SOURCE: how do you remove the rear speakers on a 06 toyota camry?
You need to remove the entire rear seat, the bottom & the seat back. Remove both of the rear inner C pillar trims, remove the rear parcel shelf, under the back window.
The speakers come UP from where they are mounted. You cannot take them out thru the trunk.
Hope this helps, and thanks for choosing FixYa.
SOURCE: trying to remove 2000 Yukon
There are three if we are talking about the same thing.
One at the bottom under the side bin.
One behind the rubber handle above the door latch (this is a long screw).
One behind the window switches. Pry up on the inside seem (long edge), it should come up and then out. The screw is behind it.
SOURCE: removing inside door panel to change the speakers
Door panels are easy, first remove all of the screws, some will be hidden under plugs on the door handle. Using a door panel tool (about $5.00 at a parts store) work it around the panel and pop the plastic keepers out. Done.
SOURCE: how to remove rear door interior door panel
You should obtain a tool made specifically for removing door panels. They are attached by "snap" connectors, and by pulling on the door panel itself will invariably ruin it. Get the tool from a parts place and carefully peer into the slot between the door metal and the door panel. Use the tool slowly with resolution. You should really acquire a manual that guides you for your particular Jag.
Remember, to take the panel completely off, you need to remove the door handle. Look for a plug that has a screw under it. You'll need to pop the door window/lock control panel too, to access screws under there. This can be tricky, so be careful.
SOURCE: who is manufacturer of rear
if your car is assembly in europ generally uses farba , but is import then uses koito, now farba complies oem rules
