Question about Candy CPCA250K Bottom Freezer Refrigerator
Please confirm which is the colder setting, the low numbers (1, 2, etc.) or higher numbers, 4 or 5 on the avanti compact freezer.
  • Candy Master
  • 43,501 Answers
Hi.
Higher numbers are colder...
heatman101
Posted on Sep 11, 2010
What is the best setting for the freezer. The settings range from 1 to 4. Second hand give away no instructions
the medium settings"
Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Apr 08, 2015 | Refrigerators
Which is colder 1 or 5?
My Avanti's temperature control is numbered 1 -5, and after 5 is MAX.
There is a separate control in the freezer section, but that is another matter.
As a matter of fact, in any refrigerator with a temp control, turning it towards the RIGHT will always result in COLDER.
If you open the door dozens of times an hour, you'd probably want to keep it on MAX.
If not, then MAX setting might begin to freeze some of the items you do not want frozen. If you are a normal user, try setting to 3.
Aug 16, 2014 | Avanti Refrigerators
Is the dial to adjust temp coldest set at low numbers or high number?
The dial inside the fresh food compartment, the bottom compartment
set to middle or above (higher numbers mean colder). Usually 5 to 9 if it has numbers.
Freezer knob in the middle if it has one. (If you set a freezer knob to "colder" it cuts
off the cold air to the lower compartment). Hope this helps
Jun 29, 2011 | Kenmore Top Freezer Refrigerator
For the temperature, to make it colder to we turn the knob towards the higher numbers or lower?
Normally the lower number is more cooling and hence the setting is ideal to be kept at mid point.
In twin door adjustment witth single control lower setting more cooling to freezer and as it goes up the temp of the fridge increases.
So you might need to recheck with this model
Sep 16, 2010 | Avanti 308YWT Compact Refrigerator
Temp Control
Hi!!
The higher the number, the colder the setting.
Rate this post, Good Day!!
Apr 26, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
How do I set the temperature?
Hello Elise, The Dial should be set to the middle number three (3) to start with and allow for 24 hours of running before you make any adjustments, either up or down.
The higher the number the colder the fridge temperature will be. Just remember that it takes almost a full day for the fridge compensate for any changes to the thermostat. Also, only make adjustments in the temperature setting by only 1 increment at a time (either up or down) and again, allow 24 hours before making further changes.
If your fridge has the red button in the center of the temperature dial, that is the manual defrost button. So if you've got a build up of ice on the freezer section, just push it and it will defrost the unit for up 2-4 hours.
Hope you find this Very Helpful and best regards!
Merry Christmas!
Dec 14, 2009 | Magic Chef MCBR440 Compact Refrigerator
I have an older whirlpool freezer i just need to know on the tempture gage which number is the coldest 1 or higher
usually the higher the number the colder it gets. Easiest way to tell on all models is the number closest to off is the warmest setting... Eric
Sep 13, 2009 | Whirlpool Upright Freezer EV161NZRQ
Temp control
Most refrigerator settings are in numbers like yours, the higher number will be colder setting.
Dec 20, 2008 | Candy CPCA240FFK Bottom Freezer...
Temperature adjustment
Generally the freezer temp is the REAL temp of the unit. Fans, dampers and manual control levers let some of that cold freezer air into the refer compartment to cool it. Check your owners manual for damper operations if you have one. If you have a refer temp control all that does is control a damper to let the cold freezer air into the compartment. Also make sure you don't block off any of those vents in the refer or freezer compartment or bad air circulation can occur.
Oct 05, 2006 | Candy CPCA250K Bottom Freezer Refrigerator
Candy CPCA250K Bottom Freezer Refrigerator Logo
353 people viewed this question
Top Candy Refrigerators Experts
John Tripp
John Tripp
Billy Detlefsen
ray gallant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
