX-R 750 J
Generator will not generate electricity.
I assume it is a hand start genset. The most common problem if it has been sat for a while is rust on the ignition timing flywheel. If you take the pullcord housing off (recoil) then you will see a big flywheel with what can only be described as a big forked prong with a couple of wires on it. This flywheel should be stainless steel and rusts when sat around for a while without use. Its job is to complete the circuit to the spark plug every time the flywheel passes the forked prong at a given spot on the flywheel, the faster the wheel turns the faster the spark hence the engine runs quicker. Clean the rust off with a releasing agent (wd 40) hey presto!!!!!!!!!!!
Sep 17, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Power loss in 220 Classic SE engine - Coolant Warning light coming on
alternator not givinging enough power or as they might call it the gernerator is failing replace accordingly
check to make sure your head gasket didnt blow out
by dropping the oil in oil pan if choclate milk looking head gasket gone
Jun 05, 2008 | 2003 Mercedes-Benz C-Class
Craftsman 7500 watt 6 circuit Transfer Kit Logo
112 people viewed this question
Top Craftsman Electrical Supplies Experts
BJ Russell
wadingriver
wadingriver
Chuck Graybill
Are you a Craftsman Electrical Supply Expert? Answer questions, earn points and help others
