Question about Frigidaire 26.0 cu. ft. Side-By-Side Refrigerator
After leveling the unit rocks. can rear rollers be adjusted?
  • Frigidaire Master
  • 43,501 Answers
Yes, there are adjustment screws behind the grille in the front..
heatman101
Posted on Sep 11, 2010
Replace deck on Precor 9.45i
Replacing a Treadmill Running Belt and Deck Following is a basic guideline of removing and replacing the running belt and deck on a treadmill. Due to different brands and designs of treadmills, the following should only be used as a guideline. If any of the information is not exact to the treadmill being serviced, refer to the service manual or call Sportsmith for further help. Tools Needed: Phillips Screwdriver, Set of Allen Wrenches, Set of Box End or Open Face Wrenches (Tools needed may vary depending on treadmill. )
  1. Switch the Power off on the unit.
  2. Next, unplug the unit from the wall.
  3. Remove the finger guard retaining screws and carefully remove the finger guards from the deck at each end of the rear roller.
  4. Loosen each rear roller bolt by 10 full turns. Then count the remaining turns necessary to remove the rear roller bolts. Remember to write down the number of turns needed to remove the bolts in each side for future reference.
  5. Carefully remove the rear roller from the unit. Clean any wax or debris buildup from the roller and place it aside.
  6. Raise the shroud and secure it with a bungee cord.
  7. Work the drive belt off the motor pulley by hand turning the flywheel while pushing the belt aside.
  8. Now remove the front roller retaining bolts.
  9. Carefully remove the front roller from the unit. Clean off any wax or debris buildup and set it aside.
  10. Loosen and remove the deck mounting hardware.
  11. Move the deck toward the left side of the frame to free the deck from the right side. The deck will move down once the frame has been cleared.
  12. Remove the deck and belt by raising the right side edge of the deck over the frame rail and sliding it to the right to remove.
  13. When installing a new belt or deck it is important to note that a new belt and deck surface should always be installed together. Failure to adhere to this guideline will severely shorten the life of the newly installed parts. Some decks can be used on both sides. However, be sure that each side is only used once. Be sure to install the belt in the proper direction on the unit.
  14. Install the belt and deck by first putting the belt on the deck, and then installing them from the right side as a unit.
  15. Be sure the deck is lined up with the frame and push the deck to the left side.
  16. Now carefully lower the right side of the deck to insert it into the frame rail and then push the deck to the right as far as possible.
  17. Re-install deck mounting hardware. (Check with mfr. for proper torque during install process.)
  18. Carefully place the front roller on the deck under the belt and push it forward into place, while placing the drive belt on the inside of the drive pulley.
  19. Replace the front roller bolts. (Check with mfr. for proper torque during install process.)
  20. Now spin the roller by hand while pushing the drive belt onto the pulley. Be sure to spin the roller several times to insure complete installation of the drive belt on the pulley.
  21. Install the rear roller into unit. Carefully start each bolt and turn one to two threads to ensure no cross-threading has occurred.
  22. Tighten each rear roller bolt the number of turns you kept earlier for reference.
  23. Now, Plug in and power on the unit.
  24. Carefully remove the bungee cord from the shroud and lower it back into place.
  25. Start the unit at a very slow speed and check for proper belt alignment. Remember to start at the slowest speed possible and be ready to stop the unit quickly if needed.
  26. If the belt is moving to right side of unit tighten the right roller bolt, If the belt is moving to the left side of the unit tighten the left roller bolt until the belt is tracking properly.
  27. Caution: make very small adjustments such as 1/4 turns and then watch the belt for several moments before making another adjustment.
  28. Once the belt is tracking properly walk on the unit at a slow speed and check for belt slippage on foot fall. If this is happening tighten each of the rear roller bolts equal turns until the slippage is no longer occurring. Caution: make very small adjustments such as ¼ turns and then watch the belt for several moments before making another adjustment.
  29. Now use the unit at a jogging speed to check for belt travel or slippage.
  30. If slippage still occurs make small equal adjustments (1/4 turns) to both sides of rear roller and re-test.
  31. Install the finger guards once you have enough clearance from the rear roller.
  32. Some manufacturers require wax or lube during the install process, please consult your owner's or service manual for further information regarding this.
How to Replace Treadmill Running Belt and Deck
Feb 22, 2014 | Precor Exercise & Fitness
We have a Whirlpool refrigerator model EB9SHKXVQ02 that is not level. The front of the unit is at least a half inch higher than the back and we see four wheels but only one leveler on the hing. How do...
Place a cedar shake on the low side of the floor align with the rear roller, slide the unit into position and adjust the front leveling legs.
Oct 30, 2013 | Refrigerators
Replacing precor 956i treadmill deck
Oct 09, 2013 | Precor 956i Experience Series Treadmill...
Hotpoint top load unbalanced
Darla heavy objects such as towels and jeans not evenly distributed in the washer will cause this to occur, open lid let washer come to a stop and then reposition clothes
If it is unbalanced as in the whole machine rocks even when not running then the rear levelers are out of position, pull top of washer towards you tilting the whole machine, towards you, the rear levelers will self adjust unless jammed, you may need help tilting the unit
Jul 09, 2012 | Hotpoint VVSR1070D Top Load Washer
Are back feet/rollers adjustable?
normally the rear are just rollers
for your problem use tapered door wedges ( hardware shop) under the appropriate side at the rear of the fridge to make the adjustment
Sep 04, 2017 | Electrolux EI23BC51IS
How do I adjust the 'feet/roller' at the rear of the unit in order to ensure the unit is level?
there are two allen head type screws one under the freezer door hindge side one under fridge side hinge insert a large allen wrench long handle type and turn clock wise to adjust the back wheels be carefule if you turn counter clockwise the long screw will come out of the adjustment nut in the wheel bracket. then have some one tilt the fridge back and next to the allen wrench you will see a white disk that is the adjustment eor the eront of the unit turn it clockwise it will spin down as you turn it.
Jun 28, 2011 | Bosch B22CS80SNS (220 cu ft) Side by Side...
Open door and whole unit moves, it dosen't come with back legs, or does it??
No most don't have rear legs. However, they usually will have front legs that screw down past the wheels/rollers to prevent it from sliding around under normal conditions.
You may have to remove the grill in the front (if present on your model) to adjust the wheels/rollers "up" out of the way while lowering the legs to level it, and they should also act as "brakes" to a degree if the floor/surface is relatively level.
Hope that helps,
Good Luck
Oct 31, 2009 | Kenmore 60721 Refrigerator
Refrigerator does not level tilts to rear extremly unit rolls foward when opening doors
there should be two set screws at the top of the rollers . to adjust if I am correct you turn these screws to the left to raise the front. These screws are above the rollers as I said however, if you use a phone book to hold up the front of the fridge it will take pressure off the rollers making their adjustments easier
Good Luck
Dave
Aug 28, 2009 | Jenn-Air JCD2389G Side by Side...
Leveling a washer tub how to do so
first get a level. second, some have self leveling rear legs, just lean the machine forward and set down slowly. the rear legs are now level. if you dont have self leveling rear legs, the legs screw in, so just screw them in or out as well as the front legs untl it appears level by eye. now place the level on the washer. check it front to back and side to side. try rocking the machine to see if there is any movement. if there is adjust the legso it stops rocking, all the while keeping an eye on the level
Sep 27, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
LG1812CW Walks During Spin Cycle
The rear 2 legs are fixed. The front 2 are adjustable. There are lock nuts to prevent the adjustment from coming loose. The front legs are to be adjusted to the minimum. While not running if the machine rocks, continue the adjustment. For few clothes there is a half load switch; best the read the manual well before anything. Well if the walking continues, check the rear for any shocks or springs that may hv fallen off during transport. Plug off the wall socket first.
May 28, 2007 | LG WM1812C Front Load Washer
Frigidaire 26.0 cu. ft. Side-By-Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
