Question about Sagem Televison & Video
I am using my Sagem ITD58G box with a TV it's worked with before -I haven't used them together in a little while though. The TV reads the digital box so the scart is working but I can't get any channels I just get an error message saying "Check your antenna, check your cable and then check your box". Is this a problem with reception? I've tried the wall ariel and a portable one and it makes no difference. What would you advise? Many thanks Rosalie
snakehead
  • 1074 Answers
SOURCE: Can't change Proline TV / Video combo to scart
visit www.partstore.com to purchase a originald remote for your set if they do not have it they can get it for you.good luck
Posted on Apr 08, 2007
  • 125 Answers
SOURCE: Quasar VV-2001 TV/VCR combo - msg: Check Antenna Cable Connection
Check first the antenna using another TV. If there is no other TV available, check using an ohmeter. If you are 100% sure tha the antenna is ok then the antenna connector on your Tv is not making a good connection to the antenna plug.
Posted on May 24, 2007
SOURCE: tv not working
Can you confirm that you didn't have any input signal? My wife once accidentally pressed the reset button on the remote and the TV was stuck in this state. I tried to hook up an antenna to the digital antenna input and let the TV search for a channel. It did find a station and got out of the channel search mode, which was all I needed. Then, I unhook the antenna and continued to enjoy my DVD movie. I didn't check the manual. So, it's possible that there is a better solution. My TV was working fine and I think it just has a terrible user interface. I'm not sure about your TV's condition, though.
Posted on Sep 19, 2007
SOURCE: No manual for Sagem ITD58G Freeview Box
http://www.sagem.com/support/site/livret/LU_UK_ITD64_62_61_60_58_59_68_72.pdf
Posted on Jun 30, 2008
SOURCE: Digivox DV3 cable box
press edit and go to bottom selection system instilation, press ok. type in 1004 on remote, nothing will appear till last digit entered. you will now see a hidden menu. there are three selections go to the bottom one and highlight, to the left another box says off use the right button and it will change to on. press exit till you come back. Go to sky movies or sport and a few minutes later you will see a box updating data, let it update and a picture will apear, all the pictures are now unscrambled. worked ok for me.
Posted on Aug 31, 2008
FREESAT SAGEM REMOTE CODES
028,011,073,083,091,000 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 02, 2013 | Televison & Video
My sagem dvr62160sl uk digital reciever wont work
A number of Sagem models have shown incompatibilities with the recent Freeview retune, there is a list of affected models (see http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf ) but it's not a fully comprehensive list. Sagem error code 07 means there's an access problem in back-up memory (stored in the EEPROM) and code 09 means the machine has been unable to find any data necessary to do an upgrade. In essence, your box has tried to upgrade itself and failed and now cannot restore to it's previous state.
Your dvr62160sl is closely related to the dtr6240 and 6280 models which are known to have had issues and so the official advice is to contact Sagem directly on 0845 0900 316 to find out how whether they can supply a solution on a dvd or if they've scheduled an OAD (over air update).
I hope that you've found my posting to be of use and ask only that you return the favour by rating my answer.
Oct 23, 2009 | Televison & Video
I NEED THE OPERATATING INSTRUCTIONS FOR A SAGEM DTR67250T DIGITAL TV RECORDER, WHERE CAN I GET THEM ?
Here is the to the clickable PDF User's Manual for this product direct from the Sagem Support web site.
http://support.sagem-communications.com/site/livret/LU_DTR6400T_6700T_ENG.pdf
If the link does not work for you do the following:
Go to http://support.sagem-communications.com/site/page_accueil.php?site=1&pays=uk
Click on Set Top Boxes
Select your box
Click on User's Manual.
I hope this helps you!
- CBR2009
Aug 11, 2009 | Televison & Video
Total Control 4 wont work my freeview box
im looking for sagem freeview code on total control.
thank you
May 17, 2009 | Televison & Video
Error codes er o7, er o9
Had exactly the same problem during Oct 09. Spoke with SAGEM all sorts of solutions no joy. Spoke to currys and tried a new power source and it works fine. Ordered a new source via SAGEM approx £15 and now have a working box. Saved having to buy a replacement and all my recordings are still in tact.
Apr 11, 2009 | Televison & Video
Error code 09
Er00 - The software that was available for upgrading was of an older or of the same version as the one already in the digital-box.
Er01, Er02 -The upgrade failed. Some information was missed out.
Er03 - The internal memory is not large enough to receive the upgrade.
Er04 - The signal was disturbed during the upgrade.
Er05 - Wrong type of data was received during upgrade.
Er06 - Not used.
Er07 - Access problem in back-up memory (EEPROM).
Er08 - Access problem in video memory.
Er09 - Can not find any data to do an upgrade.
Er10 - Poor or no cable-TV signal.
Er11,12 - Not used.
Er13 - Unauthorised data signals received by the digital-box.
Er14 - Faulty data signals received by the digital-box.
Pb01 - A problem in the ROM memory is detected.
Pb02 - Memory size is too small.
Pb03 - A problem occurred during start up (initialisation
problem).
Pb04 - Internal communication failure.
PbF9 - Hardware error identified during start-up
From elsewhere on the web:
1. Turn off the unit for 15 minutes to cause a full reset.
2. Turn on the PVR with everything attached except the antenna input.
3. You will get an Er09 on the display. On my PVR there was no output on the TV screen whatsoever (totally black screen).
4. Press 'OK' on the remote (confusing as there is no clue that this is what you should be doing, though Sagem support thought that the PVR should prompt you.
5. The box reboots in standby mode."
Good Luck...
I also see some mention that if the above procedure doesn't work, try pressing "Menu" twice to see if that clears error 09.
Mar 05, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Sagem digibox connections
I think it´s impossible.
May 29, 2008 | Sagem Televison & Video
How can I take advantage of digital cable?
No digital sound comes from Digital Coax or Optical and in order to utilize a digital signal u need HDMI or Component although component wont be truly digital. Try running everything to the TV then the sound out of the TV into the sound system. If its a high def source like high def cable box then use the optical conection on the back of the aquos and plug than into your surround system. if ur system doesnt support Optical or digital coax then you need an updated surround system. If i misunderstood your question im sorry. If u live in CT though stop by Circuit city in North haven. either myself, Dave, or my associate Justin should be able to help you out. and dont worry we're not on commission or anything.
Dec 17, 2005 | Zenith XBS344 System
Televison & Video Logo
48 people viewed this question
Top Sagem Televison & Video Experts
Andy Fraser
Andy Fraser
electracon
 Mikey
Mikey
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
