Question about Refrigerators
My Amana refrigerator is freezing everything! The temperature controls are not working! Help?!
  • Refrigerators Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Amana SZD22MB2L is freezing in refrigerator compartment
I would start with checking that hte air damper that controls air coming from the freezer over to the fridge is working properly. Thats more than likely the issue. Just in case also check that the temperature control is working as designed
May 29, 2012 | Amana Refrigerators
My amana 26 side by side refrigerator/freezer keeps running and everything is freezing. i have tried to turn it down with no help
1x1.gif How To Replace the Temperature Control Remove the temperature control dial or housing. Pull the dial straight away from the wall. Remove the temperature control. If there is a housing over the control, it either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring.
Before replacing the control, unplug the refrigerator to avoid an electrical shock hazard.
The control is connected by two wires. Label the wire placement on the control before disconnecting the wires. The wires are connected to the switch with slip-on connectors. Firmly pull the connector (do not pull on the wire) off of the control's terminal. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors for corrosion. If the connectors are corroded they should be replaced.
The temperature control also has a temperature probe permanently attached. Follow the path of the probe and remove any fasteners that hold it in place.
Carefully replace the temperature probe along the same path as it was originally installed. Avoid any unnecessary bending, and do not bend it into a sharp angle as this can damage the probe. Connect the wires to the new temperature control. Replace the switch and housing (if any) and press the knob onto the the control's hub. Adjust the control to a midway setting. Plug in the refrigerator. After one to two hours check the temperature.
Aug 13, 2011 | Amana Refrigerators
Amana ABB2224DES fridge freezes everything in the main compartment (not just the freezer). Doesn't matter what the level setting is at.
Sounds like your Temperature Control Sensor has gone bad. Could also be that the door on the duct from the freezer to the fridge is stuck open due to a bad solenoid there.
Jan 21, 2011 | Amana ABB2224DES Stainless Steel Bottom...
Our Amana AF12538 AE Refrigerator is causing the vegetables in the vegetable bin to freeze. What could cause this? the Units is only 2 years old.
Refrigerator temperature control set too cold or faulty Fresh Food thermistor.
Adjust refrigerator temperature control or check thermistor.
1 Refrigerator section too cold
2 Refrigerator airflow not properly adjusted
3 Check air flow.
Just too much information for this page. If you would like the long version please let me know. I am a Technician and have the tools and the answers if you would like my assistance. I will go out of my way to help you and would rather tell you this first so please do not rate unless I assist you Thanks, Sea Breeze
Dec 30, 2010 | Amana AFI2538AE
Ice maker not working. refrigerator is freezing everything. seems to run all the time.Help!!!!!! It is an Amana about 10 yrs old.
if you have the settings correct then the cold control(ref setting) is bad. but some older models use a baffling system which confuse some people. the freezer settind turned to the lowest setting make you fridge colder. when you put the freezer on the highest setting it allows less airflow. which in turn keeps ref warmer.
Aug 01, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Amana SPD26VW runs, lights on, does not freeze
I called Amana and found the "sealed systems" are still under warranty. It cost me $85 for a service call and the fridge is working. The problem was a plugged "capillary line."
Jun 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana refrigerator fresh food control does not work at all
first of all, check to make sure your fan is working, also check the inside compartment for the damper should be open when your rise or lower the temperature settings on your dial. when you rise your temperature dial to 5 you should feel air flow coming out of the damper, if not check to make sure that the evaporator fan is working first, if it is than check the damper door should be open sometime this damper door gets stuck on something or they break off.
Dec 26, 2008 | Amana ABB1927DE Bottom Freezer...
Brand new Amana French Doors Refrigerator is too cold.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Dec 11, 2008 | Amana 25" Cu Ft French Doors Bottom...
EVERYTHING FREEZES!
Probably need to replace that temperature control. Also check damper. If manual, set to where less air is going to fridge.
Sep 24, 2017 | Amana ARB224RCW Bottom Freezer...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
