Question about Emerson NR305TT CD Shelf System
The turntable will not turn I thing the motor is bad \r\nwhere can I find a new one Model NR305TT Number on motor EG530SD-2F
2 Suggested Answers
SOURCE: Emerson NR305TT - Replacement Turntable Needles
I have the same model. Though I haven't replaced the needle yet, I was able to remove the broken one. You'll see that the arm has a red plastic attachment. It houses the needle in a very thin strip of something like electrician's tape. There is a very small separation on the front (end of the arm facing you) of the tone arm, where the arm (black plastic) and needle "cartridge" (red plastic) come together. I used a metal nail file and pried them apart very gently. At this point the red plastic "cartridge" with the broken needle was hanging but still connected on either side. The red plastic "cartridge" is made with tiny plastic 'bumps' that pop into indentations built into the black plastic of the arm. Again, using my metal nail file, I simply held the arm and pried the red plastic "cartridge" away from one side. It popped off the other immediately and fell away from the arm. Voila!
Hope this helps!
Posted on Mar 07, 2009
How do I adjust the pitch / rotation speed for the turntable of my Emerson NR305TT ?
If the pitch is adjustable then there will be a little round knob to adjust it near the pivot of the turntable tonearm. If not the pitch is not adjustable.
Jun 23, 2016 | Emerson Nr305tt Heritage Home Audio System...
Unable to find repair parts for emerson nr305tt stereo
As the unit is obsolete, the repair could easily cost more than the unit's worth. Consider buying a used one off Ebay (currently there are 9 units available. One going as low as $16 + shipping.)
Apr 15, 2014 | Audio Players & Recorders
Electro Brand model number 9801: I played one record, now when I tried to play another the turntable will not rotate. Could the motor have burned out that easily?
Listen carefully with your ear to the turntable when you move the tone arm towards the record. If you can hear the motor running and the turntable is still stationary then the drive belt from motor to turntable has probably fallen off of broken. Lift the turntable, there's normally a metal clip holding the turntable in place, and locate the drive belt.
Jan 19, 2014 | Teac GF-350 CD Shelf System
I have a GE spacemaker XL1800. the model number is JVM 1842 BD. The turn table has stopped turning. There is a turn table control and that is turned on. how do I go about repairing it? also, wher
The full model number from the tag on the unit would be JVM1842BD001 or JVM1842BD002 without the spaces.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 07, 2013 | Microwave Ovens
GE model je 1860, the turn table doesn't work, the 21 v ac crossed the turn table, and the motor is 128 ohm as the spec. Would you think what caused,please Thanks
In GE / Samsungs that have 21VAC turntable motors and stirrer motors, the 21VAC is supplied from a tap off the internal cooling fan motor that cools the magnetron.
It sounds like you have a bad turntable motor.
The turntable system otherwise consists of the motor, the coupler, the turntable support with rollers, and the tray.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or possibly a bad plastic coupler.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Oct 01, 2010 | GE JE1860 Microwave Oven
Grinding noise from turning platter mechanism - Kenmore #63252
If yours sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Sep 23, 2008 | Kenmore 63252 Microwave Oven
G.E. Profile Microwave Model JVM2070SH01 turn table does not turn.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 02, 2008 | GE JEM25 Microwave Oven
OTR microwave turntable won't rotate
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If not, please post your brand and model.
It's probably the motor, but possibly the coupler.
One quick check is to remove the turntable and support / roller ring and try to turn the coupler. It should be a little hard to get started, then you should hear a whirring sound, not a clicking or grinding, which would indicate a bad motor.
If the coupler turns loosely with no resistance, then it's probably bad.
Here is my text on replacing couplers, which had steps which are necessary when replacing motors. Note that if yours is a built-in model, ignore the part about turning it on its side *grin*
NOTES ON REPLACING TURNTABLE COUPLERS
Copyright 2007 by William E. Miller - MicrowaveDisplay.com
UNPLUG THE OVEN FROM THE WALL FIRST OR YOU WILL EXPOSE YOURSELF TO LETHAL VOLTAGES!
Note that I am not encouraging you to work on electrical items if you are not qualified, and I assume no liability for any consequences of your decision to do so.
When replacing the turntable coupler on most models, it is necessary to loosen or remove the screws that mount the turntable motor to the bottom of the chassis.
It is usually easier to do this with the microwave oven on its right (heaviest) side because you will need two hands for alignment.
Be sure to put a towel or similar cushion on the work surface to avoid scratching the oven wrapper (oven cover) or the work surface.
It is not necessary to remove the wrapper or the wires from the turntable motor itself, but you may need to remove a small metal duct covering the turntable motor if your oven has one.
It should only be held on by one or two screws.
Although a broken coupler may come out easily or even fall out, the new coupler will not go in without at least loosening the turntable motor.
Look at the hole in the new coupler. You'll notice it has (most do have) a flat side to it. That flat side will line up with the flat side on the motor shaft.
When the old coupler is out and the motor is loose, you can ease the new coupler in the hole with one hand while turning the coupler very slightly back and forth as you gently push the motor toward it. Do not force the part in.
When the coupler has mated properly with the motor, you should feel it go in.
Be sure it's right, or you may break the new coupler or bend the mounting ears of the motor when you attempt to tighten the screws.
Reassemble in reverse order.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 05, 2008 | Microwave Ovens
Hope this helps!
May 29, 2007 | Emerson NR305TT CD Shelf System
Emerson NR305TT CD Shelf System Logo
99 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
