Question about Seiko Kinetic watch
Seiko 5m43 fails run after cell replacement - Seiko Kinetic watch
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 184 Answers
Hi, Look on page 11 of your manual for the proper procedure to restart watch after a battery change, or complete discharge of capacitor system. If you don't have the manual, Try this link:
http://www.seikowatches.com/support/ib/index.html
Take the four-digit module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Posted on Sep 08, 2010
    Problem Solver:
  • 17 Answers
Please expplain what you mean by "cell replacement. If you mean the battery was replaced and the watch is not running it can be several things.
The most common mistake I see people make when they try to install a new battery in a Seiko Kinetic is they put the battery in upside down. The battery is the opposite of most watches...you should not be able to see what type battery it is, it is face down.
The second problem is people do not install the mylar insulator correctly. I have fixed a lot of Seiko Kinetics merely by putting a mylar insulator the way it is supposed to go.
Other problems can include the central stem all the hands are attached to gets pushed into the crystal when the watch is open because the people working on the watch did not use a watch holder. I have gotten many "broken" Seiko Kinetics where an amateur tried to replace the battery and ended up ruining the watch this way.
Also, the pendulum sits on top of a gear. This gear must mesh perfectly with a tiny tiny gear that is hard to miss. If it wasn't meshed when the watch was put back together then the watch will not work.
But, the most important thing to remember is if your watch stopped working after you installed a new battery then the installation was not done correctly. If a battery is in the watch in the right way the watch will run for several months even though it is not being moved.
Turn the hands around 12 or more hours.
Push the crown all the way in.
Push the Indicator button...If there is no Reserve power you will
need to install a new battery in the correct manner.
Posted on Jul 14, 2013
How to remove the crown in 5M43 calibre kinetic watch by seiko
take the back off the watch...carefully look inside the watch for a small arrow, it will be pointing to a tiny dot pull out your crown as far as you can. use a small pin/tweezer, what ever will fit in that small hole push in the hole and at the same time, pull your crown out. it should pop right out!
hope this helped!
Jun 16, 2011 | Seiko Kinetic watch
Previously accurate Seiko dive watch suddenly gaining 1-2 hrs/day
if your watch caliber is 7s26b(look at the case back plate)is a usual problem of those calibers!the hair spring stuck somehow and the watch runs!a seiko authorized sevice center can help you!dont let anybody else magician to ruin your watch!is a routine repair for someone with knowledge and support from seiko!
Dec 11, 2009 | Seiko Divers SKXA35 Wrist Watch
My watch runs too fast: adds appr. 1 minute every 24 hours
That is way too fast for a Seiko Kinetic. There is no adjustment to slow it down. With time of course it might run slower as the gears get dirty. Maybe Seiko will replace the movement, worth asking
Oct 03, 2009 | Seiko Kinetic watch
Can I use an ordinary button cell in a seiko kinetic
I have been trained by a Master watch maker and I have worked on many Seiko Kinetic watches. Yes the original watches came with a capacitor that is charged by your arm movement. But unfortunately, they seem to only last a few years. All replacements are now done with a Lithium Ion battery that is much better and lasts longer than the original capacitor. This is the correct solution and don't try to use a battery type that is used in other quartz watches.
Oct 01, 2009 | Seiko Kinetic watch
Seiko Self winding 200M Divers Watch Stopped Working
your watch needs a good service.disassembling cleaning oiling and reassembling!this must done every three to four years in automatic watches!try in a authorized seiko service center!
Jun 28, 2009 | Seiko Divers Automatic watch
How to remove back for battery replacement - 19 year old seiko wristwatch. numbers on back: 5423-8229 & 041115.
This is a little tricky, I think this has a screw on back. It takes a two or better a three prong tool to remove back. A new seal shoud be on hand to replace this. Watch should have a consumption test and a min run voltage test, if either of these fail a new circuit board or movement should be installed. Take it to a good watchmaker and they will clean the outside before opening and do a water resistance test after assembly.
Jun 13, 2009 | Seiko 0512037FA Wrist Watch
Seiko Chronograph 7T32 minute hand inactive after battery replace
you often need to do a full reset on 7T32s (& other seikos) after a battery change. there is a small reset contact in the rear of the movement which needs to be shorted to the top of the battery (the movement is engraved with wording to this effect, something like "AC reset", I can't remember exactly). you might also try pulling out the crown all the way (2 clicks) then holding both upper pushers in for a few seconds. it's unlikely to be a buggered motor unless it's one of the subdials that's failed.
hth-
duncan.
Feb 20, 2009 | Seiko Le Grand Sport SDWF73 Wrist Watch
Seiko kinetic
Here is a link .
Hope it helps.
Dec 31, 2008 | Seiko Kinetic watch
My seiko kinetic watch stops working overnight but it is fine whilst wearing it
Further to the previous solution...
Despite Seiko's claims regarding never having to change the 'battery', the power storage unit or ECU in Seiko-speak (not technically a 'battery') does eventually need replacing. From the symptoms you describe, it sounds as if the 'battery' on this watch is on its last legs as it is no longer charging properly. The good news is that it doesn't have to be an expensive job to have it replaced (providing you avoid going through the local jeweller <==> Seiko chain!). There are companies on the Internet who offer a replacement 'battery' service. I've used one in the past and was very satisfied with both the cost and the good service. A Google Search will probably return a choice of several in your country. Btw, if you have had your Seiko Kinetic for a few years, its probably worth paying a bit more and having it overhauled (clean and oil the movement and replace the watertight seals) at the same time.
Jul 30, 2008 | Watches
Seiko Kinetic watch Logo
768 people viewed this question
Top Seiko Watches Experts
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
