Question about Sony Playstation 3 (PS3) Console
Hi i cant put discs in2 the computer? it doesnt take the disc as i put it in, it will eject tho if i push it in so far help please.
  • 225 Answers
The laser will be off on the drive, you can send it in and they will fix this error or you can actually repair this error from home using a simple repair guide.
Posted on Sep 08, 2010
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Disc cant read the disc and will not eject the disc. I tried unplugging it and putting on and pushing eject. no good. what do you think bose 321 system
disc cant read the disc and will not eject the disc. I tried unplugging it and putting on and pushing eject. no good. what do you think bose 321 system ...
Oct 08, 2010 | Bose 3 2 1 GSX System
How to insert a cd in a laptop I have never operated a laptop befoe.Plz help .
go to my computer then you can see your disc drive there,
right click it then click eject, then the disc tray will pop out then put your disc and push the tray,
pls rate if this thing helps
Jan 25, 2010 | Computers & Internet
My son put a Nintendo wii disc into my ps3 and i cant get it to eject please help !
look for small hole near cd tray put toothpick or something small in hole and push
Dec 19, 2009 | Sony Playstation 3 (PS3) Console
Hi there, I have recently experienced problems with my ps3. When I put in my fifa 10 disc it plays for about 10 minutes then the crowd goes silent and when i pause all the ball goes out of play it freezes....
right m8 sound like the new update has messed up your system to try and update the system again by going to system update> download via internet once you have done this try your games again if problem still percists try this (LAST OPTION ONLY) turn your system on hold down the on/off button till it beeps twice then let go quick you should have a new screen select option 3 it will reset then do same again but select option 2 doing this should reset the system properly you wont lose any data tho pal so dnt wory messeage back if any problems
Nov 07, 2009 | Sony Playstation 3 (PS3) Console
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
NEED HELP!!!!
You can download the PC Suite of LG KU990 from Rapid Share. Its in two Parts.
Part 1 Part 2
If I was helpful, kindly do Rate! Regards.
Jul 29, 2009 | LG KU990 Viewty
PS3 Jammed Disc Drive: Cant put it in, when its in, cant get it o
I can fix this for you!
just go to this link:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300318746769
when you get your ps3 back this wont happen!
Apr 02, 2009 | Sony PlayStation 3 40GB System
Sony CDX-MP40, not take or load c.ds up, but ejects them!?!
Sounds like a jammed micro-switch, open it up and check for dirt in the loading mech.
Apr 14, 2007 | Sony CDX-MP40 CD Player
Sony Playstation 3 (PS3) Console Logo
13 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
