Question about Health & Beauty
I have a Pari Trek S nebulizer model 047B1000 that has stopped working. It worked fine last night but this morning it will not turn on. What can I do to make this work?
sknerdish
  • 53 Answers
SOURCE: iphone touchscreen not working
try fully charging the battery
Posted on Feb 18, 2009
ginko
  • 19396 Answers
SOURCE: Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
Posted on May 30, 2009
MNfisherman
  • 11896 Answers
SOURCE: Lost tranmission capabilities on one of the units,
The only way to really reset this is to remove the power/battery for 8 hours, press power button for 3 seconds, then wait 1/2 hour. Then try it again.
If you need a manual for this radio, you can view it here:
http://www.motorola.com/mdirect/manuals/T5320_T5410_T5420_User_Manual_E.pdf
Posted on Nov 15, 2009
  • 31 Answers
SOURCE: tubing coming out of machine gets very warm
This is common that these smaller units get warm when running for longer than five minutes at a time. I have never had a problem with it overheating though. If it would make you feel better the larger Pari units rarely get warm. The Pari LC plus neb kit may need replacing. This may fix the problem.
Posted on Jun 26, 2010
  • 54 Answers
SOURCE: my nebulizer also worked last
check with power cord and fuse if external provided and some of the machine it will be inside.
Posted on Jul 16, 2011
My nebulizer also worked last night, but can't get it to turn on this morning.
Jun 10, 2011 | Health & Beauty
Green and yellow lights flash on battery while charging
If all the lights are flashing, it normally indicated dead batteries as instructions say and I found out. Pari would have you buy a new power pack or likely high repair price to replace 2 LI-ION cells . But, unless you are very handy with electonic items, you may have no choice. We bought a 2nd unit originally and when those batteries prematurely died, I reserched and installed my own.
Feb 12, 2011 | Pari TREK S Compact Nebulizer System ()
I have a pari trek s. The battery is dead and I am attempting to charge it. However it is not charging and will not turn on even while plugged in. While plugged in all 4 battery lights are blinking.
Unless you are very knowledgeable in electronics and wish to replace the two internal tab-soldered cells yourself (and finding capacity type required), you have only one resort. Buy a new battery pack. That is exactly what Pari wants. Too bad, because charging circuit board never fails. Only the 2 cells die prematurely.
Jan 23, 2011 | Pari Health & Beauty
TUBE LEAKING AIR AT BOTTOM
Depending on which type of nebulizer she has, it should be a very simple fix. The best thing you can do is replace the disposable neb kit. This would cost less than $5. Pick up at your local medical supply company.
Jun 30, 2010 | Pari AC Adapter for the Respiratory Trek...
Tubing coming out of machine gets very warm
May 26, 2010 | Pari AC Adapter for the Respiratory Trek...
Air filter - where is it - how do you check it
This will vary by model. Pari compressors have a small round, slotted cover which holds the filter. Other manufacturers may place them in other locations, such as the side, or the back. Filters should be replaced on a regular schedule, such as every six (6) months, depending on use. Pari rates their filters for 500 hours, but recommends replacing the filter when you replace the nebulizer cup (if using reusable cups), which should be every 6 months to 1 year.
Source: http://www.pari.com/pdd/pdd-faqs.htm
Jan 17, 2010 | Pari Proneb Ultra II Compressor Nebulizer...
Sterlize my nebulizer
From Pari.com:
What is the best way to clean and disinfect my PARI Nebulizer?
Cleaning: After every treatment, thoroughly rinse the nebulizer to remove medication. Hand-wash with warm water and dish soap. Rinse thoroughly. OR... Wash in the dishwasher using a dishwasher basket on the top rack.
Disinfecting: (done after cleaning) every 2nd treatment day, mix a solution of 1 part distilled white vinegar and 3 parts warm tap water in a clean bowl. Soak the nebulizer parts (except the tubing and mask) for 60 minutes. Rinse thoroughly. OR... Mix a solution using Control III® Nebulizer Disinfectant and soak for 10 minutes. Rinse thoroughly. OR... Boil the nebulizer parts for 10 minutes.
Apr 20, 2009 | Pari Proneb Ultra II Compressor Nebulizer...
Health & Beauty Logo
446 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
